01-09-2003, 02:50 PM | #1 |
Member#: 10921
Vehicle:04 04 STi 12.8 @ 105 mph |
Performance stats for 04 WRX STi
I found this on the U.S WRX Sti
http://www.car-videos.com/performanc...?id1=169&id2=0 It says 0-60mph in 4.59 sec with a 1/4 mile in 13.4 @ 101 mph The STi is running 17.5 psi boost ! |
01-09-2003, 02:55 PM | #2 |
Member#: 25778
TXIC
Vehicle:2007 LGT blizack. eh? |
seems that site is a little off.
I don't see the EVO having a faster (almost even) 0-60 or 1/4 time like they claim. |
01-09-2003, 03:03 PM | #3 | |
Member#: 10921
He told me it runs 8.30s-8.40s@83 - 84 mph in the 1/8 mile bone stock. That would put it in the very very low 13s bone stock. He is legit. Soon the EVOs will be hitting the drag strips in numbers and there will be no dought to their speed. The EVO 7's were running low to mid 13s bone stock with decent drivers. The EVO8 should be just as fast. |
01-09-2003, 03:28 PM | #4 |
Member#: 14848
Vehicle:2007 Tribeca TS w/ 20" OZ's |
Forget the EVO, to have the STI and M5 mentioned in the same statistic comparison is an honor to all Subaru fans.
01-09-2003, 03:40 PM | #5 | |
The Godfather
Member#: 2
Vehicle:2015 STI Launch Ed. Rally Blue Pearl |
-Nick |
01-10-2003, 02:02 AM | #6 |
Member#: 21412
Vehicle:2005 WRX ice blue metallic |
The JDM Evo VII vs the JDM WRX STi, the Evo is quicker in a straight line. I've seen them pull a 12.9 stock vs low 13's for the STi. One that was dynoed here had 170awkw (about 220awhp stock).
On an Australian dyno, that is a huge number. Stock STi's rarely reach 130awkw (170awhp) on the dyno. Also stock WRX's on our dynos put out less than 130awhp. Adam |
01-10-2003, 02:06 AM | #7 | |
Member#: 25778
TXIC
01-10-2003, 05:17 AM | #8 | |
Member#: 21412
seems that site is a little off. I don't see the EVO having a faster (almost even) 0-60 or 1/4 time like they claim. |
01-10-2003, 05:25 AM | #9 |
Member#: 5489
Vehicle:2013 FR-S AVO Orange |
Which STi? Bug-eye or the restyle? The restyle is much stronger and faster than the bugeye.
And dyno results are misleading - the dyno's are usually set up for a fan that blows over the front of the car only, with the hood open. That tends to put the STi/WRX at a disadvantage, since the TMIC draws air from the top, not the front. Tommy Kaira estimates about a 15hp loss because of that. Cheers, Paul Hansen |
01-10-2003, 06:05 AM | #10 | |
Member#: 21412
Adam |
01-10-2003, 08:16 AM | #11 |
Member#: 10921
One important point is you can't really go by these 0-60mph times. AWD cars arfe extremely driver dependent. If you gave the same EVO to two different drivers one driver may pull a 4.5 sec 0-60mph while the other driver may only pull 5.0 sec 0-60 mph.
I would have to bet that when Car and Driver/ Motor Trend etc get ahold of the New Sti / Evo's they will probably run in the low 5 sec range 0-60mph. Give me a new Sti or EVO and I garentee I could pull a mid 4 sec 0-60mph. Example. I was reading a recent mag at the airport and they were reviewing the 03WRX. They only ran 6.2 sec 0-60mph with a 14.7 sec 1/4 mile. Car and driver last year ran 5.4 sec 0-60mph in an 02 WRX. Thats close to a full second difference. Thats huge. Its all about the driver. Car and Driver just recently ran 14.0@ 98mph and 5.5 sec 0-60mph in the Club C WRX Sti with 276hp. They ran faster in the stock 227hp WRX vs the 276hp Sti. So you can't always pay attention to these numbers. |
01-10-2003, 08:39 AM | #12 | |
Member#: 11237
Vehicle:2002 WRX Wagon Silver |
Dunno if it was a different driver or temp/track conditions that contributed to that. |
01-10-2003, 09:20 AM | #13 |
Member#: 31625
If you check carefully, now there is often notes at the bottom of C&D, R&T that mentions how they have manages their 0-60. I should check at home for the magazine name but they now tend to do "realistic" test drives. I remember R&T testing the Eagle Talon a few years ago and dropping the clutch at 6000RPM to manage the best 0-60 times... Now they tend to for example slip the clutch from 3000RPM. That gives a more realistic test. That's something to consider when reading 0-60.
