09-23-2010, 09:25 PM | #426 |
Member#: 21038
South East
Vehicle:05 STi CGM 08 WRX 5D SSM |
Unfortunately, no. There are some that do come close, Silverstars are the only ones that come to my age adled mind, that info is in this thread somewhere, but it comes at a cost. They are more expensive and don't last as long.
09-25-2010, 10:31 PM | #427 |
Member#: 248293
Vehicle:2010 2.5i hatch SSM |
I know which thread you're speaking of. I looked at it. It's not worth it. I've been given a ste for HID conversion. I might order off there unless a place like LightWerks can do it.
09-25-2010, 10:37 PM | #428 |
Member#: 21038
South East
Just make sure it's a true 'conversion', not just the bulb & ballast put into a halogen housing.
09-27-2010, 10:21 AM | #429 |
Member#: 248293
I'll keep that in mind so I don't mess up the housing.
11-08-2010, 09:39 PM | #430 |
Member#: 259737
NWIC
Vehicle:2011 Impreza WRX 5dr |
Got an appointment to fix a fog light kit on my standard 2011 wrx at the service dept. Question," the service tech said that he could add a HID kit for 280 & 99 for the install. Is this a decent price and would this include the housing as well or is it just the bulbs in the halogen housing. Anyone else done this already?
11-08-2010, 10:53 PM | #431 | |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
11-09-2010, 02:13 AM | #432 |
Member#: 230795
Vehicle:2011 Impreza WRX 5dr WR Blue Pearl |
Agreed here as well. The prices are good but the OEM fogs are NOT designed to handle HIDs. The housings are too small to handle the heat generated by the HID capsules and I'd my memory serves me right they are plastic - a bod combination. Install a set of aftermarket fogs like the Piaa or Hella. They run about $600 a set plus installation.
11-09-2010, 11:26 PM | #433 | ||
Member#: 106225
Vehicle:02 WRX STied PSM 03 L, 05 GT Legacy Wagons |
However, HIDs in foglights, even if used in good quality HID fog optics, (which really don't exist) are not good a good idea. High capsule temperatures are the least of the concerns. There are plenty of reasons why no OEM uses factory HID fog lights. Hella doesn't even sell any HID fog lights, they know better as well. PIAA on the other hand is only half a step above the EBay Chinese HID kits. They sell the most overly priced, horrible quality lighting parts on the market. If you care for more information on why HIDs are bad in foglights you can read these... http://www.danielsternlighting.com/t...fog_lamps.html http://www.danielsternlighting.com/t...dvantages.html http://www.danielsternlighting.com/t...ght_color.html Quote:
Now, you really don't want HIDs in your fogs for many reasons, even if it wasn't such a rip off. Read those articles I posted above, and this one... http://www.danielsternlighting.com/t...nversions.html Even if it was a good modification, you could get the same thing on Ebay for $50. Just to clarify something, this is at the dealer's service department, that is offering this to you? What dealer is this? I just can't imagine a dealer selling something so terrible, not to mention illegal. I don't know what your local vehicle inspection laws are like, but If the dealer is also an inspection station, like most are around here, this is a serious legal issue. They can't pass vehicles after they have put those junk HID kits in them. Last edited by FourOnTheFloor65; 11-10-2010 at 01:38 AM. Reason: spelling error |
11-10-2010, 01:04 AM | #434 |
Member#: 259737
NWIC
Maybe I should have worded my question better. I am getting the fog light kit from subaru installed on the car since I had ordered it with the car but it was not installed at the port and has to be done at the dealer.
When I was inquiring about a HID kit for the main lights the service tech told me that he could order one for 280 and install that as well when he works on the fog lights. Sorry for any confusion. So is the HID light setup for the main beam illegal in Seattle? If not is it possible that the HID kit is the one that gets installed on the 2011 premium WRX'? @fouronthefloor65 - filled out my profile. |
11-10-2010, 01:34 AM | #435 |
Member#: 106225
Thanks for filling it in.
It is illegal in all US states, and every developed country in the world for that matter, to put an HID kit in halogen headlights, fog lights, driving lights, back up lights, dome lights, whatever. You didn't read those articles did you? What the Premium WRX and STi have are completely different optics that are designed for HID. HIDs produce light in a totally different way, than halogen bulbs. The optics (reflectors, lenses, or other light controlling devices), are totally different between HID and halogen. The two different light sources are not interchangeable. These kits are extreemly low quality, dangerous garbage. Just because they allow you to physically fit an HID light source into a halogen headlight does not mean they work correctly, be safe, reliable, or legal. If you want to see better for cheap, and search for H9 swap. If you truly want HIDs you should have bought a Premium, but you can always buy a set of used Premium or STi headlights and a wiring kit from www.lightwerkz.net. You could get them new from the dealer, but you don't want to know how much they cost. There is also the option of doing or paying someone to do a proper retrofit, where the entire projector is replaced with one that is designed for HIDs. Lightwerks also does these. A retrofit is not technically legal either, but if done properly, it will be perfectly save, and look just like the car came that way. No one will ever know. Last edited by FourOnTheFloor65; 11-10-2010 at 01:40 AM. |
11-10-2010, 02:15 AM | #436 |
Member#: 259737
NWIC
Thanks for the response. I wonder what the service guy is trying to sell me or if he even knows since they ordered the wrong fog light kit the first time around.
