06-02-2020, 09:48 PM | #576 | |
Member#: 464265
One lesson as well (learned the hard way) wear eye protection when working with that swain coating... getting outer decorative layer flake in your eye is no fun... It is effective though at insulating...beats wrapping headers!
06-16-2021, 02:54 PM | #577 |
Member#: 198281
MAIC
Vehicle:2005 WRX/STi WRB of course |
Update:
The latest version of our Holy Header. Killer B Motorsport Holy Header Max VE The Killer B Motorsport Holy Header VE-Max was developed using state of the art CAD software, simulations, and testing, to determine optimal high power and RPM efficiency. High velocity merge collector into a stepped 2.5" secondary, the Holy Header VE-Max is for very high flow applications. Symmetrical 4-1 design maintains consistent and high velocity exhaust gas flow as RPMs rise. Large Secondary. The Holy Header Max was designed for higher flow rates with s stepped and large diameter secondary, 2.5". Cast Collector. Stronger than tubing, made from 347 (321) stainless. A true high velocity merge design is superior to fabricated tube collectors. Short Equal Length Primaries. The shortest possible length primaries you can have on an Equal Length header for improved transient response. Symmetrical Primary Design. All primaries have a similar tube length and bend geometry. Smooth Mandrel Bends. Large radius bends utilize a mandrel for smooth non-restrictive flow. Thick Walled 321 Stainless Steel Construction for Long Life. 321 is alloyed with titanium. 321 stainless steel has higher strength and toughness at elevated temperatures. Made in the USA and Killer B quality! Every Header setup is inspected, assembled and pressure tested before it ships to assure a leak free setup! Works with OEM EJ25 Oil Pans, and Killer B Motorsport Performance Aluminum Oil Pan. Fits All WRX & STi EJ Series Engines. Check it out here |
06-16-2021, 03:09 PM | #578 |
Member#: 107618
Tri-State
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
Curious about the merge with the uppipe. Wouldn't this larger secondary create issues when it merges with the uppipe considering pretty much all aftermarket uppipes have a 2 inch diameter (or whatever this diameter is). Will you offer a matching Uppipe eventually? Perhaps just like your regular header/uppipe combo (V-band)?
06-16-2021, 04:58 PM | #579 | |
Member#: 198281
MAIC
For less than ~600whp, our traditional Holy Header is still what we recommend for best performance per $. Last edited by KillerBMotorsport; 06-17-2021 at 01:58 PM. |
06-16-2021, 05:08 PM | #580 |
Member#: 508105
NWIC
Vehicle:Link G4X flex tuned 02' EJ205 20G 6MT wagon |
06-18-2021, 08:38 AM | #581 |
Member#: 122306
MWSOC
Vehicle:2002 Sti PTE 6262 Interlagos Blue 610/580 |
I'll have to try the new one. Ive always been more than happy with the original one.
Similar Threads | ||||
Killer B Motorsport Header - Prototype Testing | KillerBMotorsport | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 183 | 11-27-2012 09:10 AM |
Killer B Motorsport - HOLY HEADER / Up-Pipe Released! | KillerBMotorsport | Vendor Announcements | 52 | 03-17-2011 02:34 PM |
Killer B Motorsport HOLY HEADER Group Buy | KillerBMotorsport | Vendor 'Group Buy' Classifieds | 35 | 06-25-2010 02:18 PM |
Vf48 Turbo (18g killer?) w/ WRX Install Results | P&L Motorsports Inc. | Engine/Power/Exhaust | 5 | 03-25-2008 06:41 PM |
