Old 07-28-2020, 09:09 PM   #1
Rod702
Member#: 132978
2004 Mike angel tund
efr 7670 1.05 Twiscroll
Default Xona 6564 x3c 586 whp mustang Dyno
Event: dyno pull
Location: All access tuning/ Devin le blanc. Las Vegas Nevada. Mustang Dyno
Ambient Temp: 100 F
Elevation: 2001 ft.
Weather: hot as fuk, July vegas weather
Track and Conditions: Dyno is rollers
Tires: hankook Ventus v12 255/35/18
Car: 1994 gc coupe
Tuner: Devin le blanc, all access tuning Las Vegas Nevada
Dyno Info: mustang
Transmission: factory sti 6 speed 2005
Gear: 4th gear
Peak HP at RPM: 586 @ 6444 rpm
Peak Torque at RPM: 508 @ 5821 rpm
Baseline hp/tq for a stock on same dyno: 200
Target Boost: 30 psi
Target AFR: dunno
Fuel: good E85
Engine/Power Modifications: built longblock. Fobiawrx rotated kit, xona 6564 x3c .82. Id 1700cc injectors. Built heads gsc II cams +1mm intake valves.
Rod702 is offline   Reply With Quote
Old 07-30-2020, 01:55 AM   #2
can250
Member#: 452601
some nice numbers there have you been down the 1/4 mile yet
can250 is offline   Reply With Quote
Old 07-30-2020, 02:54 AM   #3
Rod702
Member#: 132978
With that big ass wang. I’d be doing like 15’s ***128514;. I built this car to take some turns sir. But thanks for the compliment !
Old 07-30-2020, 11:11 AM   #4
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
Sparkly
You'll want to put the outlet of the AOS somewhere else. The crawford WILL dump oil when you start pushing it through corners, and it's right over the hot side of the turbo. That is a fire waiting to happen.
I've had the crawford before, had the oil push issue, converted to IAG, still pushed some oil.
Old 07-30-2020, 12:07 PM   #5
Rod702
Member#: 132978
Good to know thanks
Old 08-12-2020, 02:53 AM   #6
wuuusaa
Member#: 92894
2015 Wrx - fury kit
silver duh
Curious how are you liking that turbo? I've been eyeing Xona Rotors for quite sometime now.
Also where did you get that BOV/intercooler hose adapter from?
wuuusaa is offline   Reply With Quote
Old 08-12-2020, 07:15 PM   #7
silversurfer05
Member#: 366241
2009 09 wrx delivery
Dgm
Torque solutions maybe. They have a **** ton of adapters for BOVs. tial hks ect
silversurfer05 is offline   Reply With Quote
Old 08-12-2020, 07:23 PM   #8
wuuusaa
Member#: 92894
2015 Wrx - fury kit
silver duh
^^ thanks silversufer05
Old 08-13-2020, 01:47 AM   #9
Rod702
Member#: 132978
Silicone intakes.com
Old 08-13-2020, 01:49 AM   #10
Rod702
Member#: 132978
As of now I have had no problems with turbo. The powerband is very linear and really easy to control.
Only thing suks is the wait from fp. This was 3 months before COVID. Now it's probably longer.
Old 08-19-2020, 08:54 PM   #11
awd2pt5
Member#: 478704
what is the mass air setup
awd2pt5 is offline   Reply With Quote
Old 08-25-2020, 10:40 PM   #12
Rod702
Member#: 132978
Pretty sure tuner set it for intake temps only. I have 4 bar map sensor.
Old 08-28-2020, 10:54 PM   #13
TDagen
Member#: 163648
V9 6mt R180 Brembos
Nice GC, looks tough in that first photo. 586whp and set up totear up the corners, that sounds like fun.
Fobiawrx's Stuff is top notch. Enjoy!
Old 08-29-2020, 02:01 AM   #14
Rod702
Member#: 132978
Fobiawrx’s Stuff is top notch. Enjoy!
Thank you sir!
Old 08-30-2020, 10:27 PM   #15
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
That is a beautiful car. Love the setup. The power delivery is awesome.
Advice from a friend- make sure your hood latches are not knock-offs. He had his hood open unexpectedly at 125mph on a straight (thankfully).
I'd be a bit worried about the line that runs over the hotside of the turbo. May want a bit more clearance than what I can see in the pictures.
Old 09-02-2020, 01:41 PM   #16
Rod702
Member#: 132978
I got legit aerolatch to hunker down the bonnet. The way the Crawford aos and the a iag expansion tank entry and exit it just looked like the natural path to go. I was worried about that too, but I put the Crawford’s Fire sleeve over that hot section.
Thanks for compliments bud!
Old 09-02-2020, 02:27 PM   #17
SnoBrrru
Member#: 501446
'15 WRX
gone plaid
This made me laugh while on a conference call for work. Thanks.
SnoBrrru is offline   Reply With Quote
Old 09-05-2020, 12:24 PM   #18
Rod702
Member#: 132978
https://gfycat.com/bluesmartcornsnake
Old 11-24-2020, 10:28 AM   #19
Brianb351
Member#: 332869
2007 STI lmtd #089
Morning Frost White
I'm curios what clutch you are using.
Brianb351 is offline   Reply With Quote
Old 12-20-2020, 03:26 AM   #20
Rod702
Member#: 132978
If do recall it’s the act extreme heavy d
Old 03-18-2021, 09:58 AM   #21
Karlot
Member#: 339923
2006 Impreza WRX STi
grey
how's the boost come on when on the street/track? i'm debating on a few turbos but this xona has definitely caught my eye. looks very similar to the 3076 by garrett. how fast does it hit spool and how's transient response?
Karlot is offline   Reply With Quote
Old 03-22-2021, 02:17 AM   #22
Rod702
Member#: 132978
I thought Dyno plot looked laggy in my opinion, even called fperformance turbo and talked to one of their techs about it. Wyatt from Fp said this turbo is similar to gt35 turbo, but boost comes in sooner. On the street it’s snappy, and between gears it spools up quick. On street I’m getting 28psi at 4500k. But then again this is on a 2600 lbs. car so my results might differ then yours.
