Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 12-09-2011, 02:42 AM   #1
wrxkid157
Member#: 201046
2004 WRX
Default STi steering rack over wrx?
I have heard that the STi steering rack has a "better feel" and that its better handling over the wrx does anyone know if this is true or worth it at all?
wrxkid157 is offline   Reply With Quote
Old 12-09-2011, 04:49 AM   #2
Arnie
Member#: 1725
2002 Subaru Forester
SG silver
Its a quicker rack. I enjoyed the swap (plus STi steering wheel) in my bugeye. I can't say it has more feel over a standard WRX rack, its just quicker.
Arnie is offline   Reply With Quote
Old 12-09-2011, 10:02 AM   #3
wrxkid157
Member#: 201046
2004 WRX
the one i was going to get doesnt have the STi stearing wheel but that doesnt bother me because i dont mind mine and i was planning on getting a new one in the future. how hard was the install?
Old 12-09-2011, 12:53 PM   #4
Arnie
Member#: 1725
SG silver
In principal its not too bad. Mine was a bit more involved as I did an 07 STi rack, sub-frame and steering wheel. If you get an 04 STi rack its plug and play. The 05+ STi's all use a different subframe mount. So theoretically you need to get an 05+ STi subframe too if you want to mount the rack properly. However I've seen a few threads were people have mounted an 05+ STi rack using the standard 2 bolt on the driver's side. You'll have to search for what they did. While in there I suggest doing uprated steering rack bushings for whatever rack you get. With the 07 STi subframe/rack into my 02 I had to bend the hard power steering lines a wee bit to get them to line up. A bit finicky but not a problem. Also get some new o-ring seals. I wish I had done that but I was in a rush to get it done. One of my lines weeps a wee bit.
Old 12-09-2011, 01:49 PM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
The 05+ Saabs and 06+ WRXs have the same rack as the STi ratio wise.
Another area of difference is that the STI has a solid linkage joint between the column and the rack. Other models have a rubber isolated one which feels numb.
Old 12-10-2011, 10:15 AM   #6
azscooby
Member#: 115297
2002 ej207 vf34
The newer 05-07 WRX and STI racks will fit, without swapping subframes.
They use the same mounting holes but fewer mounting points.
Swapping the subframe will give you the additional mounting points and theoretically, added rigidity. Though many have been running this way for years with no issue.
I swapped in a newer rack, solid steering linkage and STI wheel.
Money well spent in my opinion.
If you're needing a new rack, its a no brainer, do the newer rack.
azscooby is offline   Reply With Quote
Old 12-10-2011, 11:05 PM   #7
Pinned
Member#: 152707
I never knew about the 06+ WRX using the same rack ratio as the STi. Will those swap in directly to an earlier WRX subframe, or is it the same deal as the 05+ STi (fits, but not "correct")?
Pinned is offline   Reply With Quote
Old 12-11-2011, 01:57 AM   #8
pocketdrummer
Member#: 197301
2005 WRX STI
W R Blue (02C)
Will any STI steering rack fit on an '02 WRX Wagon?
pocketdrummer is offline   Reply With Quote
Old 12-11-2011, 11:33 AM   #9
25rsti
Member#: 166324
no, just 04 sti
Old 12-11-2011, 03:04 PM   #10
azscooby
Member#: 115297
2002 ej207 vf34
A 04, 05, 06, 07 WRX/STI steering rack with "fit" in an 02 Wagon (and any 02-07 WRX/STI for that matter.)
An '04 STI rack will be a direct fit, an 05-07 will still work, (and has been proven to work, even long term) it will simply use fewer mounting locations.
There are MANY people, including myself, that have been running the newer 05-07 STI racks in 02-04 WRX's without any problems.
Seems to be a lot of people saying that it will not work. I have done it, it does work.
Others have ten's of thousands of miles with the swap with no problems.
The '05-'07 WRX/STI rack has more mounting points than the 02-04.
If you swap an 05-07 WRX/STI rack into an 02-04 WRX you will use four locations to mount the rack, just like the original rack.
The 05-07 WRX/STI uses additional mounting points for added rigidity and a different crossmember.
When you do the swap, you simply use the original mounting points, four of them. Same fitment as the original.
If you swap the crossmember you will get the additional mounting points. Some go this route, not a bad idea, but not entirely necessary.
Hope this clears it up.
