Welcome to the North American Subaru Impreza Owners Club Thursday April 22, 2021
Old 08-29-2019, 01:08 PM   #10001
Reflex-Arc
Lord of the Gif
Member#: 1703
2013 Fiat 500 Abarth
Bianco
Have you pulled the AVR out of the equation and gone source direct to confirm it's the cable?
Reflex-Arc is offline   Reply With Quote
Old 08-29-2019, 01:09 PM   #10002
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
Originally Posted by ForceFed4 View Post
Probably cheaper and a lot less trouble to just replace the suspect cables. If you want to be really sure, get the Monoprice slim Certified Premium dealies:
https://www.monoprice.com/product?p_id=24187
Cable price is irrelevant. That certification with the holographic tag is not, and is a real industry standard that is proof the cables are up to full 4K HDR bandwidth. I've also had good luck with the Amazon Basics High Speed HDMI cables though they are technically not certified premium:
https://www.amazon.com/dp/B014I8SSD0/
btw, the "Certified Premium" process doesn't certify anything over 7.5M
Akirasoft is offline   Reply With Quote
Old 08-29-2019, 01:10 PM   #10003
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
Yes, and things work more consistently when going direct hence why I think the AVR is introducing just enough signal loss to make things fail.
Anthem themselves are unwilling to admit anything is wrong with the AVR and just blame the cables.
Old 08-29-2019, 01:20 PM   #10004
Reflex-Arc
Lord of the Gif
Member#: 1703
Bianco
I'm guessing you've also tried running the same length of cable outside of the conduit to rule that out?
Old 08-29-2019, 01:41 PM   #10005
ForceFed4
Member#: 7370
SGM
My bad, I completely missed that your run is 20+ feet through conduit. In that case, I don't have many suggestions outside of what you're already trying.
ForceFed4 is offline   Reply With Quote
Old 08-29-2019, 02:36 PM   #10006
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
in the beginning, no, because I had bought into the statements that cable was cable. After learning that cable isn't cable, I had to go through 4 more cables before finding one that would work at all (i.e. even transmit a signal). The current cable I'm using worked before I ran it through the conduit however I did not run it for days. The problem is intermittent (which is AWESOME for troubleshooting.)
One of the reasons why I'd like to have access to a cable tester is that they actually pump varying capacities of data through a cable and let you know if it fails at a certain data rate. The tester is too expensive to buy for a one time use though (like $350-500)
Old 08-29-2019, 02:40 PM   #10007
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
I should mention that the cable run length is totally my fault as I actually installed the conduit. I could have probably came up with routing for it that was a bit shorter but I wanted to keep the bends nice and easy to make installation easier. I also would have used different conduit (I used the carlon flexible raceway stuff and all the ridges inside make it a pain in the ass.)
The TV is only 8 feet away from the AV rack but because of the routing through the walls and behind the fireplace it ends up being longer.
Old 08-29-2019, 02:41 PM   #10008
thechickencow
Member#: 16840
17 4Runner
This is a crazy idea but what would stop you from cutting a HDMI cable and splicing in better wires for the length?
thechickencow is offline   Reply With Quote
Old 08-29-2019, 02:42 PM   #10009
ptirmal
Member#: 82243
13' BMW X3 35i
It does sound like an interference/handshake issue .
I have a 50ft run of this monoprice lux cable https://www.monoprice.com/product?p_...SABEgJqWPD_BwE.
I picked it up when I ran the wiring for my 1080p TV. I was dreading upgrading to 4k because I wasn't sure it would handle it as I would sometimes get a "no signal" message from the TV but figured it was more the receiver (old Onkyo sr606).
When I upgraded to my Denon x3500h there were pretty much no signal loss messages. And when I upgraded to my 4k TV it passes it along fine.
I would trouble shoot as mentioned above without the receiver and then without the conduit if needed . I'm thinking it's the receiver, have you checked to see if you need to set the output to anything special for 4k HDR? I'm pretty sure there was a setting in my Denon for that.
ptirmal is offline   Reply With Quote
Old 08-29-2019, 02:56 PM   #10010
Akirasoft
Member#: 2973
2018 Camaro ZL1 1LE
Red
I ran through the gamut with Anthem support and they were emphatic that it was a cable issue. The Anthem by design doesn't touch the video passing through it. That being said there can be signal loss anytime you have a connector involved, if the signal is barely within spec to begin with adding two connectors (in + out) via the AVR could be the straw that broke the camel's back.
Old 08-31-2019, 04:42 PM   #10011
thechickencow
Member#: 16840
17 4Runner
Default The Home Audio/Video Thread
Any idea what these might be for? Moving in a new house, all the 7-speaker is wired (different wired than this), these come out of a wall but I canít figure out where they lead to.
