Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 02-01-2011, 01:10 PM   #1
Wileycyote
Member#: 268173
2003 WRX Wagon
Question Fuel Smell Repair Kit 10130aa000
I'm taking off my manifold to put in a new turbo inlet and decided to pick up the fuel smell repair kit ($34) and install that while I had the manifold off. Unfortunately the kit didn't come with instructions.
The kit inclued two gaskets for the manifold. a fuel rail 17544aa135, 2 small hoses 807707130 and one larger hose 807707140.
I did some searching to find instructions, but had no luck since most people take it to the dealer for the fix. I did find some instructions on scoobymods for the older kit, but it has only two pieces. I'm hoping I can figue it out when I have the manifold off.
Since I would like to do this myself and there dosn't seem to be a DIY I was hoping someone would know of where to find the instructions for this newer fix kit.
03 wrx stage 2
Thanks for the help
Wileycyote is offline   Reply With Quote
Old 02-01-2011, 02:13 PM   #2
Seventh
Member#: 263223
2011 WRX 5dr
SWP, 332ti
(1) Relieve fuel system pressure using the procedure from the appropriate model year repair manual under Engine section 22. Fuel. (MY 2002 page FU(DOHC TUBRO)-51, MY 2003 page FU(DOHC TUBRO)-54).
(2) Remove the intake manifold assembly as per repair manual Engine section 3. Intake manifold. (MY 2002 page FU(DOHC TUBRO)-15, MY 2003 page FU(DOHC TUBRO)-15).
Note:
The following photos show the updated fuel line and hose.
(3) Turn intake manifold on it side with the throttle body facing down on a clean work surface.
(4) Loosen the hose clamps at the ends of the steel line as shown below.
(5) To ease the removal of the steel line from the intake manifold, remove the 2 bolts holding the intake manifold wire harness protector.
(6) Remove the 3 line mounting bolts and then remove the line from the intake manifold.
(7) Install the new metal line using 3 new hoses from the kit and secure it to the manifold. The existing stainless steel clamps can be reused. Also re-install the wire harness protector bolts.
(8) After the new line and hoses have been installed, the intake manifold can be re-installed. Be sure to use the new intake manifold gaskets included in the campaign kit.
Seventh is offline   Reply With Quote
Old 02-01-2011, 02:34 PM   #3
Wileycyote
Member#: 268173
2003 WRX Wagon
Talking
Yah baby! Thanks for the kick a$$ reply. Just what the Dr. Ordered
Old 10-13-2011, 03:10 PM   #4
WR Boxer
Member#: 171395
2004 STi
Java Black Pearl
I know this is an old thread, but does anyone know if this repair kit will work on an 04 sti? Were there major differences in the intake manifolds or fuel rails?
WR Boxer is offline   Reply With Quote
Old 10-14-2011, 12:30 PM   #5
Cannibal
Member#: 133023
2005 WRX STi
I don't have an answer for you as to if this kit will work...I might have something better.
I had the fuel smell happen to me earlier this year on my '05 STi. I searched and searched to find out if anyone else had this problem. I remember finding lots of information about the earlier WRX's having the problem and Subaru coming out with a fix for it but nothing for the STi's. So I called up SOA, told them my problem, and they told me to take it to a dealer to see if the dealer could replicate. After a few tries at the dealership the problem finally happened while at the dealer. Here's the good part...the dealership then fixed the problem and Subaru paid for everything! So based on that, I would say call SOA before doing anything.
Cannibal is offline   Reply With Quote
Old 10-14-2011, 12:33 PM   #6
WR Boxer
Member#: 171395
2004 STi
Java Black Pearl
All of the dealerships in my area suck royal donkey nuts. So I will probably take my chances and see if I can't get the brand new lines to work for me. My leak is definitely coming from the lines that this kit will replace.
Old 01-11-2013, 05:58 AM   #7
Rymaster
Member#: 296277
2002 Impreza WRX
I gotta remember to do this when I put my 16g in
Rymaster is offline   Reply With Quote
Old 09-21-2014, 02:00 PM   #8
AeroBullet
Member#: 248148
Default Fits 05 WRX but fittings are different
This kit will fit an 05 WRX, but is unnecessary on an 05 since the leaky fittings in question are identical to the ones in the stock 05. Also, the upper fittings on the kit (shown in the last photo) are not the quick-disconnect style used on the 05. You would have to remove your quick disconnect fitting and install a new hose with a clamp going to the FPR for it to work.
Thanks so much Seventh for posting the photos and info. I ordered the kit for my 05 WRX and it helped me to finally get the fuel leak fixed. The only thing it is missing is the stainless hose clamps like the stock ones.
In my first attempt (without the kit), I bought some fuel line from the auto parts store and some generic hose clamps. I wanted to replace the hoses, not just tighten the clamps, to make sure the leaks were stopped.
I found that the hose I bought fit ok, but it was just slightly larger outer diameter. Then the hose clamps I got didn't clamp tight enough on the small hoses, so I just reused the stock clamps and got everything back together, but it still leaked. The hoses have to be exactly like stock for the clamps to work. So I got this kit.
In order to get the rubber hose on the right side to mount, you'll need to disconnect everything like the photos show, then slide the hose on the fuel rail as far as it will go. Now take the fuel lines and connect it to the hose while working the hose onto the lines. Not much room to work but you will get on there after some effort. The other 2 hoses on the left connect easily after that.
The kit was still great cuz it has the hoses and the gaskets but I didn't use the metal fuel line.
AeroBullet is offline   Reply With Quote
Old 11-18-2014, 01:35 PM   #9
massacremasses
Member#: 380004
2005 V7 EJ207 WRX
Old post I know, but everyone keeps saying the kit is $34. I went to that website and its $73.88 now Its cheaper on subarugenuineparts now..
http://www.subarupartswebsite.com/OE...0130AA000.html
massacremasses is offline   Reply With Quote
Old 11-18-2014, 02:29 PM   #10
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
FYI, this fuel-leak replacement kit is for the 2002 and 2003 [USDM] WRX only.
Old 11-18-2014, 02:38 PM   #11
massacremasses
Member#: 380004
2005 V7 EJ207 WRX
I have an 01-02 EJ207. Id imagine its the same.
Old 02-03-2015, 05:19 PM   #12
massacremasses
Member#: 380004
2005 V7 EJ207 WRX
It was...
In case anyone else stumbles upon this...
Old 10-05-2018, 04:33 PM   #13
Icarian
Member#: 492338
It was...
Thank you! I have an ej207 v8, I'm hoping this kit will work for me. Does anyone know if the gaskets supplied in this kit will work for my engine?
Icarian is offline   Reply With Quote
Old 04-24-2021, 09:55 AM   #14
Lazarus_2019
Member#: 509841
So assuming this wouldn't work on a JDM EJ205? Are the fuel lines and gaskets different between USDM and JDM?
Lazarus_2019 is offline   Reply With Quote
fuel smell and burning smell e_presley20 General Community 15 01-10-2011 03:11 PM
Hesitation/Jerking after Raw Fuel Smell Repair (09-36-03) Sputt Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-11-2009 05:36 PM
Raw fuel smell repair, now breaking ice sound? nich0lai Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 55 02-28-2007 06:17 PM
Has anyone done the fuel rail fix to eliminate the cold weather fuel smell? Snowphun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 11-01-2005 09:20 AM
Fuel Smell When Cold Out...Fuel Rail/Injectors? DJWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-22-2004 04:58 PM
