Brakes & Suspension Forum sponsored by The Tire Rack |
02-16-2004, 12:59 AM | #1 |
Member#: 50872
SCIC
Vehicle:2002 Impreza WRX dark side |
Canyon Runners
Hi guys,
I know some of the club members are into canyon run as much I do, I want to know what would be the good set up to give myself a sweet canyon run and a daily drive. Im running with Whiteline rear sway, Tein coilovers for now, what should I be look into?? Thanks guys
02-16-2004, 01:25 AM | #2 |
Member#: 39552
BAIC
Vehicle:2003 WRX Wagon WRB |
Did you change your rear endlinks? How about tires? Get some good tires and endlinks. Best bang for buck mods, along with the RSB.
02-16-2004, 01:29 AM | #3 |
Member#: 17751
SCIC
Question, whats wrong/weak with your current setup?
02-16-2004, 02:05 AM | #4 |
Member#: 43996
Vehicle:The Aggressive (tm) You don't know about it.. |
I do the exact opposite of canyon running.
I am a mountain runner. |
02-16-2004, 02:42 AM | #5 |
Member#: 50872
SCIC
I like my set up I have right now, but you can never be happy what you have, coz we all want better and the best. I have Nitto555 right now on my set but I dont like them as much as my old set. But it could be my camber is set as factory setting. I will change them soon or adj the camber when I get time. I do take the car to the mounitne too, but as winter weather goes, I will wait til the summer comes. Safty is always come 1st.
So just the end links do the job? Thanks |
02-16-2004, 04:45 AM | #6 |
Member#: 39552
BAIC
Well, as thesmokingman asks, what is wrong with your current setup? The second question is what is your modding budget? Endlinks do make a big difference. I noticed it right away. The rear swaybar and endlinks were my first mod right after my tires/wheels. Camber settings will make a big difference too, but identifying what you want the car to do/not do will help with more specific suggestions.
02-16-2004, 10:20 AM | #7 |
Member#: 15106
First off loose those 555's and get some S03's in 17 inch size
225/45/17. Do you have strut tower bars? if not get front and rear from STi or Cusco. Also, make sure you're using aftermarket endlinks on your rear swaybar. Final touch is to get an aftermarket steering wheel. Your weakest link is you tires for now. goodluck! |
02-16-2004, 12:27 PM | #8 |
Top Scoob 002
Member#: 32771
BAIC
Vehicle:03 Black WRX 04 White M3 |
give us more info on the condition of the roads you will be driving. I live in the bay area and do alot of mountain driving on the weekends. My old setup was whiteline rear bar at 22mm w/ endlinks, cusco front and rear strut bars, and falken azenis tires. On smooth roads like highway 9 this setup wasnt very good, lots of body roll because of soft springs, calaveras road which is somewhat good condition my setup seemed just okay also. Mt. Hamilton which is extremely rough and bumpy my setup was perfect and i could drive extremely fast.
Now that i have hks hipermax 2 coilovers ive driven all these roads. Started on calaveras and its great, i can drive alot faster than before with the current dampening (19 from full soft in F, 20 from full soft in R and they are 30 way adjustable) I then went to highway 9 and was even more amazed, the suspension was even soft for this road and i could probably run alot stiffer on this road. I was on Mt. Hamilton yesterday and my setup sucked. I left it the same as the previous two roads and the person following me said i was constantly had only 3 wheels on the ground. Any bump i hit i would jump instead of going over it. So yea the whole point of my post was to say that it depeneds on what kind of driving you will be doign and where you will be doing it. Since you already have coilovers and i assume they are dampening adustable unless they are the tein SS you should be fine. Next time i goto hamilton im sure im gonna set my suspesion alot softer. |
02-16-2004, 01:45 PM | #9 |
Member#: 50872
SCIC
My set up right now is with Tein flex, the damper setting are 14 front and rear for daily driving. When I go for a run, I set them as 5 in front and 7 in rear. Thanks for the EDFC system. Camber setting is 0 front and 1.3 in rear..I need to change the front camber to 1.3 or 1.5 just like how I had them before. There is nothing worng or any weak point with my set up right now, I think my next mod is to upgrade the endlinks forsure. As for the road I run on, its smooth but with some rocks fell from the top. The new tires are not gripping on the road, tires are 225/35/18. Tires are need to go!! I really dont like them and they cost more than my old set. Never again with the nitto. My rear sway is whiteline and Im very happy with them. Im not plan to upgrade the strutbars, since I dont go to autocorss.
