Welcome to the North American Subaru Impreza Owners Club Friday March 29, 2024
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 05-19-2010, 11:25 AM   #1
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Exclamation Baja Turbos: What works with What? STICKY THIS!
Upgrading Bajas are a little frustrating, as we all know, because websites/manufactures are not clearly labeling their product as "Baja Compatible". We're forced to do more homework than other, and bounce ideas off others. While that seems fun for other, I find it slows down my work.
I'll start the list, and you reply with updates; then I'll update my main post for quick reference.
Here are some things to get started on:
*******************************Keep in mind the following******************************
If parts are coming off of other Subarus, make sure to list the year and series of vehicle. Also if a part has to be altered to fit, IE trimming; rewiring; welding; or cutting; NOTE IT with a DIY scale of 1-10. Picture are welcome too.
Top Mount Intercooler (TMIC)
1. USDM STi intercooler (2004-??) Fits a stock Baja turbo with modification to the 90" elbow between the turbo and Y-pipe. The length needs to be changed slightly. Also it requires the Sti or 2.0l wrx bypass valve, Y-pipe, bypass valve vac. line. The bypass valve hose that goes to the intake needs to come from an STI to clear the electronic throttle body. the hoodscoop shroud will no longer fit properly with any larger TMIC.
NOTE: sometimes while in reverse engine rock causes the intercooler to impact the clutch reservoir cap (5MT) a few shims under the mounting tabs where it bolts down will angle the rear up the intercooler up and solve this.
Tumble Generator Valve (TGV)
TGV Deletes
Fuel Injector
Throttle Body
Intake Manifold
Up Pipe
1. 02-07 WRX & STi are compatible, make sure to reinstall the EGT sensor
2. Bosal catless up pipe is a direct bolt on- It is essentially the same as the STI although it may have thicker flanges. Does not have EGT bung so the CEL will have to be turned off at the ECU or the resistor mod. It accepts OEM heat shielding.
Down Pipe
1. Random Technology makes one that is a perfect fit, NO modding (DIY Rating 2)
2. Helix Catless DP requires some cutting to fit (DIY Rating 3)
3. OAKOS Automotive downpipe fits the 5MT Baja turbo with no modification. It clears the brace on the firewall and everything. It is catless and 2.5" diameter.
Brakes
1. Front Brakes: The Baja shares the front brakes with the 2003-2005 WRX. Rotors and brake pads are directly interchangeable.
2006-2007 WRX 4 pots (red) and the older JDM 4 pots (gray) will bolt up (uses existing rotor) but will not clear the OEM wheel choices. Will need different wheels or wheel spacers.
2004 STI Brembo- direct bolt on, needs larger wheels for clearance. (Must be 2004 STi rotors as anything after that will have a different bolt pattern). May need to dust shields behind the rotors.
Rear Brakes- Baja has same rears as the outback H6. So anything pad or rotor listed for the "H6 rear" will bolt right up. There are some decent choices as this is used to be a pipular upgrade for 2.0 WRX guys back in the day.
Fuel Pump
OEM Radio Deck
Driver/Passenger Seat
Steering Wheel
Air Bags
Center Gauge Cluster (RPM, MPH, Temp)
Exhaust Manifold/ Equal or on Equal
Turbo Charger
1. STI turbocharger is a direct bolt on. It will fit the stock intercooler with some creative stretching and wiggling. But swapping in a proper length Y-pipe is best. Of course with the USDM STi intercooler and Y-pipe it is a perfect fit.
Radio Deck
1. Radio Deck- Basically anything Subaru the same year or older will fit the baja. I replaced the OEM 6 disc with a 2004 WRX head unit to add a tape deck. I also think the illumination matches a bit better.
Short Throw Shifter
1. Short throw shifters- anything for a Subaru 5MT (WRX, FXT, LGT) of the same model years will fit the Baja 5MT turbo or non-turbo. Anything from the SPT assembly to Kartboy lever or bushings.
Clutch
1. Clutches- 2004-2005 Baja turbo can use anything intended for a 2002-2005 WRX "pull style" clutch. 2006 Baja T is a "push style" and is compatible with 2006-2007 WRX (I do not know about later models)
Baja friendly websites:
http://www.ezsubaruparts.com
http://www.rallitek.com
honda killer is offline   Reply With Quote
Old 05-19-2010, 06:48 PM   #2
04wrexsti
Member#: 225937
15 Mustang GT
All subies gone
is there any accessports that work on a baja?
04wrexsti is offline   Reply With Quote
Old 05-19-2010, 07:24 PM   #3
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Default Baja Turbos: What works with What?
Nothing like the Cobb AP you see for the rest if the Subaru line. Some people have found a glitch (ecu transplant) to make one work; but I wouldn't reccomend it.
You can get a Baja open source tunered for $200-300. That's half the price of a used AP.
Subie_Sleeper has a lot of working knowledge whenit comes to ProTuning.
Sent from my iPhone using Tapatalk
Old 05-19-2010, 08:45 PM   #4
twheats1
Member#: 147722
11 Rug
00 R 1100RS
The WRX and Sti up pipes (up until model year 08) fit without any modification.
If you do not reinstall the EGT sensor you WILL have to either disable the code or do the resistor mod.
twheats1 is offline   Reply With Quote
Old 08-25-2020, 07:11 PM   #5
harleyjohn45
Member#: 507583
1957 Belair
Red
If you do not reinstall the EGT sensor you WILL have to either disable the code or do the resistor and it will not .
