Old 06-20-2020, 06:39 PM   #1
Boxer1687
Member#: 369969
1998 Impreza Outback
Default Rear drums to disc conversion
Hey all!
Got a 98 Impreza 5 Spd. Drums in back. Drums FINALLY are showing it’s wear. Given that opportunity I’d like to take this chance to convert the drums to disc. I’ve read I can convert them to late legacy models(98,99) with ABS. But what about 00-04 legacy models and 2.5 RS Imprezas? Does anyone know?
Boxer1687 is offline   Reply With Quote
Old 06-22-2020, 08:03 AM   #2
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
2.5 RS GC imprezas yes for sure,
I guess old rear disc car knuckles aren't too hard to find? IDK
good luck getting the "big ass bolt" out of your old control arms though.
Cujo31 is offline   Reply With Quote
Old 07-09-2020, 08:02 PM   #3
Boxer1687
Member#: 369969
That bolt it’s already broken. So my plan is replacing the control arms as well as the trailing arms. Just need to know the compatible years.
Old 08-10-2020, 03:59 PM   #4
Boxer1687
Member#: 369969
Update on this?? Anyone know what years is compatible with my 98 Impreza wagon?
Old 08-22-2020, 05:26 PM   #5
Wannabe WRX
Member#: 130623
1999 STi-R #95/1000
WRB (in Progress)
You can bolt any Impreza or WRX up to at least 2005. 93-01 Impreza rear hubs would be the best bet.
The regular 06-07 Impreza rear discs will also work. 06-07 WRX hubs require a 16x7 wheel set, so unless you're doing a full upgrade, avoid.
Legacy hubs from 93-01 should also work (they're the same as the Impreza).
Do not get any of the 2004+ STi stuff. You will spend major $$$$ trying to get that to work.
Wannabe WRX is offline   Reply With Quote
Old 03-06-2021, 07:16 PM   #6
Boxer1687
Member#: 369969
Thank you for this reply (almost a year later for me to thank you!).
I will keep this in mind when looking for parts.
Old 03-11-2021, 01:36 PM   #7
Zedexgc8
Member#: 372109
2018 WRX STI
Pure red
Reading this, what proportioning valve can we get?
I have a 2000 impreza L non ABS with rear drums. I'd like to convert to 2002 WRX rear assembly.
What is needed exactly?
hub, knuckle, disk, calipers, pads, , proportioning valve ?
Zedexgc8 is offline   Reply With Quote
