Old 03-08-2021, 06:29 PM   #1
U7TRA_
Member#: 518170
Default Has anyone successfully read a 2007 2.5i NA Ecu?
I have tried 3 different cables no matter what i cannot get the ecu to read.
all i get is this no matter the cable (tried generic tactrix and ftdi cable)
contacted Tactrix direct, they stated it should work but cannot gaurantee. also if it does not they stated "....we do not do returns and that in the current market you should be able to sell it" Hahaaa!
2007 2.5i Impreza Auto
green connector connected.
U7TRA_ is offline   Reply With Quote
Old 03-09-2021, 07:55 AM   #2
mikeydrives1
Member#: 262117
2001 Forester STI
MKtuned
Actually Yes, to make a slight idle adjustment, ive reflashed an 07 2.5i hatchback before.
What was weird though was that I had to select an odd-ball year for the ECU selector, one you wouldnt initially guess. I vaguely remember it being like "STI 07+" or something like that, and it was able to recognize the ECU, pull and flash the map no issue. Play around with ECUflash's selector until it does a successful read and/or test write ( always test write first!) of the map.
mikeydrives1 is offline   Reply With Quote
Old 03-10-2021, 06:30 PM   #3
benflynn
Member#: 515308
I use 2007 2.5i to run my 2006 forester x
benflynn is offline   Reply With Quote
Old 03-10-2021, 06:31 PM   #4
benflynn
Member#: 515308
I have also had an ecu that my cable wouldn’t connect to. I just ordered a spare. There is no immo so it’s plug and play
Old 03-16-2021, 07:16 PM   #5
U7TRA_
Member#: 518170
Any specific version of ecuflash?
Old 03-17-2021, 11:10 AM   #6
jon7009
Member#: 394646
2003 WRX Flex Fuel
Pv=nRT
File > Options > (scroll down, all the way down) and select SSMk1 for CAN seed key algorithm
Ecu > Select vehicle type > pick the sti05 / sh7058 / 1024k type
despite being a year with CAN, it doesn't use the standard "subaru CAN" communications for whatever reason when flashing (read/write)
jon7009 is offline   Reply With Quote
Old 03-17-2021, 12:18 PM   #7
U7TRA_
Member#: 518170
Will try this and report back. I greatly appreciate everyone's assistance
Old 03-21-2021, 02:11 PM   #8
U7TRA_
Member#: 518170
Great Success! Thank you!
PM me a BTC or ETH address and ill send you a thank you!
