Welcome to the North American Subaru Impreza Owners Club Thursday March 28, 2024
Old 09-16-2021, 10:32 PM   #1
pepistho
Member#: 526338
2005 WRX STi
Default Can a 2002 steering wheel fit on a 2005 STi?
Looking into replacing the cheap NRG wheel the previous owner had put on with an OEM one. Just wondering if an older one would fit on my 2005 STi since those (2002, 2003, etc.) are the only ones I can find in my price range. I'm not really concerned about cruise controls or volume or anything, just if it'll fit on and that the airbag can still work. Thanks!
pepistho is offline   Reply With Quote
Old 09-17-2021, 04:56 PM   #2
monkeyposeur
Member#: 333468
93 SS - 06 OB XT
03 WRB GD 205/22T 20G-XT
I've put an 05 WRX steering wheel on an 03 WRX, so maybe?
monkeyposeur is offline   Reply With Quote
Old 09-18-2021, 12:19 AM   #3
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green USDM 22b
Think will swap
But
Will need same yr airbag
Column splines are the same 100%
95% sure the yellow airbag pigtail is the same
You need to worry about the clock spring that has the yellow airbag pigtail thou
Without tht, airbag will not be functional and AB light will be on
Is airbag lite on now with NRG wheel?
Horn work?
Blinkers/turn signals cut off after a turn?
I have a 03 WRX wheel on my 05 Sti column
AliBenn is offline   Reply With Quote
Old 09-18-2021, 10:52 AM   #4
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Originally Posted by AliBenn View Post
Think will swap
But
Horn work?
You can fake the air bag with a 3 ohm resistor - Subaru has a resistor that is used in place of the air bag for certain diagnostics so the light may be out regardless.
Clockspring and switch assemblies for 2002-2003 are different part numbers than 2004-2005.
As the old saying goes - you have to pay to play. If I couldn't afford to do this job right then I would keep saving money until I could afford it.
I wasn't that smart when I was a kid and ruined a few cars trying to make things work just because I had a part I could make fit.
Elbert Bass is offline   Reply With Quote
Old 09-18-2021, 02:15 PM   #5
pepistho
Member#: 526338
2005 WRX STi
[quote=AliBenn;46632589]Think will swap
But
Horn work?
Thanks for the info! I'll make sure the click spring is all there with the split and everything. and addressing your questions, the airbag light is on, but the horn does not work and the turn signals do not reset/cancel. although, i suspect that the horn isn't working simply because of whoever installed the hub
Old 09-20-2021, 08:14 PM   #6
AliBenn
Member#: 487
^^^^no without a clockspring, all those issues will occur
So
You need a stock steering wheel/AB/clock spring and will be good
Again, I have a 98 clock spring with 03 WRX wheel/airbag on a 05 steering column !
Everything works
Not too intense of an install
Just make sure you line up clock spring arrows
I am sure there are some vids on utube showing the same
Old 09-28-2021, 11:42 AM   #7
robbieshonda
Member#: 122306
2002 Sti PTE 6262
Interlagos Blue 610/580
Jspec auto in VA sells STI steering wheels at a decent pricehttps://jspecauto.com/en/subaru/acce...eering-wheels/
robbieshonda is offline   Reply With Quote
