Old 01-24-2021, 07:11 PM   #2051
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Originally Posted by xpystchrisx View Post
I'd go as close to stock as you can get then. And then dial in as much camber as you can at the front wheels. Then match it or just a bit less camber at the rear. I prefer zero toe on these cars at all four corners, but I autox at least once a month.
I've got the Whiteline camber bolts in the front, so I'm assuming I'll be able to get 2.5+ at the front. Maybe I'll go something like 2.2/1.5 with zero toe.
PilotKD is offline   Reply With Quote
Old 01-26-2021, 05:03 PM   #2052
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Well I tried installing the white line bump steer / Roll center kit today with only 50% luck. I could not get the ball joint out of the Hub on either side. After smacking it enough for my lower control arm looks like it lost a fight with Mike Tyson I didn't really want to continue doing that and risk damaging my aluminum control arm. I was able to get the tie rod ends on no problem the correct bump steer but I'm going to have to re-attack the ball joints some other time. Looks like they make a special tool for that which cost about $70 but I guess I'll have to bite the bullet and buy one of those. The ball joint definitely didn't come out like some others show on YouTube with a crowbar and a couple Taps of the hammer. Cars got 38,000 miles on it in the Northeast so I guess there's a bit of rust up there. In the meantime I'm going to have to get the thing aligned tomorrow without the new ball joints in there.
Old 01-27-2021, 01:53 PM   #2053
gtsilver944
Member#: 443043
Might want to hold off on the alignment appointment if you know how to get the alignment within the ballpark and aren't putting many miles on. Having geometry corrected tie rods with stock ball joints will create some interesting bump steer. And it'll need to get aligned again with the new ball joints.
I used a cheaper version of the tool off Amazon (figure it's a once or twice use ever tool) with an impact wrench which made the job quite easy.
gtsilver944 is offline   Reply With Quote
Old 01-27-2021, 03:59 PM   #2054
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Well I did get it aligned today since they told me they'd honor a "freebie" if I come back within 30 days to tweak anything that needs to be fixed (more on that below).
Their printer was broken so I don't have a print out of the alignment results, but he was able to get the rears at -1.5 L/R and the toe pretty close to 0, but from what I remember it wasn't right at 0. I want to say it was somewhere around +0.15. Front toe was somewhere around +0.02. The big issue was front camber. When I put the Whiteline camber bolts in, their instructions left little to be desired and just about all of the YouTube videos show people putting the camber bolts in the top hole. After digging a little deeper, I found out that this is apparently wrong. The aftermarket camber bolts should go on the bottom retaining the OE camber bolt up top. Due to me installing these wrong, the dude could only get -.5 on the left and -.02 on the right. Hardly close to what I wanted (-2.0). He was really cool about it and even tried to figure out how we could fix it right there (I was under the lift with him), but after frantically searching the web while I was standing there with him, I figured out that I really needed the OE bolts back in there (that were home in my garage). So, he tightened everything back up as is and told me to come back after I fixed everything. Even with the half-assed alignment, the car feels like a million bucks. My only other option instead of using the camber bolts is to get new strut mounts like the Whitelines or camber plates.
This will work out better anyway because it gives me time to get the Whiteline ball joints in there. I wound up buying the $25 Astra Subaru ball joint tool on Amazon, which should get here tomorrow. That should make quick work of the seized ball joints so I can get the Whitelines in there and go back for Alignment Part 2. Next time, I'll take pics of his screen.
https://www.amazon.com/Astro-Pneumat...1780414&sr=8-7
Unrelated: Does anyone know anyone running the "Super Pro Front Alloy Control Arm Kit" for the 2015+? A little pricey and I assume overkill since the OE LCA's are aluminum to begin with?
https://superprousa.com/products/alo...-alloy-arm-kit
Old 01-27-2021, 10:18 PM   #2055
gtsilver944
Member#: 443043
I believe those are just stock control arms that have been polished and had Superpro bushings pressed in. Makes it a "bolt on" item ($600) rather than having to press the old bushings out and their bushings in ($200 + labor).
Old 01-27-2021, 10:53 PM   #2056
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Now that you say that, they do look identical to the OE FLCA.
Old 01-28-2021, 10:18 AM   #2057
brew182
Member#: 488451
Default Bouncy ride help?
Hey everyone, not the most experienced with suspension related things so I'm hoping for some direction. I have tried searching, but couldn't find great info.
I have a '16 Premium WRX, original owner, ~42k miles. Car has been completely stock except for a shift stop and tune.
I have been noticing for some time that my steering when driving on the highway has had issues. I'm constantly having to make small adjustments to keep in my lane. This has maybe been noticeable for ~6 months? Did some quick searching and thought it may have been the steering dampener causing play in the steering. I installed the Perrin dampener lockdown and I did notice a slight improvement, but still having issues.
