02-27-2007, 07:29 AM | #1 |
Member Sales Rating: (3)
Member#: 137846
MAIC
Vehicle:2004 STi Aspen White |
VA: Home Audio/Video/Game
anyone interested ?
maganavox tv 125 bux * Product type * CRT TV - Color * Technology * CRT * Diagonal size * 27 in * Image aspect ratio * 4:3 * CRT type * Real Flat * Digital TV Type * Analog TV * Width * 31.1 in * Depth * 22.4 in * Height * 27.4 in * Weight * 88.2 lbs Video System * Comb filter * Digital * Analog video format * NTSC * Analog video signal * Composite video Audio System * Sound output mode * Stereo * Audio controls * Balance, Bass, Treble * Speakers included * 2 speakers Television Features * Closed captioning * Yes * Display menu language * English, Spanish Tuner / Channel Details * Tuner type (qty) * Standard TV (1) * TV tuner channel qty * 181 * TV tuner preset channel qty * 181 * Parental channel lock * Yes * V-chip control * Yes Remote Control * Remote control type * Remote control (Infrared) Connections / Cables / Slots * Input/Output connections * 1 x Antenna (F connector) - Rear, 3 x Composite video/audio input (RCA phono x 3) - Rear, 1 x Component video input (4 pin mini-DIN) - Rear, 1 x S-Video input - Rear Sony STR-DE597 Audio/Video Receiver 150 bux * Product type * AV receiver * Width * 16.9 in * Depth * 12.3 in * Height * 6.2 in * Weight * 17.6 lbs * Color * Black Audio System * Built-in decoders * DTS 96/24, DTS Neo:6, DTS decoder, Dolby Digital, DTS-ES Matrix 6.1, Dolby Pro Logic II, DTS-ES Discrete 6.1, Dolby Digital Surround EX * Surround sound effects * Digital Cinema Sound EX * Digital sound processor (DSP) * Yes * DSP preset qty * 11 * DSP presets * Movie, Music, Cinema Studio Ex. A, Cinema Studio Ex. B, Cinema Studio Ex. C * Surround system class * 6.1 channel * Bass Control * Yes * Treble Control * Yes * Additional features * Midnight Mode, A/B/A+B speaker switch, Digital signal format auto detection / auto switching Connections / Cables / Slots * Headphone Jack * Yes * Coaxial Digital Input * Yes * Optical Digital Input * Yes * Connector type * 1 x Headphones (Phone stereo 6.25 mm) - Front, 2 x SPDIF input (TOS Link) - Rear, 1 x SPDIF input (RCA phono) - Rear, 2 x Audio line-in (RCA phono x 2) - Rear, 1 x Audio line-out (RCA phono x 2) - Rear, 2 x Component video input (RCA phono x 3) - Rear, 1 x Component video output (RCA phono x 3) - Rear, 1 x 5.1 channel audio line-in (RCA phono x 6) - Rear, 1 x Monitor output (RCA phono) - Rear, 3 x Composite video/audio input (RCA phono x 3) - Rear, 1 x Composite video/audio output (RCA phono x 3) - Rear, 1 x Subwoofer output (RCA phono) - Rear, 2 x Front speakers output (Banana/spade x 2) - Rear, 2 x Front speakers output (Click-fit x 2) - Rear, 1 x Center speaker output (Banana/spade x 2) - Rear, 2 x Rear speakers output (Banana/spade x 2) - Rear, 1 x Rear center speaker output (Banana/spade x 2) - Rear Amplifier * Signal-to-noise ratio * 96 dB * Input Impedance * 50 KOhm * Input Sensitivity * 500 mV * Amplifier output details * 100 Watt - 8 Ohm - THD0.7 % - 2 channel(s) (Front), 100 Watt - 8 Ohm - THD0.7 % - 2 channel(s) (Rear), 100 Watt - 8 Ohm - THD0.7 % - 1 channel(s) (Center), 100 Watt - 8 Ohm - THD0.7 % - 1 channel(s) (Rear center) Radio * Radio type * Radio tuner - AM/FM - Digital * Tuning display * Fluorescent display * Station preset qty * 30 * Antenna form factor * Loop AM / wire FM * Radio response bandwidth * 30 - 15000 Hz * Radio signal-to-noise ratio * 76 dB * Total Harmonic Distortion * Mono: 0.3%, stereo: 0.5% * Auto preset memory * Yes * Additional radio features * Station naming Display * Audio system built-in display * Fluorescent * Timer * Sleep Remote control * Remote control type * Universal remote control (Infrared) * Remote control (2nd) type * None Included Furniture / Accessories * Included accessories * AM antenna, FM antenna Power * Power device * Power supply - Internal * Operational power consumption * 220 Watt * Operational power consumption (standby) * 0.3 Watt Theater Research TR-2830 Floor Speakers 150 bux pair * 30-400 Power Handling Watts * 4-8 Ohms * 107 dB/1W/1m (MAX.) * 2-4" aluminum finish cones * 1-10" silver long-throw subwoofer * 2-1" silk fiber domes * HxWxD: 43.7"x6.3"x14.5" * Weight: 41 LBS (each) MTX 12" Subwoofer (SW2) 145 bux ( 3 days old ) • 12" woofer • Bass-reflex design • 100-watt RMS amplifier • 35Hz-160Hz freq. response • Line-level inputs • Speaker-level inputs Sony® SS MB150H Left/Right Channel Speakers 30 bux Featuring a 5 1/4" improved H.O.P. cone bass driver, a 1" nano-fine balanced dome tweeter, sound reproduction to 50 kHz (for high-resolution audio), 120 watts of maximum input power, and a Frequency Range of 80Hz-50kHz, this 2-way, 2-driver book shelf speaker will definitely enhance your audio experience. Increased resistance to heat and humidity Avoids interference Black Ash matches your other audio components pair-12" pioneer floor speakers 50 bux Frequency Response: 30-20 kHz Impedance: 6 Ohms Max Power: 120 Watts sounds great Sony Center Channel 15 Bux Pair-Emerson bookshelf speakers 10 bux ( used for rear center ) 8-Ft. Monster® THX Ultra V1000 Component Video Cable 50 bux Monster's Ultra Series component video uses advanced video technologies sucha as nitrogen gas-injected dielectric insulation and silver-content solder connections to deliver the clearest, sharpest picture possible with maximum color saturation and ultra-low attenuation. Color-coded bands for simple, error-free hookup Heavy-duty double shielding protects against outside EM and RF interference 24k gold-plated contacts provide maximum conductivity and resist corrosion Exceeds THX certification standards for proper system performance and reliability Monster LightWave 10-Ft. Fiber-Optic Cable for Xbox/Xbox 360 20 bux xbox 360 , wireless net adapter , battlefield 2 , FF11 , Sneak king , pocketbike racer , big bumpin , 1-wireless controller , 1 controller plug and play charge kit , component cable , 1-nyko intercooler . no hd . 350 bux rca cables 2 bux fiber optic cables 3 bux |
Similar Threads | ||||
FS Home - Audio/Video/Game Pieces For Sale | 4x4STi | MAIC Private Classifieds | 2 | 08-26-2007 10:49 AM |
My home audio video equipment rules! | L Bo | Off-Topic | 6 | 04-13-2007 08:33 PM |
WRX parts, home Audio/Video stuff, and more... | NicFunkadelic | NESIC Private Classifieds | 6 | 02-15-2007 10:38 AM |
Home audio/video wiring gurus, need a bit of help. | trail*of*dead | Off-Topic | 16 | 12-23-2006 02:25 AM |
Home audio/video goodies for sale! Tivo! Replay! Pronto! | BiggSean | Private 'For Sale' Classifieds | 7 | 02-26-2006 11:15 PM |
