03-08-2021, 06:29 PM | #1 |
Member#: 518170
Has anyone successfully read a 2007 2.5i NA Ecu?
I have tried 3 different cables no matter what i cannot get the ecu to read.
all i get is this no matter the cable (tried generic tactrix and ftdi cable) contacted Tactrix direct, they stated it should work but cannot gaurantee. also if it does not they stated "....we do not do returns and that in the current market you should be able to sell it" Hahaaa! 2007 2.5i Impreza Auto green connector connected.
03-09-2021, 07:55 AM | #2 |
Member#: 262117
Vehicle:2001 Forester STI MKtuned |
Actually Yes, to make a slight idle adjustment, ive reflashed an 07 2.5i hatchback before.
What was weird though was that I had to select an odd-ball year for the ECU selector, one you wouldnt initially guess. I vaguely remember it being like "STI 07+" or something like that, and it was able to recognize the ECU, pull and flash the map no issue. Play around with ECUflash's selector until it does a successful read and/or test write ( always test write first!) of the map. |
03-10-2021, 06:30 PM | #3 |
Member#: 515308
I use 2007 2.5i to run my 2006 forester x
03-10-2021, 06:31 PM | #4 |
Member#: 515308
I have also had an ecu that my cable wouldn’t connect to. I just ordered a spare. There is no immo so it’s plug and play
03-16-2021, 07:16 PM | #5 | |
Member#: 518170
03-17-2021, 11:10 AM | #6 |
Member#: 394646
NWIC
Vehicle:2003 WRX Flex Fuel Pv=nRT |
File > Options > (scroll down, all the way down) and select SSMk1 for CAN seed key algorithm
Ecu > Select vehicle type > pick the sti05 / sh7058 / 1024k type despite being a year with CAN, it doesn't use the standard "subaru CAN" communications for whatever reason when flashing (read/write) |
03-17-2021, 12:18 PM | #7 | |
Member#: 518170
03-21-2021, 02:11 PM | #8 | |
Member#: 518170
PM me a BTC or ETH address and ill send you a thank you! |