After driving some more I was trying to pay more attention to what's going on and I'm noticing the car feels very "bouncy" on the highway. I'm not sure how best to describe it, but it feels like I'm sitting on a spring even on a straight "flat" section. After that realization, I've noticed it is also bouncy around town too, just not as noticeable. One odd thing is that if I hit a sharp bump it doesn't seem to do a ton of bouncing, mostly with small gradual bumps I see the problem.
I'm wondering if this is causing my steering issue (or if they're unrelated). Does anyone have any good ideas of what could be causing this? I know the struts are a good place to start, but I don't want to go through the cost of replacing without knowing for sure. 42k miles seems like a short life, but they have seem some terrible New England roads their whole life. Any tests I can run or things to look out for to better diagnose would be very helpful!
Thanks!
brew182 is offline   Reply With Quote
Old 01-28-2021, 02:28 PM   #2058
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Thanks!
I'm not sure about your steering issue, but I always felt my '17 was "bouncy" with the stock suspension, especially in the rear. To the point that it destabilized the car sometimes. My car has 38,000 miles and I've owned it since 26,000. With the GT Works Trophy Cups, the car just absorb the bumps and you kind of get thrown down into the seat as they rebound. It may be time for some new dampers.
Old 02-11-2021, 05:28 PM   #2059
PilotKD
Member#: 131702
2017 WRX Premium
CWP
Any updates? How are they?
Just a little more on these. I've probably got 500 miles on them now with an alignment. I did add Vorshlag camber plates and did away with the Whiteline camber bolts. The Vorshlags add a 1.0 degree of caster and as you can see from the pics, I've got a lot of room for camber adjustment. It's sitting at -2.0 up front and -1.5 in the rear with 0 toe up front and a slight amount of toe in the rear. I don't remember what it was off hand and the aligners printer was not working. So right now I've got the GT Works Trophy Cups, Vorshlag camber plates, Whiteline RLCA's, Whiteline toe arms and the Whiteline 24mm rear sway bar. 255/40-18 Michelin Pilot Sport 4's.
Overall, it rides stiff! It's definitely streetable, but you need to be careful on rougher roads. It feels like a new car though. Absolutely no lean around corners with so much grip even with all-season tires. I feel like I am getting a little bit of tramlining running those alignment settings, but other than that, it feels great. I may end up eventually fine tuning the alignment a bit more.
The camber plates definitely make the front suspension more communicative. It's barely noticeable on the highway, but there is definitely more noise and feel over cracks and imperfections of the road without a rubber bushing. I can definitely feel more of the road now, even in the brake pedal.
Old 02-23-2021, 10:59 AM   #2060
MIA20WRX
Member#: 522387
2020 WRX Base
Magnetic Gray
Default shock/strut choices ???
Hey guys, first post here. Looking to make some suspension and aesthetic upgrades on my brand new stock 2020 base WRX. I plan on getting 20mm spacers front and rear and getting H&R Sport Springs. I’m also considering getting shocks/struts to accompany the springs, any suggestions or recommendations ?? I found Bilstein B6 & B8 but nothing else. Also considering getting KW V1 coilovers as opposed to separate shocks and springs. Lmk what y’all think
MIA20WRX is offline   Reply With Quote
Old 02-23-2021, 10:00 PM   #2061
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Well most people want to know spring rates on lowering springs and your initial choice (H&R) doesn't divulge rates(never). So you'd be in the "dark" on your first choice of X springs and spacers.
Maybe one question anyone reading this would have is what do you plan to do with the car in the future? 100% street or any track or autocross use?
If you have no intention to improve handling ( some people dont) then most of your options should suffice for aesthetics. But if you want to decrease the inherent understeer the stock car has anywhere near the limit then we have a few options that work very well.
Let us know if your thoughts,
Myles
Racecomp Founder
RaceComp Engineering is offline   Reply With Quote
Old 02-24-2021, 12:08 PM   #2062
MIA20WRX
Member#: 522387
2020 WRX Base
Magnetic Gray
Myles
Racecomp Founder
Thanks for the advice!
I intend on keeping it as a daily driver, just looking to have more fun and better aesthetic. I would possibly consider sway bars in the future in regards to the understeer aspect.
Looking into getting a GH/GR sti for track/autocross purposes in the future.
Old 02-24-2021, 02:09 PM   #2063
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
Doing sway bar(s) to resolve the understeer issue is a band aid. Changing the spring rates would be the best remedy and then yes adding sway bars.
