03-29-2022, 01:55 AM | #1 |
Member#: 510671
SCIC
Vehicle:2006 WRX Gray |
Hesitation when starting to accelerate, runs fine at full throttle
My naturally aspirated 2002 USDM Impreza hesitates under acceleration - unless I accelerate hard, then it responds well. I presume maybe it is having trouble under high load in closed loop, but handling open loop just fine ? Car is on a new long block, but has 344k miles on it so many sensors may be very old. What can I check for ? My first suspect is the oxygen sensor.
03-29-2022, 01:32 PM | #2 |
Member#: 515308
My first thought is fpr, is the vac line hooked up?
03-31-2022, 08:51 AM | #3 |
Member#: 529469
05-20-2022, 01:26 AM | #4 |
Member#: 510671
SCIC
It is connected. I only have codes for a catalyst fault. I will check for vacuum leaks Last edited by sebastian323; 05-20-2022 at 01:36 AM. |
05-26-2022, 01:23 AM | #5 |
Member#: 520235
Check the valve clearance if you have a feeler gauge handy.
