07-28-2015, 03:33 PM | #2601 | |
Member#: 165749
Down side, I'm back on the Verizon antech POS. Wi-Fi streaming and data transfer on the network is mediocre at best.
07-28-2015, 08:38 PM | #2602 |
Member#: 36838
Vehicle:2001 B50 RSTi Sedan 2011 DGM WRX hatch |
OMFG, F THERMAL TAPE.
...and that's all I have to say about that *begins to mix thermal epoxy* |
07-28-2015, 09:35 PM | #2603 |
Member#: 17256
South East
Vehicle:18 Outback on the road.... |
07-28-2015, 09:41 PM | #2604 | |
Member#: 17256
South East
Then again, I had a couple small vram heat sinks fall off a video card once even though I followed the directions to the letter (degreasing, etc). It is pretty quick and easy to use though. |
07-29-2015, 12:13 AM | #2605 | ||
Member#: 145105
Vehicle:2015 Honda Accord |
I powered the router off all day while I was at work and connected it when I got home..... Working fine all evening (2.4Ghz and 5Ghz).. Weird. Quote:
Dang! 3 of them? Folding machines? Yeah I have the R4 case so it will fit (so I've read). |
07-29-2015, 01:01 AM | #2606 |
Member#: 36838
Well, this was more stressful than it should have been, but it's all done now...
Tomorrow I move into my new case as well, so I'll have some pics once it's all assembled. -- Dave |
07-29-2015, 07:04 AM | #2607 |
Member#: 21356
NESIC
Vehicle:2017 Subaru Corolla STI Limited SE-R Type (R) |
That is a lot of work for an old card.
Is this for a htpc or quiet pc? |
07-29-2015, 08:52 AM | #2608 |
Member#: 36838
07-29-2015, 08:57 AM | #2609 |
Member#: 17256
South East
I have one on my main desktop rig, which I use for everything, including folding. I have another desktop rig that mainly just folds (Win10 machine). I have an old folding rig that has been retired as well, with a D14 on it. They are really great air coolers, I think you will be happy. You may want to check if your memory will fit under the cooler.
07-29-2015, 12:17 PM | #2610 |
Member#: 36838
Meh... put the 680 back in and system won't power up with it installed... guess it didn't survive the heatsink-ectomy... not even sure how to try and troubleshoot this.
07-29-2015, 12:22 PM | #2611 |
Member#: 21356
NESIC
I take it it powers on without the card, just not with it?
Tried with it on the pci-e slot, but without power from the psu? (get a 970 ) |
07-29-2015, 12:25 PM | #2612 | |
Member#: 36838
I don't think the board was using anything on the heatplates for added ground... not sure what is up =P 970 isn't really an upgrade from the 680... I might aim a bit higher. |
07-29-2015, 01:18 PM | #2613 |
Member#: 36838
Futzed with it a bit... figured the VRM area was the only place any kind of electrical shorts could have happened.
Managed to pop off one of the heatsinks I epoxied on and noticed I didn't damage the chips below... slowly managed to wiggle each other heatsink off and clean up any epoxy that might have been bridging things. GPU works now with nothing on the VRM chipests... so clearly I have to be more careful when I re-epoxy these back on (cleaning the epoxy off of the heatsinks will be hell). Much better temps before/after: Last edited by AcquaCow; 07-29-2015 at 01:34 PM. |
07-29-2015, 02:41 PM | #2614 | |
Member#: 17256
South East
I would check carefully around the power cord connectors and make sure you have not broken one of the hard metal connectors. Can you remove the heatsink and AS and put it back on with new compound? |
07-29-2015, 03:11 PM | #2615 | |
Member#: 17256
South East
07-29-2015, 03:15 PM | #2616 |
Member#: 279660
That's a nice drop in temp. Nice work.
07-29-2015, 05:19 PM | #2617 | |
Member#: 332955
NWIC
Vehicle:1994 Accord 5MT |
07-29-2015, 06:16 PM | #2618 |
Member#: 145105
07-29-2015, 11:25 PM | #2619 |
Member#: 36838
Regluing the vrm heatsinks on right now... Used 1/2 as much epoxy this time.
Edit: success! Up and running! Last edited by AcquaCow; 07-29-2015 at 11:48 PM. |
07-29-2015, 11:53 PM | #2620 | |
Member#: 36838
I'm also not sure with all the other airflow I have in my case, how much this was fighting against any of my other fans... I seem to have enough airflow out the top/back that I find a lot of dust stuck to the back of the PCI-e slots on my case due to all the air being pulled in there. |
07-30-2015, 12:13 AM | #2621 |
Member#: 195061
NWIC
Vehicle:1997 ¯\_(ツ) Green |
Yeah, 970 is a substantial upgrade over the 680 in every single aspect, period.
07-30-2015, 12:15 AM | #2622 |
Member#: 332955
NWIC
07-30-2015, 01:07 AM | #2623 | |
Member#: 36838
http://www.3dmark.com/3dm11/10112053 |
07-30-2015, 01:32 AM | #2624 |
Member#: 36838
This was the previous before/after I posted...but I had re-seated the water block a few times w/o putting fresh paste on since I was troubleshooting.
Here's the same workload but with proper paste on it: Quite the difference... especially because this is silent. |
07-30-2015, 06:54 AM | #2625 |
Member#: 123330
Vehicle:16 ZoomZoom CeX-3 15 ZoomZoom3-Regina |
Wow. That's a lot of value for a $5 paste.
