04-05-2022, 03:27 AM | #1 |
Member#: 528702
EJ253 head rebuild
I have a trusted automotive machine shop who will P&P my heads, vac&pressure test them, surface them for head gaskets and do a full valve job for $1,000 if I supply parts.
It’s an EJ253 SOHC 5MT N/A. I need to get some strong, oversized valves, stronger springs and rockers and valve guides. I’ve been looking for days but everybody said theirs are the best. Was also thinking about doing cams at the same time if I can find affordable ones that aren’t super gnarly. It’s my DD, I need decent MPG, and good reliability. Is there anything else I need to supply for a rebuild? and what would my best options be for valve size (oversized), strong valves (intake & exhaust), how strong should the springs be and how should I chose rockers and valve guides. Is there an option to buy 2 affordable cams that aren’t super gnarly since it’s my DD? And is there anything I’m forgetting? This is my first Subaru rodeo and I love the car, want it to last me the next 10+ years. Thank you for any legit advice that doesn’t imply that I haven’t been researching because that’s all I do in my free time is look for parts I need for the head rebuilds. Thank you all from a brand new Subaru fanatic
04-05-2022, 08:20 AM | #2 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
If you are putting in oversized valves you will need over size valve seats - does the machine shop price include installing OS valves/seats?
My best advice is don't waste money on heavy mods on an N/A engine. Gains are minimal. Spend that money on updating the suspension, dealing with any rust, and maintenance so the car will give you another 10 years reliable service. Buy a project WRX/STI if you want to play. My grandson has an '02 RS that was updated with better suspension and full poly bushings. Fun as heck to drive and isn't strong enough to get you in trouble. I ALMOST like driving the RS better than his dad's WRX we just finished building around an engine we PB Blastered out of an old Grassroots Motorsports rust-bucket build. |
04-05-2022, 03:39 PM | #3 | |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
So, I'll save you some time and money. You don't need to change out the valves. You don't need to change out the rockers, and there are no options other than stock ones, anyway. You don't need to change out your springs, particularly if you aren't even certain if you're going to change out the cams, and if you do change the cams, you don't want anything "super gnarly". With all of that aside, you absolutely do want to swap out the cams. I'm sure in all of researching you've read about Delta Cam, Web Cam, Kelford, Brian Crower, etc. I think Delta and Web may be the only ones with off-the-shelf options for the SOHC heads. You'll find plenty of testimonials for the Delta cams here in this forum or over on RS25.com. Call and talk to them about what you want to do and which of their grinds is best for you. |
04-11-2022, 05:28 PM | #4 |
Member#: 13530
NWIC
Vehicle:EA63 , EA81T, EJ20G, EJ205 |
Give these folks a call and see what they recommend: https://www.facebook.com/NASPerformance/
04-30-2022, 01:40 PM | #5 | |
Member#: 528702