I just got my 2006 WRX up pipe for my 2006 Baja and It will not fit. Not even close. Mt Baja has a TD04-13 turbo.
harleyjohn45 is offline   Reply With Quote
Old 08-27-2020, 09:07 AM   #6
roadsterdoc
Member#: 48216
That *is* unexpected! Can you post pics of the flange of uppipe you were sent and the inlet of your turbine housing to show the differences?
roadsterdoc is offline   Reply With Quote
Old 09-04-2020, 09:24 PM   #7
harleyjohn45
Member#: 507583
1957 Belair
Red
Send me your email to [email protected] and I can send photos
Thank You
John
Does anyone know the phone number for JMP turbo repair.
Old 05-20-2010, 12:15 AM   #8
ascott13
Member#: 234966
2004 Baja Turbo
black/gunmetal
only certain Downpipes fit without alteration. i have a Helix catless DP and it required modification of the steel bracket at the back of the engine bay for clearance.
ascott13 is offline   Reply With Quote
Old 05-20-2010, 12:25 AM   #9
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Thanks updated
Old 05-20-2010, 04:51 PM   #10
ascott13
Member#: 234966
2004 Baja Turbo
black/gunmetal
i completely forgot the DIY scale on the cutting of the bracket for the helix DP. it wasn't hard, just annoying doing trial and error of whether i took enough material off, in the right place etc. if an oil change is a 1 and spark plugs are 5, i would say it would be a 2.5 - 3. it isn't hard as long as you have an angle grinder and the patience to grind the bracket and install the DP to test fit, drive it, find out you didn't remove enough material and pull the DP off and start over again a few times. my second removal was enough for me, and i was getting really good at pulling the DP loose at that point...
Old 05-20-2010, 11:02 PM   #11
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
updated
Old 05-21-2010, 11:54 AM   #12
PA-Outback2000
Member#: 161832
2000 Outback Limited
xcceleration.com does bajas. u avoiding b/c of prices?
PA-Outback2000 is offline   Reply With Quote
Old 05-21-2010, 03:44 PM   #13
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Sam has high prices but I was able to get a couple hundred dollars dropped....the DP and Turbo Back Exhaust for sale there is pricy because it has a High Flow CATs in the DP and Midpipe.
The advantage of purchasing his equipment is: you woun't have swaybar or hanger problems, that most baja drivers get.
Ohh and the $400 cutout can be bought straight from the vender for $189.
Old 05-28-2010, 09:27 AM   #14
swazz03
Member#: 229774
2006 Baja Turbo
Default downpipes for baja
ascott13 what yr model was the downpipe for . thanks
swazz03 is offline   Reply With Quote
Old 05-28-2010, 10:38 AM   #15
slagman
Member#: 214691
2005 Baja Turbo
What about headers?
slagman is offline   Reply With Quote
Old 05-28-2010, 03:38 PM   #16
Hawk296
Member#: 14555
1995 Impreza L
Baja
Based on only what I have tried/used on my baja:
Hawk296 is offline   Reply With Quote
Old 05-28-2010, 06:39 PM   #17
ascott13
Member#: 234966
2004 Baja Turbo
black/gunmetal
it's a helix catless downpipe for an 02 - 07 WRX fitment. as far as i know, the only downpipes that are different are the new WRX's and the 05+ Legacy GT's since their turbo's are mounted a bit differently.
also, does anyone know if there is a basic stage 2 open source map for the baja around? i can find one for just about every other turbo subaru except the baja...
Old 05-28-2010, 09:16 PM   #18
slagman
Member#: 214691
2005 Baja Turbo
i see headers that say will fit wrx, sti, and legacys, so i'm guessing headers for 2.5s are all the same except for newer models and should fit bajas?
Old 09-29-2016, 06:51 PM   #19
korrec26
Member#: 455559
Default I have trouble with my 03 baja
Need to reply to post my thread
korrec26 is offline   Reply With Quote
Old 06-02-2010, 10:50 AM   #20
honda killer
Member#: 239621
2005 Baja Turbo
Silver/Gun Metal
Updated
This week I'll try to clean up the tread and use links to specific threads; just to keep topics on track
Old 06-07-2010, 10:19 AM   #21
PA-Outback2000
Member#: 161832
just bite the bullet and have them do the car. it will be done once and right.
Old 06-23-2010, 09:20 AM   #22
swazz03
Member#: 229774
2006 Baja Turbo
Installed a Grimmspeed uppipe and a used PDE catted 3" to 2.5" downpipe on the Baja .Everything was a great fit. Took me several hours as this was my first time working on a car. Also put the 2.2 Kohm 1/2 watt resistor into the heat probe connector which took away the check engine light .
Old 06-26-2010, 06:20 PM   #23
BajaSleeper
Member#: 186725
2006 Baja Turbo
This should definitely turn into a sticky. I think this is incredibly useful for all baja owners.
BajaSleeper is offline   Reply With Quote
Old 07-13-2010, 09:48 AM   #24
swazz03
Member#: 229774
2006 Baja Turbo
The DBA 5000 rotors model 5010 fronts fit the baja .
Old 07-17-2010, 03:34 PM   #25
Mrjack55
Member#: 252222
2006 Baja Turbo
Thanks for this info. As a new Baja owner this kind of stuff is really helpful.
Mrjack55 is offline   Reply With Quote
clutch and flywheel what works with what?!?! scobaru Subaru Conversions 10 01-06-2005 10:21 PM
What Works with Borla Hush? HerculesPeanut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 06-28-2004 04:21 PM
ej20's and what works with what scobaru Subaru Conversions 4 10-24-2003 07:28 PM
Advan RG works with what brakes??? Subaruist Brakes, Steering & Suspension 1 10-22-2002 11:23 PM
Which cold air intakes work with what FMICs? Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-15-2002 07:55 AM
