02-14-2022, 04:58 AM | #1 |
Member#: 213393
Vehicle:2003 WRX Tomei Powered |
2014 JDM STi GVB spec C G25-660/TD05H Result 380whp
Event: Dyno Pull
Location: YongIn GHP / Seoul, S. Korea Ambient Temp: ~15 degC. Elevation: Unknown Weather: Dry and Nice. Tires: Michelin, Pilot Sport 4, 235/40/18r Car: 2014 Impreza JDM STI spec C GVB Tuner: PFP Dyno Info: DynoJet Transmission: 2014 JDM STi Transmission (These are short ratio 6MT like early USDM 04-06 but with final drive of 3.9 + 1.1 Transfer ratio) Gear: 4th Peak HP at RPM: 385whp @ 6200rpm STD Corrected Peak Torque at RPM: 45.8 kg/m @ 4300rpm STD Corrected Baseline hp/tq: 240whp as RON 97 octane 2017 USDM VAB STi stock Target Boost: 1.45 Bar (21psi) Target AFR: 11.6 Fuel: RON 99 octane Engine/Power Modifications: Stock Ver 10 EJ207, Kinugawa G25-660/TD05H Ball bearing single scroll bolt-on Turbo with 8CM exhaust housing, Tomei Unequal length header, Custom downpipe w/ No catalyzer, Fujitsubo AUTHERIZE-RM + Custom enlarged tipm External wastegate setup + 45mm Turbosmart external wastegate, ID1050x Cobb Injectors, Cobb 265lph fuel pump, ProcessWest FMIC kit, Tomei turbo inlet hose, Cobb intake, IAG TGV Delete Ver.2, Airpump delete, Hi Spark Japan coilpack, HKS spark plugs Cold range 8, Greddy Radiator Driveline Modifications: 2014 JDM STi Transmission (These are short ratio 6MT like early USDM 04-06 but with final drive of 3.9 + 1.1 Transfer ratio) Suspension Modifications: BLITZ ZZR coilover, Cusco adjustable lower arm, Other Modifications: CE28SL 18x9.5, WorksBell RAPFIX + Prodrive Japan steering wheel, Full Defi advance gauges(Boost, Water temp, oil temp, Oil pressure) Video Link: To be updated. Dyno Plot : Low boost S mode 1.15 bar, Hi boost S# mode 1.45 bar Picture of the car : So it has been awhile since I updated on NASIOC but I'd like to introduce few of the cars I encountered over my subaru journey. Car is my client's 2014 JDM STi GVB Spec C. This car features many desirable options such as lightweight glass, aluminium hood, intercooler spray, etc. We decided to ditched Spec C ball bearing twin scroll setup for UEL rumble + sufficient power on top-end setup. I was personally against on ditching twin scroll setup but ever since owner bought the car brand new in Osaka, Japan, he wanted to get that signature Subaru rumble sound on his beloved Spec C. Goal was to keep the response of twin scroll ball bearing character but provide sufficient top-end. Gas was RON 99 (93 equivalent in US) Insta link for more photos : https://www.instagram.com/p/CZ4W-B7FNdd/?utm_medium=copy_link Enjoy.
03-10-2022, 12:02 PM | #2 |
Member#: 355996
Nice to see this here. I'm putting together a similar build but with an EJ257 and TD06SL2 on the exhaust side of the turbo.
03-11-2022, 12:04 AM | #3 |
Member#: 213393
03-11-2022, 01:14 PM | #4 |
Member#: 175624
Vehicle:0304 WRX WRX SY WRB |
Do you happen to have a boost/rpm plot? Didn't see it in you dyno plot
Sent from my SM-G781U1 using Tapatalk |
03-12-2022, 03:41 AM | #5 |
Member#: 213393
03-14-2022, 04:58 PM | #6 |
Member#: 355996
Ah, I've already bought the turbo with the TD06SL2, I wasn't sure what the TF06 was exactly. Seems like plenty of people have made good power with the SL2 though. Good to know.
03-20-2022, 09:46 AM | #7 | |
Member#: 213393
Boost plot is during dyno pull 4th gear. Engine EJ207B (Ver. 10 spec C engine), Custom External wastegate pipe + 45mm Turbosmart EWG High boost (S#) on RON 99 Octane Gradual throttle -> WOT throttle at 2500RPM You can see the plot below. Very responsive and a good match with EJ207 |
03-22-2022, 08:40 PM | #8 |
Member#: 297799
South East
Vehicle:2003 WRX EJ207 version 8 |
Very nice. Did this v.10 EJ207 have dual AVCS?
03-24-2022, 09:33 PM | #9 |
Member#: 213393
