Brakes & Suspension Forum sponsored by The Tire Rack |
11-28-2001, 06:35 PM | #1 |
Member#: 2847
Vehicle:'01 4x4 Ranger '01 RS gone :( |
Put the RE-92s back on and now they feel out of wack.
I had my RE-92s stored for about two months stacked on top of each other. I put them on last night and today when I hit about 65-70 mph they start to shake like they are out of ballence. Are they screwed, or what?
I also would like to avoid the same issues with my new set of SO-3s so does anyone have any good ways to store them? Thanks for any info. Ben
11-28-2001, 07:16 PM | #2 |
Member#: 12221
Vehicle:2002 wrx wagon wr blue |
I think its better to store tires on their tread rather than on their sidewall.
11-28-2001, 07:25 PM | #3 |
Member#: 1352
Vehicle:2005 Forester XT black |
I would do a visual check to see if any of the balance weights may have fallen off. Then re-torque the wheels to make sure they are seated properly. Are the tires on the front now the ones that were on the rear previously? Out of balance rear wheels sometime don't obviously vibrate until you run 'em up front. Hope this helps. If all else fails just rebalance the suckers! I don't think storage "stacked" will hurt the mighty RE92!
11-28-2001, 10:38 PM | #4 |
Member#: 2847
I did switch them front to rear, hhmmm. Ill have it checked out. Is it a good idea to rotate them while they are just sitting around, or does it matter? Thanks a lot.
Ben |
11-29-2001, 02:09 AM | #5 |
Member#: 11693
Vehicle:2002 WRX PSM |
I think tires would be ok stacked for a few months at a time. I've seen tire distributors store unmounted tires stacked up to 10 high. So if you have tires on rims with air in 'em I can't see how 4 stacked up would be a problem. After all, they are made to support your 3000 lb car.
wrecked, now camber way out of wack | Irate | Brakes, Steering & Suspension | 2 | 05-11-2005 12:36 AM |
Put the prodrive muffler back on | mtb_dude | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 7 | 06-21-2003 12:37 PM |
Uppipe installed - Trick to putting the Inter-Cooler back on | Mattr762 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 03-28-2003 11:20 PM |
AAargh! They didn't put the 4EAT pan back on properly! | remarcable | Transmission (AT/MT) & Driveline | 4 | 12-06-2001 08:15 AM |
Drive X-country on the Nokians, or put RE-92s back on? | Siper2 | Brakes, Steering & Suspension | 19 | 02-22-2001 10:50 AM |