Hereís the room as it sits right now:
Old 08-31-2019, 05:56 PM   #10012
PARANOID56
Member#: 22035
2014 Brocoma DCab
71 FJ40, 13 DRZ400SM
speakers elsewhere in the house or outside.
PARANOID56 is offline   Reply With Quote
Old 08-31-2019, 06:13 PM   #10013
shikataganai
Member#: 92634
Hook up a receiver to those channels and play something, see from whence the noise emanates.
shikataganai is online now   Reply With Quote
Old 09-01-2019, 05:57 AM   #10014
vapore0n
Member#: 21356
2017 Subaru Corolla
STI Limited SE-R Type (R)
are those power cables?
are the ends crushed or melted?
If they are speakers, be sure to know what they are connected too.
It appears that multiple speakers are connected to the same channel, thus this could fry your amp due to the current draw
vapore0n is offline   Reply With Quote
Old 09-01-2019, 09:56 AM   #10015
thechickencow
Member#: 16840
17 4Runner
I have to look around but the only other speakers I see in the house is the upstairs built in 5.1 setup and that has its own wires. Hmmm...
Old 09-01-2019, 11:44 AM   #10016
NutBucket
Member#: 90804
2021 Ascent
2012 Accord
I'm going with crushed. Low impedance isn't an issue as long as you're not pushing the amp hard.
NutBucket is offline   Reply With Quote
Old 09-01-2019, 12:26 PM   #10017
97OBLimited
Member#: 224432
1997 Outback Limited
2012 DGM Impreza Hatch
Quick subwoofer question: when tuning a sub, do you make adjustments at the plate Amp of the sub or through the receiver? Max one and use the other as adjustment or what? It sounds good but I feel like it could sound better.
97OBLimited is offline   Reply With Quote
Old 09-01-2019, 02:13 PM   #10018
thechickencow
Member#: 16840
17 4Runner
They are just crushed.
Old 09-01-2019, 07:52 PM   #10019
thechickencow
Member#: 16840
17 4Runner
Pretty excited about this setup here. Sounds pretty good other than the front sound being above the TV a bit. Doesnít seem to be a big issue.
The TV is a 65Ē Samsung from a couple years ago, I think itíll work now but I do think Iíll upgrade the receiver (itís a 18yo Yamaha which has served me well but itís time).
Hooked up my gaming PC which is more of a plex server lately anyway and I think thatíll do the trick for streaming football this fall.
I need a decent wireless mouse/keyboard and eventually Iíd like to upgrade my sub setup once everything else is set.
Old 09-01-2019, 08:44 PM   #10020
shikataganai
Member#: 92634
Instead of wireless I went with a powered 30 foot USB extension cable run by the wall behind one couch, and then a USB hub for a standard wired USB mouse and keyboard to use on the couch on a lapdesk thing.
Old 09-02-2019, 12:38 AM   #10021
thechickencow
Member#: 16840
17 4Runner
Ordered a Yamaha rx-v685 tonight, was cheap on Slickdeals. Will be nice to have HDMI switching and a working volume knob.
Old Yamaha will be the new garage receiver I think.
Old 09-02-2019, 07:10 AM   #10022
ptirmal
Member#: 82243
13' BMW X3 35i
It's 2019, wireless peripherals are the way to go.
Old 09-02-2019, 04:46 PM   #10023
shikataganai
Member#: 92634
Why? I never will have to change a battery in my setup.
Old 09-02-2019, 04:50 PM   #10024
ptirmal
Member#: 82243
13' BMW X3 35i
Looks ghetto having wires dangling across your room, I couldn't live with myself. Also, tripping hazard, occasional tugging feel etc.
Old 09-02-2019, 04:53 PM   #10025
shikataganai
Member#: 92634
Wires are all behind a couch that sits 90 degrees from the TV (and which is apparently a permanent storage area for hundreds of stuffed animals now). Nothing is visible save for the cables immediately attached to the keyboard and mouse themselves, and thatís just not that big of a deal, IMO.
The official Post pics of your Home Audio/Video setup? V2.0 GRUMPY514 Off-Topic 74 07-30-2008 09:50 AM
VA: Home Audio/Video/Game AspenWhite Non-Subaru Stuff 5 03-06-2007 09:43 AM
WRX parts, home Audio/Video stuff, and more... NicFunkadelic NESIC Private Classifieds 6 02-15-2007 10:38 AM
Home audio/video wiring gurus, need a bit of help. trail*of*dead Off-Topic 16 12-23-2006 02:25 AM
Home audio/video goodies for sale! Tivo! Replay! Pronto! BiggSean Private 'For Sale' Classifieds 7 02-26-2006 11:15 PM
