08-25-2016, 03:24 PM | #1276 | |
Member#: 104922
Vehicle:2016 WRX |
08-25-2016, 03:26 PM | #1277 |
Member#: 6590
08-25-2016, 03:31 PM | #1278 |
Member#: 12368
Vehicle:2008 Infiniti G35X 2011 BMW X5 Diesel |
I have added single breakers. That's my limit.
08-25-2016, 03:34 PM | #1279 |
Member#: 66310
South East
Vehicle:2023 korean muscle |
electrician time? |
08-25-2016, 03:36 PM | #1280 |
Member#: 6590
Change the plug on the compressor and use the dryer outlet?
08-25-2016, 03:36 PM | #1281 |
Member#: 30342
Yes, looks like it. You'll be paying him to install a second box, too.
08-25-2016, 03:37 PM | #1282 |
Member#: 66310
South East
08-25-2016, 03:38 PM | #1283 |
Member#: 66310
South East
08-25-2016, 03:38 PM | #1284 |
Member#: 286686
BAIC
Vehicle:2003 WRX EJ207 VF36 White |
If there's any question, it's electrician time.
08-25-2016, 03:39 PM | #1285 |
Member#: 30342
08-25-2016, 03:40 PM | #1286 |
Member#: 30342
IIRC electricians aren't allowed to completely fill a box. They have to leave at least one space open.
Also, it's something you definitely don't want to do yourself, so if you're paying somebody, might as well get the subpanel now so then you can add circuits yourself in the future. |
08-25-2016, 03:47 PM | #1287 | |
Member#: 66310
South East
I figured this was an electricians job. Thanks everyone. |
08-25-2016, 03:50 PM | #1288 |
Member#: 190706
Vehicle:2023 Ford Maverick Alta Blue |
08-25-2016, 04:16 PM | #1289 |
Member#: 12368
Where is there space on that panel? I don't see any. I see unlabeled breakers, but no space.
08-25-2016, 04:17 PM | #1290 |
Member#: 190706
08-25-2016, 04:20 PM | #1291 |
Member#: 6590
08-25-2016, 04:23 PM | #1292 | |
Member#: 12368
Not really worried about 200A, unless he is running all of those major appliances at once. |
08-25-2016, 04:28 PM | #1293 | |
Member#: 6590
I noticed he already has some piggy-backed (small 2-pole) breaker in there. |
08-25-2016, 04:34 PM | #1294 |
Member#: 31519
Vehicle:2022 Oversized Load 2020 Lotus Evora GT |
Yeah, was thinking the easy win is doing those skinny doubles for that stack of kitchen appliance breakers and then stuff a sub-panel off the free space made.
08-25-2016, 04:45 PM | #1295 |
Member#: 141952
Vehicle:2023 M340i |
i need a bigger saw, this poor thing is getting a workout. had a tree cut down and told them to cut the stuff into pieces i can manage with my saw. should have told them i didnt have a 28" bar.
08-25-2016, 04:54 PM | #1296 | |||
Member#: 66310
South East
i have 200A service. So i need an electrician. The rest i have no idea what you are talking about.. i guess i need a 60A sub panel and do what exactly to get that? |
08-25-2016, 05:31 PM | #1297 |
Member#: 286686
BAIC
You have tons of service, and don't need a sub, but- as a former electrician- you should just have a pro do it. Is the load in the same room as the panel? It shouldn't be expensive, I'd use an offset 1/2" stub, a 4 11/16 box and plate, and three feet of thhn #10, and a suitable receptacle if this is a cord and plug installation, but of course I wouldn't do that as I'm currently unlicensed. They will have the two "mini" double 15a single pole breakers and the 25 or 30a double pole in their truck, although they may not have the right brand... (See below)
2k2- Electricians will leave open breakers for a number of reasons, the most common being that somebody smashed too many blanks off the panel cover and now they need to fill the hole, and don't have panel cover blanks. Iirc, it's legal to leave them in but they had to be labeled. However, OP, your panel has already lost its UL approval: like breakers with like panels- breakers are approved with their panels, and you have a mix of cutler and Siemens stuff. Cutler, ge, Murray, Siemens and a few others will fit (and are oft rumored to be "made in the same factory") but technically tank the UL rating, which means it's not at code. Nobody ever cares but I thought you'd want to know at least for trivia sake. Panels bite hard, I luckily don't know first hand, but there's no greater opportunity for severe, debilitating electrical shock in the home than messing about in the panel. Please call the pros! (Do you have a family or roomates?) |
08-25-2016, 05:37 PM | #1298 |
Member#: 6590
Oh, so this is how it feels when people talk about computers to me.
Your compressor needs a 230/240volt circuit with 30 amp breaker. Do you have any other items you want to power? Is it in a shop or garage? The sub panel is an easy way to expand your current one. You run a wire from the main panel to another location (shed/garage) then install the sub panel which will have a handful of breaker in it. How much power the sub panel can handle is limited by the available power left over in your main panel and the size wire you pull. Most people will do a 60amp sub panel with 4-6 breakers in it to power tools, compressor, outlets. It's common with sheds and garages because then you're not running 4-6 wires out to the shed, just 1...also, it puts the breakers closer to the point of use which is safer and more convenient. Last edited by Grap; 08-25-2016 at 06:14 PM. |
08-25-2016, 06:26 PM | #1299 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
Meh, that's an easy job. I would do it.
You can move the dual 15 on the bottom right to the bottom left. Then you would have two adjacent spots for the double 30 you need (looks like the breaker for the dryer). Or, as others have suggested, install a double 60 and put a sub in the garage. Just sucks pulling heavy gauge cable and/or installing conduit (not sure if necessary). |
08-27-2016, 04:46 PM | #1300 |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
Got my first estimate for my garage addition. It was not realistic for a garage. Guessing it was a non bid.
