02-11-2021, 09:22 AM | #7901 |
Member#: 126425
SWIC
Vehicle:2021 Forester Sport Grey |
02-11-2021, 09:34 AM | #7902 | |
Member#: 129922
RMIC
Vehicle:2013 Wrangler |
The only thing I think the Rubi gets that makes a difference is the lower ratio TCase and 44 up front. But why not get a sport for 10k cheaper. That 10k can lift the Jeep, swap the front axle, get a rear locker, and the protection you need. Dollar for dollar I don’t know if the Rubis are really worth it on the used market. |
02-11-2021, 10:29 AM | #7903 |
Member#: 129922
RMIC
You're really going to enjoy those kings you ordered for your goals. The "built" 5th gen I wheeled with had them on there. I got a chance to run it up the hill by the mines at Pickle Gulch. Such a smooth ride. It'll keep the fam happy out on the trails.
02-11-2021, 01:12 PM | #7904 | |
Member#: 11671
SWIC
02-11-2021, 01:20 PM | #7905 | |
Member#: 65831
South East
Vehicle:91 Miata. Hey you can f* short girls in one |
If you plan on going ANY bigger than this, you are going to need to re-gear, so the better axle ratio goes out the door, you MUST lift, so the good suspension bits go out the door... I planned on going bigger, but I wanted the good suspension from the get-go, so I ordered the Willys Wheeler package. This is the Rubicon springs/shocks, but the Sport with Towing package and added rear clutch type LSD for everything else. Cheapest way to have a setup that I wouldn't get annoyed with while I figured out exactly what lift/tires/upgrades I wanted to do. |
02-11-2021, 01:23 PM | #7906 |
Member#: 129922
RMIC
The guy built it with the intent to wheel it. That said the jeep had better traction and articulation across the board. Obstacles that the 4runner struggled on and needed lockers we not difficult tasks for the XJ. One of the girls in the group brought her BFs XJ out without him so none of us wanted to break it or beat on it.
02-11-2021, 01:26 PM | #7907 | |
Member#: 129922
RMIC
That makes total sense. They are legos and there is no wrong answer on which way to go. I prefer the look of the OEM fenders so if I ever go 35's it will need a lift. |
02-11-2021, 03:00 PM | #7908 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
The Willys Wheeler had the option to add a rear locker. I've never actually seen one with the locker, but it's something worth keeping in the back of your mind. Find one in Clem's Used Cars where they have no idea what it is and pick it up for the price of a sport.
My JKU sport is lifted 2 1/2 inches (measured) and I ordered it with the rear LSD on 295-70 Cepek Extremes. I don't care about gears or the problematic front sway disconnect of the rubi. Just the lockers and better front axle setup. |
02-11-2021, 03:33 PM | #7909 |
Member#: 35985
NESIC
Vehicle:20 Supra 16 Jeep Wrangler Unltd. |
I'll just drop this here. THis has probably been posted....but it's worth watching again....
02-11-2021, 03:40 PM | #7910 |
Member#: 65831
South East
Well, no, it wasn't available with a locker. It was standard with the LSD.
02-11-2021, 05:38 PM | #7911 | |
Member#: 68346
NESIC
Vehicle:2004 Tacoma 2015 GX460 |
https://www.wranglerforum.com/thread...-help.2162657/ |
02-14-2021, 03:30 PM | #7912 | ||
Member#: 142559
RMIC
Vehicle:'05 Forester XTi Broyotas:4runner & Tacoma |
My Taco is an '07 but I run OEM Goodyears off an '18 TRD. As far as skills go we were the same. My advantage was the short wheel base on my Regular Cab. My truck is also manual, I personally think that is better for off-roading. I love this Truck, I previously had a 2011 TRD Off Road 4 door, it was a great truck but I high centered and got stock a few times. This little Reg Cab beater is a mother ****er, it doesn't get stuck, put it in 4 low and first gear...it goes anywhere. Nearly 300k miles on it too and runs perfect still. No offense, but you won't see that kind of mileage out of a modern jeep. The old inline 6's? Yes. My little bastard: Quote:
His Truck: Last edited by SkiWrex; 02-14-2021 at 03:47 PM. |
02-14-2021, 03:46 PM | #7913 |
Member#: 142559
RMIC
Double Post
02-17-2021, 04:34 PM | #7914 | |
Member#: 11671
SWIC
02-18-2021, 11:50 AM | #7915 |
Member#: 499784
Vehicle:2017 WRX Crystal White Pearl |
Been wondering since a lot of the used 4.0 wranglers I see are pricey or have a lot of mileage, of what people would choose between an older 4 cylinder Jeep vs a Suzuki samurai (or similar)?