Mw
Old 03-14-2021, 12:05 PM   #2064
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
does anyone have advice for getting this bushing out? its like 4" in diameter and the tool that was listed in the service manual is discontinued
_brian_ is offline   Reply With Quote
Old 03-14-2021, 04:39 PM   #2065
Rimsky55
Member#: 424917
I know the Gtworx/Bilstein + Yellow RCE, when launched in 2016, was advertised as "ride better than a fully stock STI". The STI's suspension has since supposedly gotten softer over time (but ride quality offset by increase in wheel size to 19).
Would the Gtworx+Yellow feel softer/better ride quality vs the OEM 2019+ STI? If not, any suspension replacement options that would make it softer (without compromising too much performance) for those who live in an area with poorly maintained roads?
Rimsky55 is offline   Reply With Quote
Old 03-15-2021, 12:28 AM   #2066
aplus
Member#: 491978
Are you running stock springs with the GTWorx Bilsteins?
I'm running Yellows with the GTWorx struts and it's personally it's too stiff and bouncey for me; thinking of swapping the Yellows for my stock ones.
aplus is offline   Reply With Quote
Old 04-08-2021, 07:20 PM   #2067
SlowRedOne
Member#: 423271
2015 STi
Lightening Red
Took the sti to the shop to install coilovers. When I went to pick it up they told they also put on some rear LCAs without letting me know at all and then charged me for it. They said it was necessary to keep even wear on the tires.....how true is this? It doesn't sit right with me that they just put them on without giving me any sort of heads up.
SlowRedOne is offline   Reply With Quote
Old 04-08-2021, 10:29 PM   #2068
PilotKD
Member#: 131702
2017 WRX Premium
CWP
No. I have the GTWorx Bilstein Trophy Cup coilovers, not struts. I believe the spring rates on the coilovers are 400lb/in front/rear.
UPDATE: I am getting a lot more noise out of the Vorshlag camber plates. More so on the driver's side than passenger side, but it seems to come from both sides (sounds like a cricket in the dashboard over subtle bumps/divits in the road). I've almost thought it was my dash creaking, but I really think it's the plates. My tophat nuts are torqued down tight. I did put a little lithium grease on them today, so we'll see if that helps.
Old 04-09-2021, 01:12 PM   #2069
blurred
Member#: 47143
I ran vorshlag plates for about 5 years and never had 1 noise. They were completely silent so I'd say you have an issue, maybe it's not the plates (dead/dying/loose swaybar endlinks make those noises over small bumps fyi) at least you'll need to change the bearing if it has died
blurred is offline   Reply With Quote
Old 04-09-2021, 01:21 PM   #2070
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Adjustable rear LCAs are definitely nice to have, but not must haves. I do recommend them but it wouldn't really be cool for a shop to do something like that without telling you beforehand.
- Andrew
AndyRoo is offline   Reply With Quote
Old 04-09-2021, 04:30 PM   #2071
PilotKD
Member#: 131702
2017 WRX Premium
CWP
I honestly think it's a squeak in my dashboard somewhere that I got to hunt down and not the plates. It sounds too close to me.
Old 05-03-2021, 10:55 AM   #2072
Urabus33
Member#: 343479
2006 Legacy GT Stage
Has anyone paired the GT worx with a lift spring, like KING or Rallitek? Planning to do a small (2") lift and the springs are supposedly 20% stiffer than OEM with a 1" lift (2020 WRX) and I want to make sure they would be a good match.
Urabus33 is offline   Reply With Quote
Old 05-03-2021, 12:39 PM   #2073
AndyRoo
Member#: 20952
BRZ & Datsun
White & White
Yes this guy on instagram rallycrosses his 2015+ chassis with GTWORX Bilsteins and King springs.
https://www.instagram.com/heritagelivery/
A couple people had similar set ups for GR chassis...the Bilsteins work well for that sort of thing. The King spring rates are sort of a mystery which is annoying, and I think they could be better for rallyx if that's you're thing. But still a good combo for a little extra height with good damping.
Racecomp is actually working on rallyx springs for 2015+ WRX/STI but there's still some development work to do. I'm the guy working on the BRZ rallyx springs at RCE. Supply and covid issues are making things move very slowly unfortunately but we're making progress.
- Andrew
Old 05-06-2021, 08:29 PM   #2074
Urabus33
Member#: 343479
Appreciate the insight. Really just want something that can comfortably tackle daily driving on pothole/construction filled roads, railroad tracks and big bumps/dips in the freeway. The stock dampers don’t seem to be the answer but most of what I read is people lowering on GTWORX, not raising hence my query.
If you can answer, How are the planned RCE RallyX springs going to differ from whats on the market currently?
- Andrew
Old 05-07-2021, 10:09 PM   #2075
cueball89
Member#: 90513
Anyone know the length of the OEM 15+ front springs for the wrx or sti?
cueball89 is offline   Reply With Quote
