Brakes & Suspension Forum sponsored by The Tire Rack |
05-07-2022, 02:32 PM | #1 |
Member#: 97984
Vehicle:1999 2.5RS WRB |
2015+ Superpro Double offset vs Whiteline Anti-Lift bushings
Fellas,
I'm looking for advice on which front lower control arm bushing to get for a 2015 WRX in order to maximize front caster. I'm considering the Whiteline Anti-lift bushing: https://subimods.com/collections/201...-2015-2019-wrx And the superpro double offset bushing: https://subimods.com/collections/201...-2015-2019-sti Do both add the same amount of caster? Any difference in durability or NVH? Do they both allow the same amount of suspension articulation? Thanks!
05-08-2022, 09:35 AM | #2 |
Member#: 446364
BAIC
Vehicle:'17 STI LMT '08 LGT DGM / QSM |
Greetings,
Elastomer is better than polyurethane from a durability standpoint. Better is cold weather too. The Whiteline kit is also more adjustable. Get the Whiteline. |
05-10-2022, 09:50 PM | #3 |
Member#: 97984
Does the whiteline have more articulation than the superpro? It looks like it has a spherical bearing held in place with, as you said, elastomer.
05-11-2022, 07:15 PM | #4 |
Member#: 107618
Vehicle:06 GG WRX / 09 FXT @florencedestinedfxt |
I have seen the Superpro version for the 11-14 STI arms, which is almost the same except the passthrough is slightly shorter. I also have the WL version in hand. Both are bearings held in elastomer. The WL version is sealed (based on my memory) versus the Superpro. It's not that the Superpro isn't sealed but it's design would allow contaminates to enter more easily. Overall, I would say that the WL version is better designed and allows much more adjustment with the various spacers and spacer placement.
I would not worry too much about articulation unless you're lifted. |
