06-29-2015, 11:12 AM | #19001 |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
Quick question for you guys, I'm in the 2012+ forum, but since our cars share some similarities, I was wondering if any of you had swapped the steering wheel on this car? Did you run into any issues or benefits doing it? Messing with removing and installing the airbag is somewhat putting me off going too crazy with this idea.
06-29-2015, 11:27 AM | #19002 | |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
I swapped my steering wheel and plasti dipped my airbag at the same time. No issues, swapped to an OEM Wrx wheel. Essentially the exact same thing in black with wrap on it. Disconnect your battery, pump your brakes a few times, then wait an hour for good measure before unplugging your airbag. |
06-29-2015, 01:24 PM | #19003 |
Member#: 403464
E. Canada
Vehicle:2008 Impreza sport h lightning red |
Yea they are 42 offset
06-29-2015, 01:25 PM | #19004 |
Member#: 403464
E. Canada
06-29-2015, 01:59 PM | #19005 |
Member#: 410716
Vehicle:2016 WRX CBS |
I have the same tires, cooper zeon rs3-s... Or did you get the rs3-a? I like them soo far! Great improvement over my stock wheels, especially on my 17x8.
06-29-2015, 02:08 PM | #19006 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
06-29-2015, 08:54 PM | #19007 |
Member#: 403464
E. Canada
06-29-2015, 08:56 PM | #19008 |
Member#: 403464
E. Canada
do you mean pull? cause they are rolled to the max lol the inside lip is completely bend in and flush
06-29-2015, 09:43 PM | #19009 |
Member#: 146287
BAIC
If that's the case, then, yes. Pull them.
06-30-2015, 01:12 PM | #19010 |
Member#: 342985
Hey all, been awhile. Up to 190k on the car and having an issue recently. Steering is extremely stiff, when leaving a parking spot... need two hands to turn. Zero whining, no noises or anything. Thoughts? Steering pump replacement, steering pump o-ring failure? I am NOT losing any power steering fluid, still slightly above the full mark.
FYI, the steering rack was replaced about 5k ago since it was leaking and would whine on cold start ups when it was 5-10F outside. In my resarch online for failed steering pumps... most of the threads talk about hearing a whining noise, I don't have any of that. Thank you guys. |
06-30-2015, 07:42 PM | #19011 |
Member#: 413473
Vehicle:08 OBS Black |
Steering
[quote=DownhillSubie;43566743]Hey all, been awhile. Up to 190k on the car and having an issue recently. Steering is extremely stiff, when leaving a parking spot... need two hands to turn. Zero whining, no noises or anything. Thoughts? Steering pump replacement, steering pump o-ring failure? I am NOT losing any power steering fluid, still slightly above the full mark.
tighten your power steering belt. I'll bet you anything it's just a bit too loose. |
07-01-2015, 11:29 AM | #19012 | |
Member#: 342985
[quote=Smengineer;43568272]
Negative, not the power steering belt, all tight. I'm noticing some blow-by on the return line from the power steering pump. Going to see if it is the O-ring. The pump is getting fluid because when I have the car on and turn the wheel, I can see the fluid bubbling around in the reservoir, so I don't think it is the pump that failed. |
07-01-2015, 11:47 AM | #19013 |
Member#: 146287
BAIC
I had some weird steering stiffness but it would usually go away before I get out of the parking lot. Felt like a manual rack.
I have a leak in my rack and the system was filled with Lucas Stop Leak which is super thick syrupy stuff. So I just attributed the stiffness to the thick fluid. Maybe throw in some Power Steering System additives? In addition to stopping leaks the Lucas stuff works to recondition seals and gaskets. My steering did feel noticeably smoother. http://lucasoil.com/products/problem...ring-stop-leak |
07-01-2015, 11:50 AM | #19014 | |
Member#: 342985
Hmm, thanks for the tip. The stiffness doesn't go away in mine... it is constant. Drove the car on a 10 mile loop last night around town, hard steering the entire time. Obviously easier at speed vs. in a tight parking spot. |
07-01-2015, 12:15 PM | #19015 |
Member#: 146287
BAIC
Weird. I wonder if there's a clog in the lines. Thicker fluid might break up a clog.
07-01-2015, 01:14 PM | #19016 | |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
My 17x9 +35 225/45 never rubbed and neither do my 18x9.5 +30 225/35. It's all about offset, camber and modified fenders. Mine are all rolled and pulled. 8k/8k spring rate so not even that stiff. |
07-01-2015, 08:37 PM | #19017 |
Member#: 403464
E. Canada
07-02-2015, 04:49 PM | #19018 | |
Member#: 403464
E. Canada
Mechanically its the same, i think, but it was the rear bumper defuser and the side skirts like the wrxs with no hood scoop |
07-02-2015, 05:16 PM | #19019 |
Member#: 410716
Got my rally armor flaps in the mail today... Hopefully i like the look/functionality of them once i get them on or i guess ill be reselling them haha :x
07-02-2015, 10:30 PM | #19020 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
If you install them regular way w/o the factory mud guards (no extra drilling) and do not like them, and have all the hardware, etc still, I'll probably buy them off you if you want to sell them. I'm thinking about removing my factory mud guard and just use the Rally Armor flaps. Mainly just so I can easily remove them and clear out the junk that collects in the fenders once a year or so. |
07-03-2015, 02:21 AM | #19021 | |
Member#: 410716
Picked them up slightly used on the classifieds... There either silver or grey, haven't really looked at them with proper lighting yet to tell, the seller wasn't sure as i think he got them on the car when he bought it or something... There in pretty good shape. Ill try and mount one up without drilling them for my oem mud guards first and see if i like them before i put the extra hole in them. |
07-03-2015, 09:30 PM | #19022 |
Member#: 410716
Anybody running rotella t6 5w40? Thinking about trying that or pennzoil ultra platinum 5w30 or maybe amsoil OE 5w30 on my next oil change... Currently using castrol edge 5w30...
07-03-2015, 09:44 PM | #19023 |
Member#: 330830
08 2.5i
07-04-2015, 12:33 AM | #19024 |
Member#: 146287
BAIC
You're running RS headers? I thought you had Rallisport.
07-04-2015, 12:44 AM | #19025 |
Member#: 355937
SCIC
Vehicle:2010 Impreza OBS Black on Black |
08 2.5i
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
