01-22-2022, 09:28 PM | #1 |
Member Sales Rating: (18)
Member#: 32357
NWIC
Vehicle:2005 Black STI SBR20G 386whp/399wtq |
Denver - WRX/STI Parts (Mostly 02-07 WRX/STI parts)
All prices are for the parts only. The shipping will be added costs.
MadDad Velocity Headers Uppipe combo (3 bolt header to uppipe flange) will fit 2002-2014 WRX/2004+STI - EJ255 & EJ257 These are made from the same manufacture that makes Japan's TOMEI headers and GT Spec ones. Full T304SS incorporating lost Wax formed stainless steel flanges, performance tuned 4 into 1 design with one piece collector that eliminates undue extra welds, an engineered matching uppipe that supports higher flow along with an integrated Velocity stack to maintain low-end torque, amazing TIG welds. It is dual layer ceramic coated also. Has an EGT bung, you just need a probe to connect your gauge. You will need gaskets and hardware to install, Used, good condition - SOLD https://forums.nasioc.com/forums/sho...ddad+v2+header This thread on IWSTI talks discuss specs and performance of the Velocity header. https://www.iwsti.com/threads/maddad....119872/page-2 K&N Typhoon Intake (02-07 WRX STI), Part # 69-8001TWR. There is a tab broken on the heat shield mount for the MAF sensor, however the other tabs are good and it can still be mounted securely. Used, good condition - $180 https://www.knfilters.com/cold-air-i...5l-h4-gas/2005 https://www.rallysportdirect.com/par...-intake-system Perrin Rear Endlinks, 04-07 WRX STI. Comes with all the hardware (washers, bolts, nuts, spacers). One bolt is stuck in the spherical bearing in both endlinks, however this won't effect the install or the performance since the bearings are good in both endlinks. Used, good condition - SOLD Lower Arm Bar /H-Brace (P&L Motorsports version - same as the Cusco type II version) 02-07 WRX/STI - that's right why pay Cusco prices. You just don't get the fancy blue paint...lol. Connects the front subframe to one point on the front control arms. Make a huge difference in front end stiffness and chassis rigidity. Used, good condition, some paint flaking off due to road debris- SOLD https://www.rallysportdirect.com/par...-lower-arm-bar NRG Quick Release 2.0, black, Part # SRK-330BK, Brand new - $90 https://www.rallysportdirect.com/par...hrome-6-5-hole GrimmSpeed Hood Scoop Splitter, 04-05 STI, Part # 093076. Increase your airflow to your TMIC and reduce heat soak. Also has more holes for better air flow to the turbo. The only reason I'm selling this is because I have the Process West TMIC and it comes with a splitter that works better for that TMIC. Brand New in the box - SOLD, I'll throw in the hoodscoop screen you see in the pic as well. https://www.rallysportdirect.com/par...scoop-splitter Racecomp Engineering Kool Brake kit ducts (ducts only), no hoses - you will need to order the 3" ducting (hose). Reduce brake fade and have longer sessions on the track. Used, good condition - SOLD https://forums.nasioc.com/forums/sho...mp+brake+ducts https://forums.nasioc.com/forums/sho...mp+brake+ducts Universal Oil Catch Can with bracket that mounts left of the turbo for 02-07 WRX/STI(will work with all years, bracket is made to fit 02-07 WRX/STI, you can also make your own bracket), comes with the filter, fittings to install the can and some hosing to get a start. The additional hosing you will need to order based on your setup (every set up is different). Brand new, never used. I went a different route with my setup - $80 Rear Subframe - Lock Kit, Part # KSB750 - Used, good condition - SOLD https://whitelineperformance.com/pro...rame-lock-bolt Will offer a package deal. PM or text me at 303-912-7538
Last edited by t-rex25; 05-22-2022 at 12:48 PM. Reason: updated item description |
03-04-2022, 12:33 PM | #15 |
Member#: 32357
NWIC
"Spaulding, get dressed you're playing golf today. No I'm not grandpa I'm playing tennis. You're playing golf and you're gonna like it. But what about my as asthma. I'll give you asthma."
03-09-2022, 11:58 AM | #18 |
Member#: 32357
NWIC
"I want a hamburger. No, a cheeseburger. I want a hotdog. I want a milkshake"
"You'll Get Nothing and Like it!" |
04-04-2022, 01:11 PM | #23 |
Member#: 32357
NWIC
"So, I tell them I’m a pro jock, and who do you think they give me? The Dalai Lama, himself. Twelfth son of the Lama."
