12-12-2017, 02:32 PM | #1 |
Member Sales Rating: (1)
Member#: 447566
Vehicle:2017 86 Black |
Whiteline Rear Subframe Inserts
http://www.whiteline.com.au/product_..._number=KDT938 Installed these on my 2017 WRX over the weekend (well, all but one missing insert ) and wanted to share a quick review. The primary difference is that the driveline feels more connected with less lash and compliance. I have previously installed the Perrin Pitch Stop brace, Group N pitch stop, Group N transmission mount, Whiteline transmission crossmember bushings, Perrin Pitch stop, Perrin shifter busing and short shift kit, and Whiteline rear diff inserts. Each of those made shifting feel a bit less vague, and then adding the rear subframe inserts made a surprisingly noticeable contribution to eliminating some of the rubberband feel of shifting. Little no no increase in NVH. I'd be lying if I told you that I can instantly feel the car handling better because there's 1 less degree of rear subframe movement on my daily commute. But an autocross and maybe a track day are planned in the future, so we'll see if it makes any noticeable difference in those environments.
01-15-2018, 09:09 PM | #3 |
Member#: 447566
Did it myself in my garage. Took about 2-3 hours because I had to wiggle the subframe around with a jack to make sure I got a straight shot at all the bolt holes. Didn’t want to risk any cross-threading. It’s totally doable as a home DIY.
05-08-2021, 01:25 AM | #6 |
Member#: 523205
Vehicle:2016 WRX STI |
Has anyone tried these?
https://www.rallysportdirect.com/fit...e-lockdown-kit |