02-18-2021, 05:36 PM | #7916 |
Member#: 7956
W. Canada
Vehicle:2020 JLU Rubicon 2021 VW GTI |
I had a 4cyl YJ years ago (holly crap I'm old, it was actually 20 years ago). It was horrible, I ended up swapping a 4.0L into it. Which also involved a new transmission, t-case input shaft, wiring etc. Save yourself the aggravation and wait and find a decent 4.0L.
02-18-2021, 06:12 PM | #7917 |
Add Lightness
NESIC
There were a number of 4 cylinders in TJ Wranglers. I don't know the earlier ones, but drove one of the later ones. They made some change..I don't remember. But it had quite a bit of power. At the time, I was considering either a used 4.0 or a new 4 cylinder. I bought a used one.
In the rust belt, stick with only a late...like 05 or 06. The early TJs didn't have holes in the frame to allow crap to exit and around me, they all rusted like crazy. Like Tacoma kinda frame replacement rusted. If you're going to upgrade the control arms, you'll be ok, but I've looked at the stock ones and holy toothpick parts, batman. There are some years with head issues with the 4.0. One of my son's friends is a jeep expert and rattled through the years one time we were visiting. I don't remember which years were good/bad. There's a recent South Main Auto vid where he's looking at a Cherokee with high miles that's eating coolant. He found a huge crack in the head with the little camera thingy. As bullet proof as the 4.0 is known for, they're not without potential issues (as no jeep is). My 4.0 was fine, but I only had it a couple years. I did also have a YJ with a 6 and that thing never got more than single digit mpg. With what felt like about 60 hp and a 45 mph max speed. |
02-18-2021, 06:18 PM | #7918 |
Member#: 499784
Thanks for the info, I've been searching alot for 91+ wranglers with the 4.0 but man they are usually really pricey or extremely high mileage. I'm lucky im not in the rust belt for them however.
To my limited understanding they are Fuel Injection after 91, and I never worked on car with a carburetor so I was steering clear |
03-01-2021, 01:14 PM | #7919 |
Member#: 54935
NWIC
I bought a TJ Wrangler. It is my fifth Jeep but I never lifted my previous TJ, just the JK's I owned. I am thinking of a 2" suspension with maybe a 1" body lift so I could possibly do a belly up kit. I only need 31-32 inch tires for most of the trails around here.I will have my wife and daughter with me so I am not going to be going to crazy.
That being said what lift kits should I be looking at? I ran a Teraflex on my JK and liked it. Will I need a slip yoke eliminator? At what point should I be looking at new control arms? This is not a daily driver but I don't want to make ride crappy or handle poorly. |
03-01-2021, 03:38 PM | #7920 | |
Member#: 65831
South East
03-02-2021, 11:45 AM | #7921 |
Member#: 11671
SWIC
Here's the new project:
I'm going to get her mechanically back into shape before I start modding. I don't plan on anything too crazy, 3.5" lift, and some better wheels and tires. Maybe some steel bumpers because the stock ones are a little rough. Should be a fun little desert Jeep. |
03-02-2021, 12:36 PM | #7922 |
Member#: 34390
South East
Vehicle:2002 |
Blast from the past!
Here is my current daily/rock crawler: 2000 TJ 4.0 https://revkit.com/tonka-toy-tj |
03-02-2021, 03:35 PM | #7923 |
Member#: 128484
International
Vehicle:2006 EDM WRX STI WRB |
03-19-2021, 12:37 PM | #7924 |
Member#: 128484
International
03-19-2021, 01:16 PM | #7925 |
Member#: 11671
SWIC
Yeah, the genius left it in 4 low and in gear before he towed it. They did the math and the engine would have been spinning at 55,000 RPM before it detonated. On a brand new $50k Jeep.
with all the gay and straight threads | [27] | Off-Topic | 27 | 05-08-2013 06:31 PM |
the Official Rally/Off-Road thread? | Longitude | Member's Car Gallery | 178 | 09-05-2006 05:39 PM |
Why all the bestiality and dehydration threads today??? | Grap | Off-Topic | 15 | 01-11-2006 03:55 PM |
this site is dwindling (aka: The piss and moan thread v.2) | stevedood | Bay Area Impreza Club Forum -- BAIC | 59 | 04-01-2004 12:38 AM |
A lazy monday thread...A continuation of the saturday and sunday thread | DoctorNick | Mid West Subaru Owners Club Forum -- MWSOC | 9 | 09-10-2002 08:17 AM |
