Welcome to the North American Subaru Impreza Owners Club Tuesday July 14, 2020
Old 06-02-2020, 02:43 PM   #1
shadowcompany
Member#: 189394
9994 Impreza LSX STi
AWD
Default The AWD LSX STi
Coming soon.
shadowcompany is offline   Reply With Quote
Old 06-03-2020, 02:02 PM   #2
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
Please let us know when you get the corner weights for that thing
Definitely shoe-horned that in there.
Old 06-03-2020, 03:35 PM   #3
shadowcompany
Member#: 189394
AWD
I can only tell you the car weighs less, makes more average power, and continues to climb in peak power past 7,000 rpm.
Most parts on the car are universal. It still uses an STi style clutch.
Old 06-03-2020, 05:28 PM   #4
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Would I be correct in assuming this is built for drag?
Turpid Porpoise is offline   Reply With Quote
Old 06-04-2020, 10:21 AM   #5
shadowcompany
Member#: 189394
AWD
No, this still uses the STi 6MT in the stock location/angle.
Old 06-04-2020, 12:22 PM   #6
Saabaru300
Member#: 334105
2005 Saab 9-2x Aero
Ver8 EJ207, 6MT, Red
Well it definitely isn't meant for handling anymore. Slightly higher center of gravity and all that weight even farther ahead of the front axle's. Cool that you are keeping AWD.
Saabaru300 is offline   Reply With Quote
Old 06-04-2020, 02:12 PM   #7
shadowcompany
Member#: 189394
AWD
It does push the design of the car, the stock front axles are set back relative to the fire wall.
EG33 swapped (they are about the same length as the LS with short pulleys) Impreza have been used in motorsport with success. EG33 is no longer a viable swap though and EZ30 suffers from the same issues as the EJ.
The AWD and steep angle of the driveline negates some of the downsides. Stock, Subaru understeer anyway.
There is not a big difference in weight between the EJ in turbo trim and the LS in this car.
Old 06-04-2020, 09:43 PM   #8
Homemade WRX
Member#: 33782
96 3MI Racing
I dig it. Should be fun.
Old 06-06-2020, 04:39 AM   #9
PseudoKirby
Member#: 203835
1998 2.5RS
the LS is over 450lbs
I weighed my fully dressed EJ207 at 303lbs
PseudoKirby is offline   Reply With Quote
Old 06-06-2020, 12:42 PM   #10
shadowcompany
Member#: 189394
AWD
Depends what you are weighing. Aluminum based LS blocks are ~100 lbs less than iron block. Components such as alternator, P/S pump, water pump, intake/exhaust manifolds, intercooler, turbocharger, clutch, and flywheel can change the weight.
Here is some info for various engine weights in different trims
https://forums.hybridz.org/topic/590...ts-definitive/
Some engine weights for V8 GM engines (includes LS)
LS aluminum long block dressed can weigh from 425-500+ lbs with GM parts,
LS aluminum block dressed with aftermarket parts (crank pulley, oil pan, alternator, water pump, etc.) can weigh 385-425 lbs.
LS aluminum long block weighs ~350lbs with oil pan but no accessories
LS aluminum short block weighs ~250lbs and that includes the cam and timing chain.
By comparison:
EJ257 DAVCS
Subaru turbo long block dressed with mid frame turbo and EWG ~350+ lbs
Subaru turbo long block dressed, stock ~325 lbs
Subaru turbo long block ~210 lbs
Subaru short block ~100 lbs
For reference a group 35 battery is 35-40lbs and a GTX3076R is ~30lbs. A front mount intercooler and pipes is roughly ~40-50lbs, stock bumper support on JDM cars is 12 lbs.
That is not a big difference when you double the amount of cylinders and more than double or triple the displacement, while keeping the whole Subaru AWD.
The EJ engine is very light in SOHC (1.8-2.5L) naturally aspirated versions, ~200-225 lbs fully dressed. The LS comes with very bulky accessories from GM but many aftermarket parts are available that considerably drop weight.
Old 06-14-2020, 12:30 AM   #11
sense of nature
Member#: 112759
2004 Stock OEM AsFu*
FoZZY SexyRP
Shut up & TAKE MY $$
sense of nature is offline   Reply With Quote
Old 07-03-2020, 04:49 PM   #12
WhiteZombie
Member#: 338863
PSM 05 WRX WGN 5MT
95 Caprice 6spd Track Rat
WhiteZombie is offline   Reply With Quote
Old 07-03-2020, 09:48 PM   #13
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
Please tell me that you aren't running a carb and coil-on plug...
Old 07-03-2020, 10:32 PM   #14
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
By comparison:
EJ257 DAVCS
So how much does YOUR completely dressed LS weigh?
Cool deal keeping the 6mt and awd.
Nice crank damper.
The torque curve has to be fun, no turbo lag.
Not "hating" on the swap, just don't act like you're improving on anything other than parts availability. I live in the south where LS engines are all over the place, and yes they do break in stock form. They have their quirks as well.
Old 07-03-2020, 11:06 PM   #15
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Sweet Christmas, sound clips please!!
JDMJNKY is offline   Reply With Quote
Old 07-05-2020, 02:23 PM   #16
PseudoKirby
Member#: 203835
1998 2.5RS
sorry mate I dont do random numbers from the internet
heres proof in the form of me personally weighing my V7 EJ207 fully dressed with flywheel
https://imgur.com/0CVJCXx
333
and here is someone elses proof in the form of an LS1 on a scale
https://imgur.com/q2eja6p
471 with no exhaust manifolds
Old 07-05-2020, 05:15 PM   #17
hi5.0
Member#: 340456
2013 Impreza
With more weight past the front wheels and higher up, this thing looks to be Audi-like with the power and handling characteristics when driven to the higher n/10ths. Just hope not of the iron block F/R longitudinal I5 variety. That being said, amazing job cramming that engine in there.
hi5.0 is offline   Reply With Quote
Old 07-12-2020, 06:40 PM   #18
Fino
Member#: 417685
'03 V7 STi, 4.44
Sonic Yellow
Just curious, why is an EG33 swap no longer viable? They can still be found for pretty cheap and can handle a good amount of power stock. Pretty much a direct bolt in as well. I was going to go with one of them if my EJ207 ever failed.
Fino is offline   Reply With Quote
