06-03-2016, 02:20 PM | #76 | |
Member#: 6590
06-03-2016, 02:45 PM | #77 |
Member#: 101091
NWIC
We need to turn that guy into the traveling OT concrete specialist. I have a paver patio on the docket for later this summer, but I would rather pay him to get it done for me
06-03-2016, 03:28 PM | #78 | |
Member#: 93205
06-03-2016, 03:44 PM | #79 |
Member#: 250084
Vehicle:2019 STI Pure red |
Converting my kids bed from a toddler bed to a full sized bed with a conversion kit. The kit came with 4 slats that span from side to side. The mattress just lays on top of the slats. (Don't want to add a box spring it would make the bed too high). It looks like the kid should have had 6 slats instead of 4, however when someone lays on the bed when you look under it you can see the slats sag right down the middle. Not sure if the extra 2 would help. What would be the best way to prevent the bed from sagging right down the middle?
06-03-2016, 04:44 PM | #80 | |
Member#: 85327
RMIC
Vehicle:1964 Miata Hairdresser Red |
http://www.mattressfirm.com/2_bunkie...-p211-211.html |
06-03-2016, 04:57 PM | #81 | |
Member#: 15571
Vehicle:2006 06 Forester XT Silver |
06-03-2016, 06:05 PM | #82 |
Member#: 137902
Vehicle:---- living life to the least!! |
A piece of OSB? the kid probably won't mind it being a little stiff, especially if the mattress is thick enough
06-03-2016, 06:59 PM | #83 |
Member#: 111343
Received a quote for 2, 3 ton - 14 seer units and gas furnace for $8300 installed. Includes updated WiFi capable thermostats. I passed on the heat pump option which would have been $12k total, because we're planning to move in the next couple years.
Units to be installed are Goodman. The same brand that's been fairly trouble free for the last 20 years in the house. |
06-03-2016, 07:10 PM | #84 | |
Member#: 242205
Vehicle:2009 I don't know Dirt |
06-03-2016, 07:15 PM | #85 | |
Member#: 15571
06-03-2016, 07:24 PM | #86 |
Member#: 111343
Trane, Lennox, and Carrier are all more well respected brands. But at a significant cost increase. Our goal is to move in 2 years. I don't think I'll get a return on the up front investment in the more respected brands.
06-03-2016, 07:28 PM | #87 |
Member#: 242205
Have a family member who sold appliances/parts. They carried Goodman and I was considering replacing a/c at the time. He steered me away from Goodman which was remarkable as he'd sell his own mother to make a buck.
06-03-2016, 07:49 PM | #88 |
Member#: 15571
If you're definitely moving soon then go with the cheapest thing that will get you there.
06-03-2016, 07:55 PM | #89 |
Member#: 33287
Vehicle:RIP Nik I will always miss you |
06-03-2016, 08:40 PM | #90 | |
Member#: 58504
South East
Vehicle:2004 STi Aspen White / Silver |
House was 89F this afternoon when they turned the system on. Afternoon temps were 95F here. Took about 5 hrs for it to pull down to 74F (which is lower than the 77F we usually keep it at). |
06-03-2016, 09:30 PM | #91 |
Member#: 15571
Wow is the learning curve for geothermal stuff is steep. I've been down this rabbit hole for 2 full days. I got a proposal from a place so I'm dissecting it and looking at each piece of equipment, and the loop field proposal and everything. The more I read the more confused I am. I talked to a friend of a friend of mine who has had geo for 9 years and he had some critiques for the proposal so I'm researching all that. But his system has been awesome and dirt cheap to run and it gives me confidence that maybe mine will be too if I go that route. But damn the information overload...
06-03-2016, 09:51 PM | #92 |
Member#: 250084
Looking for a 1080p or higher POE camera system. I was looking at this:
http://www.amazon.com/dp/B01C6DJPX6/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2YIWX0IXL76T1&coliid=I1LXW56Z0SLUJD&psc=1 What say ye? Any other recommendations? 4 Cameras should do it. |
06-03-2016, 09:51 PM | #93 |
Member#: 250084
06-03-2016, 09:55 PM | #94 | |
Member#: 250084
Yep, her new mattress is more comfortable than ours :/ |
06-04-2016, 12:53 AM | #95 | |
Worst Mod Ever
Moderator Member#: 369
SWIC
Vehicle:19 CTS-V, 18 XC90 17 GTI |
http://www.amazon.com/3-0-Megapixel-8-Channel-Weatherproof-Bullet-AMNV3M8-4B/dp/B013VS7TQK/ref=sr_1_6?s=photo&ie=UTF8&qid=1465015915&sr=1-6&keywords=qcam |
06-04-2016, 08:51 AM | #96 |
Member#: 250084
Are there any wireless systems that have the same quality of the POE systems? There are a few runs that i am dreading with the ethernet cable.
06-04-2016, 09:12 AM | #97 |
Member#: 329599
Vehicle:2004 STI Aspen White 2015 Jetta TDI |
So the AC system fiasco turned out to be a clogged filter that caused the system to crank up the effort and just over filled the drain pan. So now we just have to address the ceiling damage. Blessing in disguise here: I can get rid of the ugly light fixture in the hallway and replace it with a recessed light fitting and led bulb! Yay!
06-04-2016, 09:33 AM | #98 | |
Member#: 35985
NESIC
Vehicle:20 Supra 16 Jeep Wrangler Unltd. |
I would disagree. i was quoted an additional 1k to upgrade from the Goodman to a Carrier system on a new system we were getting quoted. IMO it was worth it. 2 2.5 ton units 16 SEER units, so basically 500$ extra for each unit. |
06-04-2016, 01:55 PM | #99 |
Member#: 58504
South East
If it was only $1k to upgrade from Goodman to Carrier for two units, that was definitely worth it, and well under the normal cost delta.
Of course, now that Carrier moved production to Mexico, guess they can be more cost competitive. |
06-04-2016, 02:08 PM | #100 |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