Sylvain |
01-10-2003, 09:39 AM | #14 | |
Member#: 11237
01-10-2003, 10:01 AM | #15 |
Member#: 31625
I'm sure a very small amount of people would drop the clutch at 6000RPM... About 5 years ago, they were power-shifting, if they were in the redline nothing was a problem or even mentionned. They were just test driving to know the best possible 0-60 times and no matter what, when checking 0-60 times, everybody knew they had to add a few .2-.3 seconds... Now they are doing more realistic tests and i'm sure people prefer that.
Anyway, the STi will be fast, real-fast. Sylvain |
01-10-2003, 10:36 AM | #16 |
Member#: 21297
Vehicle:2005 Legacy GT LT Atlantic Blue Pearl |
The other thing you guys forget too is that no two cars come of the assembly line the same. Just because they rate the engines in a WRX for instance at 227hp, that is what the nominal power should be. Because of manufacturing variations your gonna get some weak ones, and some stronger ones. Also keep in mind that each car they test has had varying amounts of breakin. Some come green with only a few hundred miles, and others come well abused.
But to make a long story short, all the cars are going to perform in some range of speeds, no two will be exactly the same when it comes to breaking/acceleration handling, heck even A/C cooling capacity. Its just like CPU's all come off the same assembly line and some are just better overclockers than others. If you read in one of their recent issues, they actually compensate for differences in temperature, humidity, altitude, wind speed etc. So differences between cars is really just that different cars, and since they use only a couple of drivers doing multiple 0-60 1/4 mile runs, and they take the best 3 out of 10 usually. Simple fact some cars will run slower just becasue they don't meet spec, some cars will run faster becasue they are better than spec. Of course Subaru would never give a Primo cherry picked car for a test would it? then when they get on for the long term test it isn't possible they got an average or belowe average car? |
01-10-2003, 10:46 AM | #17 |
Member#: 10607
RMIC
Vehicle:'17 JKU Rubicon |
WHO CARES? just wait until they actually show up and someone gets real numbers. until then, i don't see how anyone can say "there is no way the STi will be quicker" or "i can't see the EVO having equal (or even close) numbers". in reality, the EVO has probably been underrated from the factory for a long time due to the "276bhp agreement" in Japan.
geez, people. have some freakin patience. and sheeesh, high 12s vs. low 13s? come on, as if you can tell the difference anywhere besides a drag strip, a place neither of these cars is designed for. both are WAAAAY faster than almost anything else around. (except for the SRT-4, of course.) in other news, the STi seems to be pretty much the most popular topic on most car boards (not just Sube and Mitsu forums). |
01-10-2003, 02:27 PM | #18 | |
Member#: 25778
TXIC
Sorry, from now on we won't post unless it's something that is a known fact. kthx |
01-10-2003, 04:31 PM | #19 |
Member#: 10607
RMIC
did you see this?
for you new internet users, that means the person is not really upset. i was (mostly) kidding. <--- see? |
Similar Threads | ||||
WTB:Willing to trade fully built block performance parts for 04-05 sti transmission! | mostwantedsti | Private 'Wanted' Classifieds | 0 | 01-30-2009 11:04 AM |
Reputable and Popular Performance sites for 04-05 STI? | Boostlag | Newbies & FAQs | 6 | 12-24-2007 12:07 AM |
Good performance strut for 04 WRX? | DickWRX | Brakes, Steering & Suspension | 13 | 12-17-2004 08:27 AM |
WTB performance parts for 04 wrx wagon | subaru_wrxwagon | Private 'Wanted' Classifieds | 5 | 11-05-2004 09:15 AM |
DC/MD/VA WTT 02 WRX seats for 04+ WRX/STi Seats | MYTRX | Private 'For Sale' Classifieds | 1 | 10-05-2004 03:01 PM |
