12-21-2020, 12:58 PM | #8876 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
I wanted to run something by you all. My 2019 STi is FBO, flex fuel, and 20G XTR. In the process of pulling the header to install my Perrin motor mounts I noticed the primary for cylinder #4 (just had to be #4) was black and the other three were a light tan. Rubbing your finger left no residue. Looking into the exhaust ports I saw no differences between the four. When I was initially dyno tuned for stage two the motor passed a compression test done by the tuning shop. That was about 10K miles ago and now I'm tuned for a 20G XTR, EWG, and Killer Bee holy header. I opted for a conservative tune that netted 380WHP and 370WTQ on a dyno jet. Ever since my factory specified break in I consume 1 qt every 3k miles. I do get on it frequently and do a lot of engine braking so the oil consumption doesn't concern me too much. Every one of my Blackstone oil analysis's has come back good. Knock consists of the occasional 1.41 at high load tip in and never during WOT.
I've decided to do a step by step diagnostics process that my tuner an I have agreed on. First is after 10+ tanks of E70-80 I ran a tank of 93 through it and was surprised at how fast my exhaust tips sooted up. After a couple more tanks of 93 I intend on pulling the header and inspecting it. If the primary is still black I will pull the plugs, inspect, and compression test. While I'm under there I will install the cylinder 4 cooling kit I got last Christmas. I'd like to add that at no point in time is smoke apparent from the exhaust, start up or otherwise. So on to my question. Do those of you that go from E85 to 91/93 experience the sooting up of the exhaust tips? My hope is that my ID1300 injector for #4 was dirty and delivering too much fuel and the 93 will clear it up. The way the car runs has given me no indication there is an issue. Any insight you all could offer would be appreciated.
12-30-2020, 11:26 PM | #8877 |
Member#: 465688
Vehicle:2008 WRX Gray |
2008 WRX JDM 2.0 Swapped
362 WHP & 337 WTQ on Dynapack / jesseisbeast / 08 WRX hatch / JDM 2.0 swap + Tomioka 20G / 1000cc @ 98% / @ sea level
Forged internals and full bolt ons. Could have made more power but we ran out of injectors. I also think I have a preturbo exhaust leak which is why the spool is so slow. Tuned by Henry at Church automotive. Last edited by jesseisbeast; 01-03-2021 at 04:27 PM. |
01-01-2021, 06:34 PM | #8878 |
Member#: 291681
Vehicle:2004 Pearl White STi IAG1000, PTE6870, Haltech |
2004 STi
60*/479ft above sea level 891whp/825wtq Mustang Dyno FIC2600cc injectors Precision Gen2 6870@45psi E80 |
01-27-2021, 03:14 PM | #8879 |
Member#: 142417
Vehicle:2011 STi Dgm |
02-08-2021, 08:49 PM | #8880 |
Member#: 319133
Vehicle:2011 STi Black |
02-24-2021, 05:59 PM | #8881 |
Member#: 141470
SCIC
Vehicle:2017 STI CWP |
Good afternoon everyone. I have another question before I go flex fuel. I already have all the parts to go flex but my tuner recommends I go with an EWG prior to coming in for a tune. Is this a necessary piece (I don’t have a problem doing it) or is the stock setup ok for flex. I currently am tuned with 1050 injectors, turbo inlet, catless TB, grimmspeed fmic and intake, 3 port ebcs, and regulator. If an EWG is recommended, I’m looking at the grimmspeed one as it looks like a well built piece. Any help would be great, thanks again everyone.
02-28-2021, 09:16 AM | #8882 | |
Member#: 157833
Vehicle:2017 WRB STI 2007 WRB STI-sold |
02-28-2021, 09:24 AM | #8883 | |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
The problem with the VF turbos is they like to boost creep a lot especially at higher boost so going EWG is a great idea and you should 100% listen to your tuner if they say its an important piece of the puzzle for your build. |
03-02-2021, 09:56 PM | #8884 | |
Member#: 333315
Agreed. Had exact same issue (boost creep) than an ewg resolved |
03-04-2021, 12:01 AM | #8885 |
Member#: 141470
SCIC
Thank you guys for the replies. I ended up getting the ewg so I just need to set up a dyno time to get the flex set up.
