Welcome to the North American Subaru Impreza Owners Club Wednesday January 20, 2021
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > Technical Forum Archive
Old 05-04-2000, 06:41 PM   #1
Overtime
Member#: 1346
Exclamation Sick fascination...the lift kit? On an Impreza?
Call me nuts, but I wonder if anyone has taken the plunge and put the lift kit on the Impreza. I'm utterly fascinated by the idea of an RS up an inch or two. Especially since it would give more room for wheels/tires (I am correct on this, no?).
Yeah, I know, I was dropped on the head a few times as a kid.
Overtime is offline
Old 05-04-2000, 08:24 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Post
Just remember, even though the car rides and inch higher, that doesn't mean the wheel well got any wider, nor the fenders. Larger wheels mean smaller tires and the possibility of having to roll the fenders. It might look kinda neat, yes, but you're also altering the center of gravity and handling at the same time.
North Ursalia is offline
Old 05-04-2000, 08:57 PM   #3
Gambit
Member#: 102
Post
Jsut imagine an Outback Sport with no hatch. It's raised 20mm. However not my any lift kit though. Just taller springs.
Gambit is offline
Old 05-04-2000, 09:06 PM   #4
[email protected]
Member#: 67
1999 Outlasting
the competition.
Post
you can order the ground control coilover setup with 8" springs and be able to raise the car about a inch or so over stock
[email protected]
tom@kartboy is offline
Old 05-05-2000, 05:36 AM   #5
Overtime
Member#: 1346
Lightbulb
Good morning.
Hmm...the Scorpion lift kit says it's a body lift, which just raises up the body, but that 1.5 in. suspension lift can be acheived too.
Am I wrong to assume that the suspension lift will leave room for bigger tires?
Either way, it would be interesting to see.
Have a good one.
Overtime is offline
Old 05-05-2000, 03:16 PM   #6
Jake_S
Member#: 556
1999 BG9 Outback
Post
The Imp has no seperate body/frame. It's a unibody, thus you cannot use a conventional body lift,i.e. blocks that raise the body off of the frame.
Tha Scorpion kit, i beleive, uses longer springs to acheive lift.
Jake_S
Jake_S is offline
Old 05-06-2000, 09:54 AM   #7
Dustin
Member#: 1188
2007 FJ Cruiser
Post
The Scopion lift kit is a body lift. From what I've seen it is essentially blocks that go above the struts. They space the suspension down 2" from the body/frame. There is also a spring kit, that lifts the car 2". Check out www.autocaresubaru.com for the Scorpion lift kit. Take a look at http://web.one.net.au/~bybsubi/index.htm if you desire more lift.
Dustin is offline
Old 05-06-2000, 12:48 PM   #8
VALENTA
Member#: 888
2011 STI
Wink
I have a feeling one of the members in Canada, here in Montreal will atempt to raise his RS with his coilovers. I do not want to give his identity, but if he ever does it, I will make sure to take pictures.
I have a country house and we were angry last winter that we couldn't go into the trails since our RS was too low!
I have a feeling next winter, we won't have any problem!
Take care!
Jan
P.S. We were going to call it MONSTER RS!
[This message has been edited by VALENTA (edited May 06, 2000).]
VALENTA is offline
Old 05-06-2000, 07:14 PM   #9
WhiteH2O
Member#: 452
'06 Lexus GX470
'15 VW Golf TDI
Post
Hmmmmmm........ You going to make a kit?
WhiteH2O is offline
Old 05-06-2000, 07:47 PM   #10
VALENTA
Member#: 888
2011 STI
Wink
WhiteH2O, he has the ground control coil overs!
VALENTA is offline
Old 05-07-2000, 01:18 AM   #11
John2.5RS
Member#: 1140
2000 S201 #78, '95 L
'13 F150 Ecoboost
Smile
Imagine the size of wheels you could put on if you added the fiberglass 22b flared fenders and the scorpion lift kit! That would be one bad a$$ off road machine!
John2.5RS is offline
Old 02-08-2001, 09:14 PM   #12
Member#: 4094
Post
It's not mine, but I like it!
<IMG SRC="http://home.att.net/~rsmash/97sube.gif" border=0>
More here
Silver is offline
Quick: how the F do you get the gas linesoff the fuel filter on an Impreza? poison Off-Topic 55 03-20-2008 08:53 PM
I helped my friend install a lift kit on a jeep xj thechickencow Off-Topic 10 12-17-2005 06:12 PM
anti-lift kit on XT? maestro Brakes, Steering & Suspension 1 02-16-2004 04:58 PM
Shift Kit On an Impreza L?? N'CTRL Transmission (AT/MT) & Driveline 12 12-30-2003 03:11 AM
where is a good place to get an body kit for an impreza bakchoi Vancouver Impreza Club Forum -- VIC 11 09-03-2002 02:45 AM
