12-08-2020, 09:56 PM | #401 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
However, there are several xW-40’s that meet the most stringent oil specs in the world (Porsche, MB, VW) and can be bought for $25-$35 for 5 qts from Amazon or Wal-Mart.
12-08-2020, 10:07 PM | #402 | |
Member#: 767
With the move to SP/GF6 Mobil 1 has dropped the HTHS from most of their data sheets, so the exact HTHS is unknown. The EP line does have higher levels of PAO base stocks, but you need to look at specs to get an idea of HTHS. GF6 = <3.5 and ACEA A3 or C3 = 3.5+. |
12-08-2020, 10:08 PM | #403 | |
Member#: 488985
Vehicle:2009 wrx dgm |
12-08-2020, 10:17 PM | #404 | |
Member#: 767
12-08-2020, 10:26 PM | #405 |
Member#: 488985
12-09-2020, 08:23 AM | #406 | |
Member#: 767
12-09-2020, 05:33 PM | #407 | |
Member#: 488985
12-20-2020, 04:32 PM | #408 |
Member#: 493859
TXIC
Vehicle:06 WRX TD Swapped sorta black-ish |
Any reason to not use CK-4 oils for our older EJ engines? The necessary additives in FA-4 oils to get a little more fuel mileage isn't likely going to be a benefit, no?
Living in a high temperate location seems like the higher viscosity CK-4 oils would be a better choice for me than the FA-4 oils particularly when used in a high output modified engine? EJ25 +/-450 HP, oil cooler, AOS, TMIC, Mishi XL radiator, E85 flex. Summer temps regularly 100f, Winter temps rarely below 40 cold start. Have not had bearing clearance conversation with machine shop yet, so have not put that variable into the discussion yet. Last edited by pazzoduc; 12-20-2020 at 04:40 PM. |
12-21-2020, 02:39 PM | #409 | |
Member#: 767
01-24-2021, 12:37 PM | #410 |
Member#: 520370
Vehicle:2022 Subaru BRZ Crystal white |
even after reading all this, I still dont understand why my car is consuming so much oil. I once had to change it at 970 miles on the oil, and just yesterday i changed it at 1150 miles on the oil. Why did i change it so soon? When i check my dip stick its dry and black. I checked the intake to see if there was oil going in there but there isnt. I use "Motul 8100 X-cess gen2 5W-40. What can be going on in there thats sucking so much oil?
01-27-2021, 08:18 AM | #411 | |
Member#: 767
Oil being black isn't necessarily a problem. It could just mean that the oil is doing its job and holding contaminants in suspension. |
01-28-2021, 12:01 PM | #412 | |
Member#: 520370
02-08-2021, 12:07 AM | #413 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
These cars have rings that stick...I combat it with combination of seafoam through brakebooster hose an atf in the fuel...I have had great luck with motorcraft an have just hopped on board the amsoil train, had great results from customer cars so going to try it myself! First sti did mobile 1 an was sucking a quart between changes on brand new engine...current sti consumes no oil an doin 5k oci did 2 uoa an had great comments from blackstone, 170k miles currently an no rebuild! https://www.amsoil.com/offers/pc/?zo=30227871
03-03-2021, 06:25 PM | #414 |
Member#: 513565
I ran ran amsoil in my 2005 rs for the first 80,000 miles. I switched to Mobile synthetic 5w30 and it seemed like it wasn’t even close to amsoil. Anyone else notice anything like this?
03-03-2021, 06:31 PM | #415 |
Member#: 373868
Vehicle:'04 STi WRB |
11-15-2021, 09:10 AM | #416 |
Member#: 417650
South East
Vehicle:2004 Impreza WRX Silver |
Surprised I didn't see Royal Purple on the list.
11-15-2021, 09:58 AM | #417 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
11-15-2021, 12:29 PM | #418 |
Member#: 767
RP has never been that popular in the Subaru community. To get a good Royal Purple oil these days, you need to go with one of their non-certified pricier HPS line that has Synerlec. But that line has high ZDDP and high detergent levels, neither of which are ideal in a DIT (intake valve deposits and LSPI). No worries in a non-DIT though.
If you go with the API certified High Performance Motor Oil line, you are probably not getting anything any better than you'd get for $25 for 5 qts at Wal-Mart or Amazon. Their oil lineup was revised when RP was purchased by Calumet. Royal Purple's Synerlec - BITOG Last edited by bluesubie; 11-15-2021 at 02:14 PM. Reason: Added details |
02-18-2022, 10:28 PM | #419 |
Member#: 177837
South East
Vehicle:2011 GTI Candy White |
Rotella t4
03-07-2022, 02:30 PM | #420 | |
Member#: 528059
https://rogerclarkmotorsport.co.uk/s...-subaru-filter Last edited by Bumaa; 03-09-2022 at 11:00 AM. |
04-12-2022, 07:41 PM | #421 | |
Member#: 412885
South East
Vehicle:2006 Sti Blue |
10-07-2022, 12:38 AM | #422 |
Member#: 289598
Vehicle:2008 impreza wrx |
nice article
i see its old What happened to the Liqui Moly info? Having great results with 2043 10w40 anti friction on Ej25 2008 able to reach 27.8 mpg highway and only burn half qrt at 4000 miles. first bought car w 33K miles and @ 53k it Spun #4 using royal purple driving easily from work to home. Have now only used, Moble1, T6, Last edited by Speed Assault; 10-07-2022 at 12:45 AM. |
02-18-2023, 04:42 PM | #423 |
Member#: 123843
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Gear Oils
I would like gear oil opinions.
Weight: 75w-90 Brands: Motul AMSOil Schaeffer I use Motul, but I no longer have access to great pricing. I don't shop solely based on pricing. My car really just sits and if I do take it out, it's either to work in awful stop-and-go traffic, or it goes to Vermont where I can take it on a nice long ride up, there, and back. Thank you. |
02-24-2023, 11:51 AM | #424 | |
Member#: 767
https://lufteknic.myshopify.com/coll...ant=1105443540 |
03-07-2023, 10:09 AM | #425 | |
Member#: 510366
So in order of preference of brand i would try if Motul 300 Gear becomes difficult to find: VP Racing 75w90ls https://vpracingfuels.com/product/vp-hi-performance-full-syn-gl-5-sae-75w-90ls-gear-oil/ Torco RTF https://torcousa.com/products/racing-transmission-fluid Im mostly just praying France surrenders and starts sending us 300 gear again. Nevermind, it's in stock at the rain forest again, at almost double the cost of the others i find, may have to try the others at this price point.... Last edited by 19std; 05-11-2023 at 01:07 AM. |