Sometime I can feel I ride on 3 wheels on a turn, I just add more weight to the trunk, Impreza's rear is too light weight sometime, but watch out for the power drift when you enter the turn while you gasing out, power drift might be a problem when adding more weight to the rear. money is not a problem. Since Im not in the hurry, plus I want to test it out each mod when I upgrade them. |
02-16-2004, 01:55 PM | #10 |
Member#: 17751
SCIC
You need an alignment. Then you should take your car to a track school day and learn the limits of your car. Then you can fully appreciate what your car can do and decide whether your car is lacking or needs any additions.
When you are canyon driving, you want a bit of understeer because its an inherently dangerous activity. Word to the wise. |
02-16-2004, 02:23 PM | #11 |
Member#: 17877
SCIC
Vehicle:2007 Exige S Storm Titanium |
Front strut bar
is optional IMHO, rear is more important. I have the 6-piece STI pink bits in back, so can't comment on how stiffer endlinks will perform. I would agree a performance alignment is needed, as is track time to learn how to drive. Not saying you can't, but everyone, repeat everyone, learns from practice. I'm nearly done with my suspension, only because I can't afford the Hipermax 2s. I need engine management right now. Other nice bits I've done are Cusco Ver II lower arm bar (replaced u-brace), Whiteline comfort ALK, SPT aluminum control arms, Whiteline steering rack bushings, Noltec front sway bar endlinks, Cusco 40mm rear strut/v-brace, Cusco fr strut brace, Cusco fr/rear sway bars (maybe Hotchkis soon), Tein FLEX, SSR Cs 16 X7.5 w/ Michelin Pilot Sports. Why didn't I go with S03s? Michelins are lighter and have a much stiffer sidewall. Why 16s? Light, light, light. Rotational weight is important for acceleration/deacceleration/handling (unsprung weight).
San |
02-16-2004, 03:15 PM | #12 | |
Top Scoob 002
Member#: 32771
BAIC
Re: Front strut bar
02-16-2004, 03:23 PM | #13 |
Member#: 17877
SCIC
I read
some negative threads about the "race" ALK. Not sure if that's the same as the "sport". I did the ALK and Cusco lower brace at the same time. I had the u-brace and Cusco brace for about two months or more. I took off the u-brace and noticed no difference, except for weight.
San |
02-16-2004, 03:48 PM | #14 |
Vehicle:OK buy Nates beans westcoastroasting.com |
The ALK comes in 3 flavors...race....sport....comfort.
The race uses a very hard bushing...too hard for me(perfect for tracked cars)....I have the sport which is a bit softer(I love it) and the 'comfort' was made by Whiteline at the request of members of this board for a more 'comfortable' for daily use. It uses the softest bushing. I would do the 'sport' if you have good roads where you are...unless there are a lot of expansion joints, like in concrete sectioned highways....which the comfort was made for |
02-16-2004, 04:09 PM | #15 |
Member#: 50872
SCIC
thanks guys for all the info and help. Here is another question...
Subaru has added a front under car brace to the MY01 wrx model, the oem brace does little for chassis and handling but fouls on the ALK, is it possible to upgrade the low brace or even run with out the brace with ALK to have a better set up?? |
02-16-2004, 04:36 PM | #16 |
Myself and oldmansan have removed the brace, run ALK's and the Cusco v2 lower arm bar.
Works good for me. |
02-16-2004, 04:39 PM | #17 |
Member#: 17684
Vehicle:1989 pathfinder rusted red |
i wouldnt do FST either...
Similar Threads | ||||
Canyon runners beware! | felonious | Southern California Impreza Club Forum -- SCIC | 68 | 05-19-2005 01:40 AM |
Hey you Canyon Runners, Poseurs, Slackers ! | makofoto | Southern California Impreza Club Forum -- SCIC | 35 | 06-24-2004 01:11 AM |
CANYON RUN CANYON RUN!! DECKER and PORTRARO!! | spicymsp | Southern California Impreza Club Forum -- SCIC | 175 | 04-29-2003 04:54 AM |
CANYON RUN (grand canyon that is)/meet | ferretboy | Southern California Impreza Club Forum -- SCIC | 1 | 12-16-2002 02:42 PM |
Canyon Runners Unite this Sunday! | Sauginius | Southern California Impreza Club Forum -- SCIC | 35 | 11-15-2000 06:04 PM |
