06-15-2020, 06:55 PM | #1 |
Member Sales Rating: (46)
Member#: 118389
CA: 04 wrx, built motor, built 4eat, SINGLE OWNER, $15,000
Hi,
Single owner, zero accidents, smoke free, fully built 4eat. Over 100k on the body, but <20k on built block and fresh tune. Details as follows: Engine: Woolman performance EJ257 signature build - EJ257 99.75 machine block - 79 mm induction hardened crankshaft - JE FSR pistons, Tool steel pins, Maxwell/Manley +2mm H beam rods, King race bearings, JE Pro Seal 0.039 Head gaskets, ARP 625 head studs Outforont motorsports heads - EJ20 heads - GSC P-D WRX S2 cams 272/272 Billet, GSC P-D Beehive valve springs w/titanium retainer valvetrain kit, GSC chrome polished intake valve (36 mm STD head), GSC chrome polished super alloy exhaust valve (32mm STD head), GSC manganese bronze exhaust valve guide stopper style, GSC manganese bronze intake valve guide stopper style - Stage 1 Head porting - Modified combustion chamber from EJ20 to EJ25 Valve covers with pressed AN fittings Brian Crower adjustable cam gears Killer B oil pickup/baffle Cosworth high pressure oil pump Kartboy pitchstop Group N engine mounts Grimmspeed lightweight flywheel Koyo Racing aluminum radiator Radium engineering dual catch cans Complete fuel system (F4M PTFE custom lines w/AN fittings, Aeromotive FPR, Aeromotive fuel rails, ID1300, Golan 40 micron fuel filter, Cobb custom fuel pump w/Aeromotive 340 and AEM in-tak 320lph, zeitronix Ethanol content analyzer) Setrab oil cooler (M22/-10AN)w/custom lines (Aeroequip starlite -10AN racing hose, Mocal oil filter adapter with 185F thermostat, Aeroequip starlite -8AN oil lines) Perrin GTX3076r rotated kit: - Perrin Garrett gtx3076r 0.82 rotated turbo - Perrin uppipe/catless downpipe with plumbed dump tube - Tial Q BOV - Tial MV-R wastegate (11psi spring) - Grimmspeed EBCS - Turbo blanket - Perrin FMIC kit - Grimmspeed P&P exhaust manifold and crossover pipe - AEM dry CAI DSS custom driveline: DSS carbon fiber driveshaft, DSS level 5 front AND rear axles, Cusco 1.5 way LSD rear differential (R160) Complete custom IPT transmission: IPT modified 4eat, Protorque high stall TC, IPT modified VB, B&M transmission cooler Stoptech complete big brake kit (Front and rear): ST40 front calipers (332/32 mm two piece front rotors), ST22 rear calipers (328/28 mm two piece rear calipers), Hawk HPS 5.0 brake pads, stainless steel brake lines Custom steering kit: 2015 sti 13:1 steering rack, F4M high pressure steering lines w/AN fittings, F4M low pressure steering lines w/AN fittings, JDM spec C power steering pump w/AN fittings, DAMD D-shaped anthracite wrapped 04 steering wheel with red stitching, OEM 04 wrx clockspring Custom Suspension: - Tokico D-spec struts w/RCE yellow springs - 04 group N rear tophats, Scooby921 strut spacers, Saggy butt shims (-25"), Whiteline com-c front tophats - Whiteline ALK - MSI billet lateral links with graphite bushings - JDM STI front control arms (non caster adding version) - Whiteline 22mm front swaybar - Whiteline 24mm adjustable rear swaybar - Kartboy front endlinks - Whiteline rear endlinks - Kartboy endlink spacers Recaro Topline seats (both Fronts) with wedge engineering brackets Lightwerkz custom s2000 HID headlights with angel eye kit Gramlight 57DR 18x9.5 +38mm 5x100 flat black (5 wheels total) Car tuned by Surgeline tuning with CA91 and e85 maps Many other mods included, please feel free to ask. Thank you!
06-15-2020, 07:10 PM | #3 |
Member#: 118389
Flat black is vinyl wrap. scheduled to get a fresh wrap week of June 22. Car is PSM underneath, good to great paint integrity. Also currently has STI hood scoop and splitter back on, but hood scoop delete is still available with purchase.
Thank you for your interest! |
06-16-2020, 08:29 AM | #4 |
Add Lightness
Moderator Member Sales Rating: (7)
Member#: 13699
NESIC
Vehicle:2021 Building It Better |
If you're looking to sell the car, just remove the present wrap and clean up the paint really good. Some people (ok....me) assume that there's horrible paint if a car is wrapped, so I take off $8k for a repaint right off the bat. Just a suggestion.
06-17-2020, 11:52 PM | #5 |
Member#: 118389
Did I mention that the car has a fully upgraded stereo as well?
Pioneer double din touchscreen dvd Mb quart reference series front speakers (component) Rockford fosgate power series amp Rockford fosgate 10in power series sub |
06-21-2020, 04:22 AM | #6 |
Member Sales Rating: (2)
Member#: 373413
TXIC
Vehicle:1999 OBS Silver/Grey |
Very interested, since you’re getting a fresh wrap can you take pictures of the whole car including any road rash and the quarters and under the car?
06-22-2020, 07:40 PM | #7 |
Member#: 118389
Bump. Thank you for the interest! Car also has battery relocated to the trunk to free up some of that engine bay space for upgraded goodies!
06-28-2020, 05:09 PM | #9 |
Member#: 118389
Excellent question. Ppl seem to love this steering wheel and it’s hard to find for the 04-05 fitment. Somebody had one FS on these forums before, not sure if it sold? No, will not part our steering wheel, so lucky buyer of this wrx will get the FULL package! Did I mention this steering wheel is mated to a full 2015 sti steering rack? Yes, the one with the 13:1 ratio that’s so desired. Also has a higher flowing jdm sti power steering pump to match! |
07-08-2020, 07:11 PM | #11 |
Member#: 118389
https://img.nasioc.com/i/fNbyQ.jpg
FYI, although the look is pretty subtle, these are by no means OEM recaro seats. These are fully functional aftermarket, genuine Recaro Topline front driver and passenger seats. Probably the most comfortable and adjustable, full leather, bucket seats i've seen. They retail for about $3k a piece! Last edited by acheung; 07-08-2020 at 11:42 PM. |
07-11-2020, 01:49 PM | #12 |
Member#: 118389
Weekend bump! Gray wrap almost done. Will post new pics soon. Fresh 3m wrap and ceramic pro!
Prob the ultimate daily driver! No worn out left legs from clutching it in traffic! Haha. Help maintain leg muscle symmetry! |
07-28-2020, 08:07 PM | #15 |
Member#: 118389
Perrin, recaro, driveshaftshop, mb quart, Cobb, grimmspeed, injector dynamics, aeromotive, aeroquip, radium engineering, volk, stoptech.... just some of the premium brand products that went into this build!
