Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Old 06-22-2021, 12:54 AM   #651
Scooby South
Subtly Outspoken
Member#: 238
OG05 STi
51E
Thinking about polishing out my 17 STi Wheels to something like this:
What says you???
For Reference.. 17 STi wheels..
Bill
Old 09-21-2021, 10:06 AM   #652
Zebra71
Member#: 526604
Any info on 2020 BRZ oem wheels? Specifically will they clear 06 WRX four pot brakes? Haven't found a conclusive answer searching so far.
Awesome thread thanks!!!
EDIT : found an example here
https://www.google.com/amp/s/amp.reddit.com/r/subaru/comments/k0j2hk/brz_performance_package_wheels_on_my_06_wrx_wagon/
Zebra71 is offline   Reply With Quote
Old 10-05-2021, 12:55 PM   #653
VoltexSTI
Member#: 521838
Good info here!
VoltexSTI is offline   Reply With Quote
Old 12-18-2021, 11:05 AM   #654
swowlinc
Member#: 303682
2006 Outback XT
Silver/Grey
Originally Posted by Mach V Dan View Post
2013 BRZ (and FR-S)
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 20.1 pounds (need verification)
OEM-equipped tire size: 215/45R17
Notes: Does not clear FHI four-pot front brakes
Need photo.
2013 Legacy steelie
Offset: ?
Bolt pattern: 5x100
Wheel Weight: 22 pounds (estimated)
OEM-equipped tire size: 205/60R16
2013 Crosstrek XV alloy
Offset: +48
Bolt pattern: 5x100
Wheel Weight: Unknown, but looks heavy
OEM-equipped tire size: 225/55R17
JDM Legacy B4 Blitzen
17x7
5x100
55mm offset
21.5 lbs (bathroom scale)
2002-2004 Forester XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 19 lb (bathroom scale)
OEM-equipped tire size: 215/60-16
2005-06 Forester XS
Size: 16 x 6.5"
Offset: +48
Bolt pattern: 5x100
Weight: 20 pounds
OEM-equipped tire size: 215/60 R16 94H all-season tires
2007 Forester XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 215/55R17
2008 Forester Sports XT
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 20.8 lbs
SG Forester STI
Offset: +48
Bolt pattern: 5x100
Wheel Weight: 26.2 lbs
OEM-equipped tire size: 225/45R18
Clears 4-pot Brembos
2009 Forester XT
17x7"
Offset: +48
Bolt Pattern: 5x100
weight: 22.9 lbs with TPMS sensor and some wheel weights.
2014 Forester XT
Size: 18 x 7"
Offset: +48
Bolt pattern: 5x100
OEM Tires: 225/55 R18 97H all-season tires
Weight: Unknown
OEM-equipped tire size: 225/55 R18 97H all-season
2014 Forester XT weight is 25lbs.
swowlinc is offline   Reply With Quote
Old 01-13-2022, 03:54 PM   #655
Mach V Dan
Member#: 12029
Thanks, but what is your source for that?
Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-16-2022, 10:11 PM   #656
choochoo
Member#: 461156
I didnt see this wheel on here.
1st gen BRZ performance package wheels
17x7.5
+48
choochoo is offline   Reply With Quote
Old 01-16-2022, 10:11 PM   #657
choochoo
Member#: 461156
I swear I only pressed the button once =(
Old 02-18-2022, 01:28 PM   #658
Mach V Dan
Member#: 12029
Some BRZ wheels:
2020 BRZ Performance Package
Offset: +48
Bolt pattern: 5x100
Weight: 20.8 lbs
2022 BRZ Premium
Offset: +48
Bolt pattern: 5x100
Weight: ?
2020 BRZ Limited
Offset: +48
Bolt Pattern: 5x100
Wheel Weight: 22.5 lbs?
OEM-equipped tire size: 215/40R18
2022 WRX wheels:
<Photo will go here>
2022 WRX Base
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: ?
OEM-equipped tire size: 235/45R17
2022 WRX Premium/Limited
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 25.2 lbs (Mach V shipping scale, and post by Redeemed77 below.)
OEM-equipped tire size: 245/40R18
Clears 4-pot Brembos on older models. (NOT on 2022+ WRX, though!)
Old 06-18-2022, 05:43 PM   #659
Redeemed77
Member#: 378138
2022 WRX
Stock 2022 WRX 18 inch wheels 25.2-.4 pounds, weighed 5 times and tested other known weights on scale.
Redeemed77 is offline   Reply With Quote
Old 07-05-2022, 06:44 PM   #660
krayjeegsr
Member#: 139071
Originally Posted by Scooby South View Post
and Installed
Any rubbing with that tire size?
krayjeegsr is offline   Reply With Quote
Old 06-20-2023, 10:40 AM   #661
echardcore
Member#: 260638
2011 WRX Sedan
Spark Silver Metallic
Hey all. Ordered a set of Ultraleggeras for my 11 WRX. My research shows that they should fit fine. Car is stock. Going to 18x8.
OEM
2011-2014 WRX
Offset: +53
Bolt pattern: 5x100
Weight: 21 lbs (by shipping scale -- see post #206)
Notes: Clears four-pots
O.Z.
18x8
Offset: +48
Weight 18.4 lbs.!
Tire: 235/40ZR18 (General G-Max)
https://www.tirerack.com/wheels/Whee...odClar=Premium
Calculations show +5 mm pushed away from the suspension and toward the fender arch.
Should be good, no? Seems like a big jump in offset.
Thanks in advance! Will cancel order if any chance of rubbing.
Garage queen gets a facelift!
EDIT: Arrived today. Gorgeous wheels. Won't be able to install and test for a few days.
echardcore is offline   Reply With Quote
Old 08-31-2023, 02:07 PM   #662
lubji
Member#: 535359
Default 05 Forester and 95 Impreza wheels
Steel -16 inch. 10.8kg or 24pounds. 05 Forester 48 offset.
Aluminum -16 inch. 7.5kg or 16.5pounds. 1996 Impreza 55 offset.
I used them on and 08 Impreza but with a 6mm spacers.
lubji is offline   Reply With Quote
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
