03-08-2011, 12:30 AM | #26 | |
Member#: 251552
SWIC
Vehicle:2017 STI Pure Red |
The bottoms of mine ripped off...well, got blown into my tire (both sides) and got chewed up. I might make some new ones, but I already secured my wire bundles with some calpico 10mm tape. It's like electrical tape on crack.
03-08-2011, 01:33 AM | #27 |
Member#: 169062
SCIC
Vehicle:2006 STi WRB |
Mine got yanked along with my undercover thingy by the tow truck after I got busted for doing donuts. Yes, I know stupid me.
05-05-2011, 12:11 AM | #28 |
Member#: 236092
NESIC
Vehicle:2004 wrx full exhaus vf48 aps big tmic nstuff |
First autox event of the year and my drivers side came off. I was on my way home, going around a corner at an intersection at <10mph, you wouldn't believe how loud it was. I thought I had crunched some sheet metal somehow. I was relieve to see that it was just the liner... I wonder if anyone has ever fabbed up some custom ones.
05-05-2011, 12:28 AM | #29 | |
Member#: 88501
BAIC
Vehicle:2011 WRX Hatch Dark Grey |
The stupid clips are constantly falling off for god knows what. Just dialing drive and clips will disappear. Bottom line, as part of inspection maintenance you're just going to have to check fender liner clips too. |
05-05-2011, 12:37 AM | #30 |
Member#: 125937
RMIC
Vehicle:03 WRX I do not like your tweed, chap. |
My car only had the back half of one of them in it when I bought it. Then again, I bought the car with a terrible chargespeed-knock-off fiberglass bodykit, so when I switched back to the stock bumper cover, I didn't have fender liners.
I pulled some out at a junk yard once, but after getting them home, cleaning them, and making sure that they fit well, I realized that 80% of the fender liner is actually covering the FRONT of the wheel assembly and underneath the front bumper. I guess I kinda figured at that point that it was more or less unnecessary and just never put them in. But putting some of that Griot's Garage stuff on the inside of the fenders is helpful for protecting the vehicle and for noise reduction. I will probably just keep rolling without them, as I really don't see them being incredibly necessary. That, and I can claim that it is "weight reduction" |
05-05-2011, 01:29 AM | #31 | |
Member#: 88501
BAIC
There are wire looms in there that are exposed without the liners. The liners keep moisture and mud out of chassis. Reduce noise and reduces the amount of junk the wheels kick up from flying into the engine bay. Do what UP2MTNS did and make heavy duty liners. http://www.dirtyimpreza.com/forums/s...indestructable |
05-05-2011, 07:00 AM | #32 |
Member#: 125937
RMIC
Hmm. Well, I've been rolling around that way for about.....6 years now, with no issues. The wires were covered with split loom when I bought them. But I may look into this "heavy duty" mod anyway, just to keep it clean inside and reduce road noise.
05-05-2011, 07:10 AM | #33 | |
Member#: 38469
NESIC
Vehicle:07 LGT spec-b Crystal Grey Metallic |
05-05-2011, 05:31 PM | #34 |
Member#: 15794
SCIC
Vehicle:2002 PSM WRX 2003 BMW e46 M3 |
07-24-2011, 03:21 PM | #35 |
Member#: 245199
My front bumper is sagging a bit due to missing the front fender linings. For everyone that has their lining removed, how do you keep the bumper attached?
07-24-2011, 03:25 PM | #36 |
Member#: 280333
I had heard that before as well but it's complete B.S. manufacturers use them for a reason as they keep moisture from the wheels and tires out of the engine bay. Yes the wiring is water safe but it's still not a bad idea to leave them. Even in my super low cars I run them, even if I have to cut two of them apart and and zip tie them together to get the clearance I need.
07-24-2011, 04:26 PM | #37 |
Member#: 289311
Vehicle:2011 Subaru WRX STi White |
Website
Subarupartsforyou.com is a pretty good website.
07-24-2011, 04:41 PM | #38 |
Member#: 117112
06 wrx here, and yes a lot of wires are exposed on the driver side which sucks and i havent had the time to tape them up yet.. like most people said here you should prob take them off if your really low and have an aggressive setup, which is why i took... well mine ripped off while driving in NY but ive kept it off since then =D
07-24-2011, 06:12 PM | #39 | |
Member#: 67004
SCIC
Vehicle:02 vf30 pnp wagon silver and cf |
07-24-2011, 06:52 PM | #40 | |
Member#: 251552
SWIC
07-27-2011, 04:50 AM | #41 |
Member#: 57156
SCIC
Vehicle:2007 V.8 207 STi Mercedes Polar White |
I'm gonna be making some of my own soon. Maybe I'll run out for parts tomorrow.
07-27-2011, 10:16 AM | #42 |
Member#: 163682
Um I've owned 2 subies already n none of my liners ever looked that bad I guess u guys aren't into thoroughly washing ur cars cause that would prevent all of that
07-27-2011, 12:07 PM | #43 |
Member#: 57156
SCIC
I'm not sure if you bothered to read the info in the thread yet but there is no way that washing our cars is the issue. One of the major issues is clearance from wide wheels and wide tire setups. So unless the washing of our cars can give us more space in the fender well, I just don't see your point.
07-27-2011, 03:31 PM | #44 |
Member#: 133267
NWIC
Vehicle:2004 psm WRX |
It's absolutely necessary on the 04's, it practically holds the front end together
Lost my 1st one ever this month on the highway at 70mph, scared the bejesus out of me... |
07-27-2011, 04:59 PM | #45 | |
Member#: 139955
NESIC
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
no, it doesn't. |
07-27-2011, 05:51 PM | #46 |
Member#: 133267
NWIC
^^^^^yes it does....i should know
No really, without the fender liners pop-tabbed into place, the lower front corners where "splitters" would be move quite a bit with no structure there....the design is poor & perplexing actually. |
08-03-2011, 05:59 PM | #47 |
Member#: 220008
Vehicle:2004 WRX STi WRB |
both driver and passenger side liners on my car are disconnected from the front bumper ( 2 clips where they meet the stock sti splitter ) and i haven't had any problems with mine. they kind of just hang out there lolol
09-17-2011, 05:05 PM | #48 |
Member#: 78314
Vehicle:04 PSM WRX Audi mask the right way |
I was looking at that DIY and I really want to try it.
09-17-2011, 05:09 PM | #49 |
Member#: 143522
SWIC
Vehicle:1987 Brat GL 4 Speed 98 Forester L (RIP) |
09-17-2011, 07:07 PM | #50 |
Member#: 286408
Vehicle:WFC #952 Function:error! |
I'm just waiting for my tires to burn through where they rub atm
How many people still have their wisdom teeth? | alacrity024 | Off-Topic | 58 | 11-28-2005 11:42 AM |
How many people still have their tonsils? | Grap | Off-Topic | 23 | 09-21-2005 11:17 AM |
Follow up: how many people regret putting their summer wheels back on? | Safir | Mid West Subaru Owners Club Forum -- MWSOC | 39 | 03-20-2004 01:21 PM |
How many people have had their brake pedal fall to the floor? | ScoobieBoy | Warranty Issues & SOA Problems | 6 | 05-14-2002 10:44 PM |
How many people have had their stock EGT sensor go bad?? | redobs | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 33 | 03-27-2002 06:40 AM |
