11-29-2021, 11:08 PM | #1 |
Member#: 520461
Vehicle:2004 WRX Silver |
MAF volage low+Overboost? [LOGS]
2001 wrx
jdm ej205 engine (avcs disabled) k&n short ram intake 3inch catless downpipe 3RD GEAR WOT LOG: https://drive.google.com/file/d/102R...ew?usp=sharing Im getting an etune and my tuner has noticed a few things wrong with my car. 1. My maf voltage is reading ~3.7v at 6000 rpm wot (lower than expected) 2. Im overboosting to 18psi I LIVE IN TORONTO ~100M ABOVE SEA LEVEL Ive verified my turbo is a stock td04 by the serial number and bought a brand new MAF sensor to make sure the old one wasnt failing. I also did a vacumm leak test and it was fine, i idle at around 19hg/in. Ive been trying to find the solution for a while but it isnt making sense to me. if im overboosting by so much shouldnt my maf voltage be near maximum too?
11-30-2021, 10:54 AM | #2 | |
Member#: 385256
Vehicle:'18 Giulia QV '21 Giulia Q4 |
Who is your tuner?
First, try putting the stock intake on and see if that corrects the problem. If it doesnt then you need to get a wide band O2 sensor and gauge and check that the MAF Voltage is correct by comparing the commanded fueling to the supplied fueling. If they are about the same then you can conclude that the MAF Reading (and there fore sensor) is OK. If the readings are different then there is a problem with the airflow metering. First step is to put the stock intake on and confirm thats not the problem. If that doesnt work, clean the MAF sensor and recheck readings. If that doesnt work then get a known working MAF sensor or a new one from Subaru (it CANNOT be a cheap off brand MAF sensor because it will not produce the correct readings). If the MAF checks out then start looking for an issue with the ECU or the intake. regarding this Quote:
https://www.miataturbo.net/engine-pe.../#&gid=1&pid=2 18PSI is about 2.2 pressure ratio. and your maf rate is about 125g/s which is roughly .10 m3/s. The turbo is operating slightly outside of its efficiency range, but its not a part of the compressor map that doesnt make sense. So in other words, its entirely possible its producing that MAF rate at that boost level Last edited by 86Dreams; 11-30-2021 at 03:34 PM. |
11-30-2021, 04:54 PM | #3 |
Member#: 515308
Td04 @18psi, can’t be more than 23lb/min? Shouldn’t need too much MAF voltage for that. Pro tune with a td04 may be a bit much tho
01-06-2022, 11:18 AM | #4 |
Member#: 394646
Vehicle:2003 WRX Flex Fuel Pv=nRT |
check your turbo inlet/intake charge system for boost leak/smoke test.
a leak between the maf and turbo would provide plenty of unmetered air. |
01-06-2022, 11:19 AM | #5 |
Member#: 394646
01-30-2022, 10:31 AM | #6 |
Member#: 528615
Vehicle:2004 Wrx Sti Red |
I have a TD04HL-15t. If you hold down the throttle on a long pull it’ll reach 18 or like 18.5. It’s on a stage 2 tune, off the shelf tune.
01-30-2022, 10:33 AM | #7 |
Member#: 528615
I have a TD04HL-15t, on my jdm ej205. Was on the car when I bought it. It will boost to 18 or 18.5 on a long (3K-7.5K rpm) pull. It’s on an off the shelf stage 2 tune. Maybe you just have the same thing? I haven’t had too many issues with it
