Brakes & Suspension Forum sponsored by The Tire Rack |
04-14-2021, 02:05 AM | #1 |
Member#: 400078
South East
Vehicle:1998 2.5rs06wrx swap black |
Firewall flex question
Is it possible with manual brakes for the firewall to flex enough for a wire to slip behide the clutch master cylinder? I just found my starter control wire wedged and trying to figure out how it got there.
04-14-2021, 03:58 AM | #2 |
Member#: 395793
Vehicle:2005 92x Aero Beige |
Do you mean manual trans?
Yes the firewall can flex a bit. That's why people get the master cyl brace to help firm things up a bit. As for the wire being wedged, that's anyone's guess. Most likely someone not paying attention after performing some work in that area. |
04-14-2021, 10:24 AM | #3 | |
Member#: 400078
South East
04-15-2021, 08:14 AM | #4 |
Member#: 395793
You are asking about manual brakes, which all cars use a brake pedal and are actuated manually, but discussing the clutch slave cylinder. So it seems to me you're asking asking if this is something that can happen with a car with a manual transmission.
If you don't have a master cyl brace the firewall can flex quite a bit. Have someone sit in the car and press the brake pedal firmly and you can watch the firewall flex. A master cyl brace helps quite a bit but there is still a small amount of flex regardless. Under normal driving situations you won't notice it. Spirited driving, or emergency situations it's noticeable. Whether or not a wire can become wedged behind the clutch master cyl, I can't say. Mine doesn't have a wire close enough that it could happen. You can share a pic of how the wire is routed and get some input from that. Possible, sure. Anything is possible |
04-15-2021, 08:07 PM | #5 |
Member#: 297799
South East
Vehicle:2003 WRX EJ207 version 8 |
I'm pretty sure he deleted his brake booster and now has manual brakes. I am considering doing the same.
The clutch master isn't that far from the brake master and it is likely that you have much more firewall flex than normal, depending on how your manual brakes are set up. You could set up a camera or have someone else press your brake pedal and see how much the firewall moves to know for sure. |
