07-25-2013, 11:15 PM | #1 |
Member#: 339777
Vehicle:2007 WRX OBP |
2007 WRX Fog Lights
Hey guys, I recently noticed that both of my fog lights aren't working.
The green light doesn't illuminate any longer when I press the fog button. In the past it would sometimes flicker or go out if I hit any rough pavement while driving. Now it is completely dead. When I press the button, I hear a "click" which I assume is the relay functioning? I have done the following: Checked the fuse. It wasn't blown but I replaced it anyway. Made sure everything was connected properly. I have yet to replace the lights but I plan on it tomorrow. I just found it odd that both went at the same time, but I guess that anything is possible. I was wondering if there was anything else I should try? Otherwise I'll just replace the bulbs tomorrow and see what that brings.
07-25-2013, 11:34 PM | #2 |
Vehicle:OK buy Nates beans westcoastroasting.com |
pull the relay out and check the pins..see if any of them are discolored...it may be burnt and not working but still 'clicking'
07-25-2013, 11:42 PM | #3 |
Member#: 339777
Thanks I'll try that. I should be able to swap in another relay of the same kind to figure out if the current fog light relay is shot right?
07-26-2013, 01:46 PM | #4 |
Member#: 352689
Vehicle:2004 Impreza dark green but looks blak |
Troubleshooting by parts replacement is expensive. If you can specify exactly what car you have beyond Impreza I may be able to pull up a schematic.
07-26-2013, 10:32 PM | #5 |
Member#: 339777
It's a 2007 wrx sedan.
07-27-2013, 12:51 PM | #6 |
Member#: 352689
For an Impreza WRX (non STI) I show separate schematics labelled "headlights w/high inten discharge" (2 sheets) and one sheet W/O high inten discharge.
If you know which you have I can give you much more specific instructions. Both schematics show a fog light switch light as an incand. bulb and not an LED so the switch light could be burned out. On this same schematic LEDs are indicated as such with a separate symbol than incand. bulbs. |
