03-05-2022, 02:21 PM | #1 |
Member#: 528955
2007 crank, no start
My 07 started not starting...no codes. It's acted up over the last 2 weeks or so. It sporadically has been doing this. Fuel pump tested good. Alternator, battery and starter tested good. Replaced crank sensor.
What direction should I go now?
03-13-2022, 06:06 PM | #2 |
Member#: 508319
Vehicle:2007 Impreza 2.5i Newport Blue Pearl |
I’d check the coils next and possibly the fuel lines.
03-21-2022, 09:18 AM | #3 |
Member#: 505946
Vehicle:2019 S209 White |
I had that happen on my 05 sti. LISTEN If your fuel pump turns on while before you start. If it doesn't It's your fuel pump. If you hear the pump turn on. Then it's your of engine crank sensor. There is two of them. The one in the front usually go bad. In my case it was the front. Your case it may be the rear or both. Good luck! Hope you get it running soon.
03-21-2022, 09:19 AM | #4 |
Member#: 505946
Stis209
04-19-2022, 03:20 PM | #5 |
Member#: 529723
No crank/no start: It was a FUSE!
Howdy.
2008 Impreza hatch wrx sti. Car would "power up" but no crank. Diff Lock indicator on dash was at 5 bars. Come to find out, there are two fuses on passenger side foot well for some odd piece of electronics that's located there. The fuse on the right was bad. Swapped it and all is OK now. |