03-04-2021, 09:42 AM | #8886 |
Member#: 216747
South East
Vehicle:2009 STi Dark Grey Metallic |
For the ewg you get different springs that actuate at higher or lower psi. Depending on what your tuner recommends, I suggest going for a stronger spring that opens at higher boost... it helps to not hve to be too careful with the throttle when you dont want it to be loud... mine starts opening around 7psi and I wish I had known about it beforehand. I would have prefereed it opening somewhere between 12 and 15 psi...
03-12-2021, 10:16 AM | #8887 |
Member#: 291681
04-27-2021, 02:19 PM | #8888 |
Member#: 501308
RMIC
Vehicle:2020 STI 741awhp (Mikeytuned) |
The E85 Army Thread
Power mods and supporting mods are:
20 STI ETS rotated kit W/PT 6466 .82 A/R ETS V2 header PT 46mm EWG ID 2600's Cobb FMIC Cobb flex fuel Cobb fuel pressure sensor Processwest "street series " intake manifold Boomba 75mm throttle body TGV deletes EGR deletes IAG rails and lines IAG AOS " comp series " ETS TBE 3" catless W/ mufflers Grimmspeed EBCS Tial Q BOV 3mm phenolic spacer Radium dual hanger Walbro 450's ( hard wired ) -8 feed and -6 return lines Aeromotive FP regulator Air pump delete Competition clutch twin disc organic Elevation: 4200 ish feet Injector duty cycle: 48.28% Fuel pressure: 71 psi Boost 28 psi tappering 24 psi E60 blend day of final flex fuel tune Tuned by: Mike Botti Etune Last edited by gtlyearsley; 04-28-2021 at 07:10 PM. Reason: forgot info |
04-28-2021, 08:20 AM | #8889 | |
Member#: 142417
What headers you using? How much power? |
04-28-2021, 08:45 AM | #8890 | |
Member#: 501308
RMIC
Stock block too! Whoops i forgot to add that. I'm using ETS V2 headers! He said its around 600 wheel map |
04-28-2021, 11:06 AM | #8891 |
Member#: 142417
Excellent!. I’m on my 3rd STi. Got 1400 miles on my 2020 stage 1 pro tuned so far.....Have a bunch of parts from my flexfuel 2011 and going to do something soon I will probably only go stock location 20g or Green and TMIC with flexfuel but would love a rotated set up, FMIC and that PW manifold is a thing of beauty!
04-28-2021, 01:48 PM | #8892 | |
Member#: 501308
RMIC
Who protuned you don't mind me asking? |
04-28-2021, 01:56 PM | #8893 | |
Member#: 508105
NWIC
Your setup looks bonkers, would love to see a clip of the car during a pull. |
04-28-2021, 06:59 PM | #8894 | |
Member#: 501308
RMIC
That was fuel pressure on the pull as well as injector duty cycle. My fuel system is definitely more then I need atm, but I bought with the intentions of a built motor in the near future. But yes I need to! Botti actually sent me another fire map and I am yet to do a pull and some logs. So it will be more power I do have a clip of a prior map revision when the stock clutch started slipping. It started to slip around 5400 rpm lol. And that was around 25 psi |
04-28-2021, 07:46 PM | #8895 | |
Member#: 508105
NWIC
04-28-2021, 09:33 PM | #8896 |
Member#: 501308
RMIC
04-29-2021, 09:12 AM | #8897 | |
Member#: 508105
NWIC
Did you buy the car new? You got a virtual dyno sheet? I am building a big motor setup in my 02 lol. Using a GTX 3576 Gen2, IAG magnum SB, 207 Spec C heads, 199D cams, ETS FMIC, STI non-DCCD 6MT etc. Should be a rocket ship on ethanol when its done. And it'll rev to 8K Last edited by K3rm1tth3fr0g; 04-29-2021 at 01:03 PM. |
04-29-2021, 09:51 AM | #8898 | |
Member#: 501308
RMIC
Yep brand new last July! I got this plot from a few of the revisions. Keep in mind it doesn’t have my final revision, as I have yet to log it Man that thing will be a screamer also! Ethanol is king |
04-29-2021, 09:55 AM | #8899 | |
Member#: 508105
NWIC
That dyno chat. Sheesh it just pulls and pulls! You said you're stock on the stock clutch? That's pretty neat. |
04-29-2021, 10:00 AM | #8900 |
Member#: 501308
RMIC
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
