06-05-2012, 04:34 PM | #5701 |
Member#: 139853
Vehicle:2002 wrx....its tsxy silver |
If you have a front mount, why not toss a single row led bar in the scoop. You can easily cram a 10" or a few of the Rigid Ind. square dually's or visionx Solstice's.
06-06-2012, 08:07 AM | #5702 | |
Member#: 9369
Vehicle:F#ck U & Your Stance BLOD |
I wonder how the hood would hold up to the added weight of those lights. |
06-06-2012, 10:50 AM | #5703 | |
Member#: 22303
SCIC
Vehicle:2002 WRX Wagon WRB 2006 W211 e55 AMG White |
06-06-2012, 10:59 AM | #5704 |
Member#: 139853
If you still have it you can modify the splitter. While they do add weight, use a 10" bar for example, it won't make it much heavier. You really only have to be gentle when closing the hood...so slamming
06-06-2012, 10:59 AM | #5705 |
Member#: 9369
Only problem I may run into is I no longer have those mounts. I removed them when I installed the FMIC. Does not mean I can't have something fabbed up though.
How hot do those LED bars get? Edit: Maybe go with the 10" LED bar in the scoop and then a 26" bar in the FMIC opening at the top portion of the opening. |
06-06-2012, 12:18 PM | #5706 | |
Member#: 296248
RMIC
Vehicle:2005 wrx wrb |
06-06-2012, 01:06 PM | #5707 |
Member#: 9369
Yep, around a grand for one of those.
06-06-2012, 01:08 PM | #5708 |
Member#: 139853
they can get pretty hot if left on for a prolonged periods. So long as there you are moving when used and there is adequate airflow over the heatsinks you should be ok.
06-06-2012, 01:09 PM | #5709 |
Member#: 9369
Cool, thanks. I just wanted to make sure it would not melt anything.
On another note, what the largest size light you can fit in the standard 02 WRX driving light location? |
06-06-2012, 01:29 PM | #5710 |
Member#: 135252
Vehicle:2002 WRX Wagon |
LED's die a quick death when overheated, and I don't know how the heat from the engine bay will affect them.
06-06-2012, 01:46 PM | #5711 | |
Member#: 280844
TXIC
Vehicle:2006 STi OBP |
06-06-2012, 04:50 PM | #5712 |
Member#: 139853
06-20-2012, 04:14 PM | #5713 |
Member#: 210984
VIC
Vehicle:2009 WRX 265 OBP |
Does anyone have the dimensions of the rally innovations light bar for a 2009 wrx. Im looking to make one and wanted to see what I needed..
06-21-2012, 10:12 AM | #5714 | |
Member#: 296248
RMIC
06-23-2012, 12:41 AM | #5715 | |
Member#: 139853
...you shouldn't need them for too long while sitting still with them on. Even if you do, they do take a bit of time to get the hot hot. And well.....one might assume if ya shell out this much coin for a lamp....you might know to not let them get hot. |
06-23-2012, 12:52 PM | #5716 |
Member#: 135252
06-23-2012, 02:36 PM | #5717 |
Member#: 167252
Vehicle:2002 OBS Wagon Midnight Blue |
A note on the hood scoop mounting location ...
Check your local state laws on auxiliary lighting. Two things to look at:
06-23-2012, 03:22 PM | #5718 |
Member#: 135252
^^ The idiots around here aren't stopped by the law when they put HID's in their halogen headlights, fog lights, and wherever else they can cram them into.
06-23-2012, 03:25 PM | #5719 | |
Member#: 296248
RMIC
06-23-2012, 03:29 PM | #5720 | |
Member#: 296248
RMIC
06-23-2012, 05:55 PM | #5721 |
Member#: 135252
It's easy to tell. If you're blinded by the light, it's likely illegal. There are only a handful of cars that ever came with HID's in reflector housings from the factory. ALL other ones use projectors.
06-23-2012, 06:25 PM | #5722 |
Member#: 296248
RMIC
But how many cops know this stuff? On my little integra I did hids and they were kinda blinding but my Lexus gs had hids and they were HELLA HELLA blinding!!!! Way worse then my integra
06-23-2012, 06:36 PM | #5723 | |
Member#: 281811
NESIC
Vehicle:04 WRX World Rally Blue |
Seriously though, I don't get why people complain about HIDs so much, sure, some are very annoying, but you can't tell me that factory HIDs aren't blinding. Sure once they're up close the glare is reduced, but I have seen some cars (mainly Cadillac) from a distance that seemed to glare like crazy and were insanely blue, until they got up close.... What I'm saying is that yes, HIDs can be blinding, but in the majority of projectors that aren't any worse than stock HIDs. /flameshield |
06-23-2012, 10:49 PM | #5724 |
Member#: 135252
Dude, projectors are DESIGNED for HID's. Halogen reflectors are designed for, you guessed it, halogen lamps. An HID in a halogen projector = light EVERYWHERE.
06-23-2012, 10:57 PM | #5725 |
Member#: 139955
NESIC
Vehicle:2015 Subaru STI 17Forester / 18Crosstrek |
Anyone have issues with lamps mounted with the Kartboy brackets being pointed too low? The back of the lamp is touching the bracket and I cant aim it any higher, and it is way too low.
DRT Components Skid Guard Kartboy Brackets Hella 500s |
The Ultimate Bulb Lighting Thread: All You Ever Need to Know About Bulbs | Yesitsdrew5310 | Electrical & Lighting | 616 | 03-09-2024 10:09 PM |
The Ultimate DIY Water/Alc Injection Thread | hippy | Water/Methanol Injection, Nitrous & Intercooler Cooling | 33 | 03-08-2008 03:11 AM |
My new Hella FF200 Driving Lights and mounts | wrxinfx | Electrical & Lighting | 14 | 04-17-2005 12:24 PM |
WTB: WRX or Impreza RS (old school) fog lights and mounting brackets. | Yamaha600Biker | Private 'Wanted' Classifieds | 2 | 06-08-2004 03:37 PM |