Old 12-11-2011, 04:39 PM   #11
go1d1e
RIP 2/21/14
Member#: 91263
02 WRX Wagon
I have an 05 STi rack in my bugeye wagon.. it fits..
go1d1e is offline   Reply With Quote
Old 12-11-2011, 08:06 PM   #12
03SubyWRX
Member#: 200767
2006 WRX TR
2013 Crosstrek
I installed an 04 STi rack into my bigeye over the summer. I have really enjoyed the quicker ratio, it definitely made a positive difference. Just make sure that you use new orings on the lines when you do the swap.
03SubyWRX is offline   Reply With Quote
Old 12-12-2011, 02:52 AM   #13
wrxkid157
Member#: 201046
2004 WRX
So basically there are 4 mounting whole for the 02-04 wrx and so does the the 04 STi but the 05-07 STi have (lets say 6 mounting whole since i dont know the number) you will use 4 of the 6 if you swap 05-07 STi and you will use "all" 4 from the 04 so unless you swap crossmember you will use 4 mounting bolts no matter what year right?
Old 02-01-2012, 06:13 PM   #14
naggg
Member#: 146395
2009 Subaru STi
Satin White Pearl
just ordered my 05 STi rack for my 05 WRX today from what i understand everything is a perfect swap over. i might even weld in my own brackets for the extra 2 that the 05+ rack has.
naggg is offline   Reply With Quote
Old 02-03-2012, 02:26 PM   #15
quickgtp
Member#: 14891
2002 WRX wagon
286 AWHP craptastic CA 91
I just did the whiteline steering bushings and changed over to an STi solid steering linkage. It was just $32 for the bushings and $50 for a used linkage and what a difference! Feels like a new rack or a new car. Sorry a little off thread but another option.
quickgtp is offline   Reply With Quote
Old 02-20-2013, 12:17 AM   #16
luftpirate
Member#: 270358
I'm guessing that when you do the 05+ crossmember / rack swap you also need the 05+ column? Can anyone confirm this?
luftpirate is offline   Reply With Quote
Old 02-20-2013, 08:10 AM   #17
JarHarms
Member#: 138994
2006 WRX, 6MT, 5x114
Originally Posted by azscooby View Post
The newer 05-07 WRX and STI racks will fit, without swapping subframes.....I swapped in a newer rack, solid steering linkage and STI wheel.
No need for the 05+ cross member. No need for a new column. Get the two longer bolts needed for one side of the 05+ rack (your existing ones will be too short). Reuse the two shorter bolts and steel bracket on the other side. Install a WL steering rack bushing kit while you are in there. Also find a used (or new) STI solid steering link. Install, use new fluid, bleed air out completely, and re-align front end.
JarHarms is offline   Reply With Quote
Old 04-11-2017, 03:31 PM   #18
A-man07
Member#: 271525
7/2 STi/WRX wagon
SWP/AW
Subscribed for future reference.
A-man07 is offline   Reply With Quote
Old 04-15-2017, 08:22 PM   #19
Genis17
Member#: 466116
I know this thread is old. Also a little off topic. I'm having trouble understanding witch engine crossmember will fit a 04 wrx sedan. My is badly rusted. Most claim the enything from 02-07 will fit but can only find STI crossmember.
I know 02-04 are the same but different than 05 and 06-07 different than the previous years. Can someone help me out on this.
Genis17 is offline   Reply With Quote
Old 04-15-2021, 05:41 PM   #20
sebastian323
Member#: 510671
2006 WRX
Gray
does the 06+ wrx have the solid linkage also ? edit: the non-sti WRX has the rubber core linkage - not the solid STI one
sebastian323 is offline   Reply With Quote
Old 04-15-2021, 06:22 PM   #21
snow_bound26
Member#: 395793
2005 92x Aero
Beige
Read the dates of the posts before you reply
snow_bound26 is offline   Reply With Quote
STI steering rack vs Wrx steering rack Serkan Brakes, Steering & Suspension 37 11-10-2015 09:27 AM
STi Steering Rack Vs WRX Steering Rack JDMWRX03 Pre-2002 Factory Turbo Powertrain 1 07-07-2009 12:08 PM
used sti steering rack and WRX PS lines IA Performance Suspension/Brakes/Handling 1 11-05-2008 11:31 PM
WTB: 04 STI Steering Rack or 02-04 WRX Steering Rack zee lee Private 'Wanted' Classifieds 7 04-01-2008 03:34 PM
Convert a 05 STi Steering rack over to a 04 rack hard or easy? 2-quick4u Brakes, Steering & Suspension 1 02-12-2006 07:54 AM