Didn't want to pay all that extra moolah for the premium to just get the HIDs. Will look into the two options that u have shared. |
11-11-2010, 09:10 AM | #437 |
Member#: 198067
Vehicle:2009 IMPREZA 2.5i 4d WHITE Premium |
TRS has a retro fit kit for $330. They are plug and play using
Morimoto Mini HID Projectors. http://www.3gwrx.com/forum/index.php?topic=14903.0 |
11-17-2010, 04:14 AM | #438 |
Top Scoob 015
Member#: 18175
Vehicle:99 STI RA Ltd #450 WRB blue |
what is the best or average bought semi-cheap HID for crystal GC headlights? i'm interested in a set but i keep hearing that it's not good to get HID for these headlights.
there are many GC8 over here on Okinawa that has HID. some were bought off of ebay. |
11-26-2010, 06:10 AM | #439 |
Member#: 235649
SCIC
Vehicle:2003 WRX PSM |
I'm making a harness for my bug eye jdm hid with OEM parts. Here is a picture
Do I need a fuse between anywhere although I'm using oe parts Also the high beam is the top light correct? TIA |
11-26-2010, 10:52 PM | #440 |
Member#: 21038
South East
^That is a good question, I was trying to wire Morette HID's into an '03, but couldn't figure it out for myself, and I couldn't find a working schematic on line either. They are still not on the car.
11-27-2010, 10:43 AM | #441 |
Member#: 235649
SCIC
Well with my observations you don't. I see it like this. With wire harness I made I'm only using the common positive on the headlight plug and then grounding the ballast so there is no heavy draw. Each headlight has its on individual harness unlike most other harnesses. No direct hook up to the Battery
I hooked up my jdms last night and it all works perfect. |
11-28-2010, 10:10 PM | #442 | |
Member#: 21038
South East
I, unfortunately, have no harness to start with. The car was wrecked, they put different headlights on the car, (long insurance story) and threw away the original harnesses. |
11-28-2010, 10:21 PM | #443 |
Member#: 230795
Another point for considering a direct battery connection with the use of a relay - - the HIDs can draw up to 20 amps momentary current when the lights are first turned on and the ignition voltage is applied to the lamps to strike the arc. And yes, one should always ensure a fuse is installed somewhere in the supply voltage line (whether it's in the fuse box or fuse panel for OEM installations or an add-on in the wire from the battery).
11-28-2010, 10:50 PM | #444 |
Member#: 235649
SCIC
So that fuse box fuse is not enough?
Also I tired doing a wire harness with a relay but the hids were coming on so as I touch the battery and I wasn't able to figure out why. Thats why I opted to the above harness. I still need to wire hi. Should I add the fuse between the common power? |
11-28-2010, 11:44 PM | #445 | |
Member#: 230795
Hope this helps. |
02-23-2011, 11:38 PM | #446 |
Member#: 274931
NWIC
Vehicle:00 legacy "BE" burch white |
97 legacy 2.5 gt hid ?
I am a new member here. traded my bmw for the subaru.
they guy a got the subaru was a member on here. My headlights are not oem they are the jdm 1 peice headlights. my ? is where do u plug the balast in at? they all go into that 1 plug, if any one could help me. correct me if i am wrong, they are h1s in the low beam correct. i just do not understand how to plug the balast in |
02-24-2011, 06:57 AM | #447 | |
Member#: 21038
South East
02-26-2011, 05:21 PM | #448 |
Member#: 274891
Vehicle:2010 Impreza Camelion Red |
anyone put and HID kit on the 09+ models? I was just about to get a set and some one told me that they are a hassle to put on because of some modulator? I have put on a couple plug & play sets myself just dont want to bite more than I can chew> anyone>anyone.
02-27-2011, 09:07 PM | #449 |
Member#: 21038
South East
See the post above yours...
03-14-2011, 03:33 PM | #450 |
Member#: 267974
South East
Vehicle:2008 Legacy 2.5i OBP |
Has anyone ever heard of someone wrecking their car because they were "blinded" by someones HID kit? Im not defending HIDs(nor do I have them in my car) but I personally have never heard of anyone wrecking and seriously being injured but that doesnt mean its never happened..........just wondering if anyone has heard of that.
AKIC FAQ Please read before starting new threads... | Kiwi Fella | Alaskan Impreza Club Forum -- AKIC | 2 | 02-18-2011 08:24 PM |
The Rules! Please Read Before Posting! | SQUAD_907 | AKIC Private Classifieds | 1 | 01-10-2009 04:59 AM |
Attention! Read before posting in any Scammer threads! | Mulder | Scammer Central | 0 | 08-11-2008 07:03 PM |
Welcome to the Subiesport Forum -- Read before posting! | ricochet | Grassroots Motorsports Magazine Forum | 2 | 08-15-2006 08:37 PM |
