09-13-2020, 08:02 PM | #1 |
Member#: 490166
Vehicle:2004 STI Blue |
Transmission negative battery harness
Hello. I’ve got an 04 STI with a battery harness the I cannot figure out where to hook up the negative battery wire near my starter. I do not have the special tab that others have right above the starter. Any ideas where to connect this negative terminal?
09-17-2020, 08:34 AM | #2 |
Member#: 283429
South East
Vehicle:2016 Fuji Sunfire 03 Silver |
You are missing the right angle piece that bolts behind the top starter bolt that allows you to bolt the negative harness down.
Part number 22442AA021 |
09-18-2020, 12:38 AM | #3 |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green USDM 22b |
Wow E. Bass
U nailed it I just looked at my 05 and I have that R angled bracket mounted to the top center(right) starter mount bolt |
09-18-2020, 04:18 PM | #4 |
Member#: 490166
09-18-2020, 08:23 PM | #5 |
Member#: 283429
South East
You can leave it bolted to the ground wire and that way you don't loose it. Saves time too.
09-18-2020, 08:27 PM | #6 |
Member#: 283429
South East
Subaru only has two starter bolts and/or nuts. Top one is always a bolt - bottom one can be a bolt or a stud with a nut. If it has the stud always remember to look for the hidden bell housing bolt hiding near that stud when pulling engine/transmission.
