03-10-2014, 09:27 AM | #601 |
Member#: 65831
South East
Vehicle:91 Miata. Hey you can f* short girls in one |
They are not the same. And the problem is more that there will be dark spots and bright spots and the likelyhood of blinding people that are driving towards you is very high.
03-15-2015, 08:52 PM | #602 |
Member#: 416041
Just make sure 55w ballest don't melt your housings headlights are usually fine but dogs tend to burn
03-20-2015, 10:38 AM | #603 |
Member#: 198067
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
The ballasts are not in the housings. 55w is the same as the halogens.
The HIDs produce more light, and should produce less heat. I'd be more concerned with glare. |
10-23-2015, 11:45 AM | #604 |
Member#: 425569
Vehicle:2013 WRX Orange |
I saw a website where you can send your oem headlights and they will modify them with several different options. I can't for the life of me remember what it was. We have a 2013 WRX and tried putting Osram Sylvania Silverstar Ultras in. They suck. Distance is better but still not bright enough. Any help on the website to customize would be helpful.
10-23-2015, 03:37 PM | #605 | |
Member#: 370122
11-02-2015, 05:21 PM | #606 |
Member#: 432256
Vehicle:2002 WRX WRB |
Hey I've been searching for close to two hours for the guide to wiring JDM headlights into a bugeye. I didn't want to create a huge post about it, just need a like to it so I can fix my high beams.
TIA.. I hate being the plunger and bringing up old ****, but I'm worn out with searching.. |
12-04-2015, 09:53 PM | #607 |
Member#: 435526
Any opinions on running 35W vs 50 W HIDs? Can a 2014 Impreza handle the higher wattage?
12-06-2015, 09:07 AM | #608 |
Member#: 198067
12-11-2015, 10:55 AM | #609 |
Member#: 435950
Vehicle:2002 Legacy (BH5) Blue |
very useful info. thanks guys. on that note..
I have a 02 legacy (BH) I got JDM headlights (HB3) I connected driver side light worked fine. once I connected passenger side only my ambers turned on and I lost foglights. when playing with wires I finally got the passenger light to turn on with figlights but then my driver side goes to high beam. wth! lol I was up till 1am lastnight breaking my head on it. any info/help will be greatly appreciated. |
12-15-2015, 03:20 PM | #610 |
Member#: 435950
Nevermind. All fixed. Blew a fuse. And was missing a ground from drivers side.
12-15-2015, 07:35 PM | #611 |
Member#: 370122
12-22-2015, 07:23 PM | #612 |
Member#: 198067
12-23-2015, 04:26 PM | #613 |
Member#: 436655
NWIC
Vehicle:2015 Impreza Sport Blue |
Hey guys. My names Dan and im new to the forum. I just bought my first new car and first subaru. I got the 2015 impreza sport, and just ordered some DDM Tuning 35w HID kit. Wish i had read all these comments before ordering though.
Being that im a total noob, do you guys have any tips/tricks on installing the kit? Any advice would help. Thanks for the time! |
12-23-2015, 04:41 PM | #614 |
Member#: 181064
BAIC
Vehicle:00' 2.5RS BRP |
Yes, Dont even install them. You'll have better output by returning them and saving up to buy some HID projectors. DDM is crap from china.
12-25-2015, 01:54 AM | #615 | |
Member#: 43815
TXIC
Vehicle:2018 Model 3 LR RWD 2017 Mazda CX-5 GT |
12-25-2015, 07:50 AM | #616 | |
Member#: 370122
12-25-2015, 10:01 AM | #617 | |
Member#: 198067
I've been using an HID kit for nearly 7 years in my 2009 Impreza. It has halogen projectors. I have not had any problems with the kit. There are hot spots with the projectors. The light does not go high to the left or shine in other drivers windows. I have never been flashed.
The pattern shown with the H11rc bulbs with the halogen reflectors is similar to my projectors. I don't understand your comment "lose output". A retrofit would be better. The pictures in that thread were less than 10 from a wall. Chinese quality varies from different companies. Quote:
12-25-2015, 11:55 AM | #618 | |
Member#: 370122
If you'd like to learn some things about lighting, go to Hidplanet.com |
12-25-2015, 12:36 PM | #619 | |
Member#: 198067
The above is my HID Kit in a 2009 Impreza with halogen projectors. |
12-25-2015, 12:46 PM | #620 |
Member#: 370122
That's quite dull. I would show mine as an example, but I apparently can't just pull photos from my phone to put on NASIOC. I guess that explains why I rarely post here.
The source of light is in and entirely different spot between HIDs and halogens. A lot of research and development goes into making a good set of projectors. Even between different types of halogens, and different types of HIDs, things change. Hence, why they're designed to not be cross compatible |
12-25-2015, 01:13 PM | #621 | |
Member#: 198067
I'm in agreement that the source of the light is different. This kit
http://deautokey.com/product/h11rc-x...lar-xenon-bulb reduces the length of the HID source light. My dim bulbs produce much more light than the original halogens did. Quote:
12-25-2015, 01:16 PM | #622 |
Member#: 370122
I see that, but it's still not in the proper position. Also, HIDs face in a different direction than halogen filaments, and the hot spots of the source are different. Again, Hidplanet.com has a "University" sub-forum that you should look at
12-25-2015, 06:19 PM | #623 |
Member#: 198067
If it doesn't put the light into other drivers windows, and it doesn't cause others to flash, I'm willing to use them.
01-07-2016, 01:29 AM | #624 | |
Member#: 436655
NWIC
I just got them in the mail today and youre right. The packaging was already beat up by the time it got to my place from china. Im definitely going to try and return these |
01-21-2016, 10:38 AM | #625 |
Member#: 198067
The H11 halogen filament and the kit's HID arc are both longitudinally aligned.
AKIC FAQ Please read before starting new threads... | Kiwi Fella | Alaskan Impreza Club Forum -- AKIC | 2 | 02-18-2011 08:24 PM |
The Rules! Please Read Before Posting! | SQUAD_907 | AKIC Private Classifieds | 1 | 01-10-2009 04:59 AM |
Attention! Read before posting in any Scammer threads! | Mulder | Scammer Central | 0 | 08-11-2008 07:03 PM |
Welcome to the Subiesport Forum -- Read before posting! | ricochet | Grassroots Motorsports Magazine Forum | 2 | 08-15-2006 08:37 PM |
