10-19-2020, 01:35 PM | #1 |
Member#: 491571
Vehicle:2003 WRX |
Shifter issue FA20DIT
Been awhile since I've posted, I've since sold my 2003 Bugeye and have owned a 2018 FA20 for awhile now.
So today on my lunch break I had to back out into the street fast and throw it in first and go, problem is I throw into first and actually was in third. Pulled into a gas station and I have to force it left more to get into first and going into second I have to keep force to the left. Other than that I don't feel any slip in tranny and runs fine ( no noise or anything when in first and second). What did I bend or break? My shifter boot even slid off my reverse lockout. It has the stock shifter and from what I was told also a perrin shift stop. Any help is appreciated. I was going to order a boomba short shifter but not sure if the shifter itself is the issue (want one either way) I tried searching Google to see if anyone else had this happen to them but I just get a lot of people talking about the sloppy stock shifter. Any and all help is appreciated to get me pointed in the right direction, thanks!!
10-19-2020, 01:52 PM | #2 |
Member#: 497677
Vehicle:2018 WRX Premium WRB |
Sounds like your shift stop got loose and needs to be readjusted/tightened.
You should set it up where 1st and 2nd gates are not hard to get into but tight enough to not go past them like the shifter was without a shift stop. Take off the shift boot and see what is going on under there. It should be easy to tell. |
10-19-2020, 02:55 PM | #3 | |
Member#: 491571
Vehicle:2003 WRX |
10-19-2020, 03:28 PM | #4 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
Those nuts (and the washers behind them) are removed and replaced in the process of installing the shift stop. I think they may have some loctite on them from the factory, but in any case it's a very good idea to put a drop of blue loctite on them so this doesn't happen. I did an inspection on mine not long after installing a shift stop and I found those nuts getting loose so I loctited them at that time.
An important note, do NOT over-tighten those nuts or the threads will snap off and you'll have a bigger problem. Just snug and let the loctite do its job. |
10-19-2020, 03:59 PM | #5 | |
Member#: 491571
Vehicle:2003 WRX |
10-20-2020, 01:36 PM | #6 |
Trust no one
Use the factory parts if you have them. If you use a nylock nut instead it shouldn't need loctite, the nylon thread accomplishes the same thing.
