03-16-2019, 01:23 AM | #1 |
Member#: 269228
14mm head stud arp 625 vs rcm
What would be the best of the 2 arp 625 vs rcm 14mm head stud? Any know the tensile strength of each can't seem to find it on the site.
03-16-2019, 12:03 PM | #2 | |
Member#: 57064
Vehicle:2008 STi IAG built HTA86 E85 Kel272s Cos IM |
I've been running 38psi through them for 30k miles without headlift if that says something about them |
03-16-2019, 01:09 PM | #3 |
Member#: 349275
Vehicle:2012 STi WRB |
14mm will be stronger than the 625's. But head stud choice should be based on how much hp/boost you aiming for.
In my opinion this is the strongest to weakest head stud. 14mm > 1/2 inch > 625 > arp2000 > oem. My STi is going in May to be built. My end result hp goal being between 500/600whp. Technically I could get away with the arp 625's. But we jumped up to half inch head studs to be safe and also give a little head room if I ever wanted to make more power. |
03-16-2019, 05:35 PM | #4 |
Member#: 71875
The thing with headstuds is that they are all steel, and despite being different alloys and "stronger" the modulus of elasticity is still essentially the same. So, you take an 11mm stock bolt, and an 11mm ca625 stud, and apply the same force, and they will stretch the same amount. The benefit of the stronger material is that you can torque them down farther to provide more clamping force without them breaking or deforming plastically, but they will still stretch at the same rate.
The larger studs take more force to deflect the same amount, so that's always going to be a benefit, regardless of the specific alloy. |
10-17-2021, 03:39 AM | #5 | |
Member#: 527019
I'm still considering the 14mm conversion but the Gen II GTX3076 should be ok with 11mm CA625s. |
10-18-2021, 12:39 AM | #6 | |
Member#: 469585
W. Canada
Vehicle:2009 STi White |
10-18-2021, 06:27 AM | #7 |
Member#: 198281
Vehicle:2005 WRX/STi WRB of course |
These conversations are always difficulty because it can vary by conditions. Not to mention they all vary in material; physical properties.
Just comparing clamping forces, the RCM 14mm would be the winner, since the larger stud uses a higher torque spec. |
10-18-2021, 11:09 AM | #8 |
Member#: 30804
SWIC
Vehicle:87 Yugo Red |
Paging Micah. Micah - your input is needed here.
Folks - Micah and I have been working on a little something and we have data that we can share soon. |
01-20-2022, 09:55 AM | #9 | |
Member#: 193940
Vehicle:2004 WRX STI Black RalliSpec Shortblock |
01-20-2022, 12:10 PM | #10 |
Member#: 491095
SWIC
Vehicle:2009 STi Blue Blue |
to put a plug here from my own research...oem and arp2000 have similar strength, the 2000s have a higher heat tolerance...am planning on running the 625s as my upgrade otherwise i know several people who use the stock bolts and do fine...dont think they are ridiculous power but they are doing decently!
01-20-2022, 12:58 PM | #11 |
Member#: 34361
Vehicle:04.7 STI WRB IG @got2boostit2 |
And then Clint and Micah never responded.
Look up Mechanical Advantage they did a study on head studs. Might be in Blog form. |
01-24-2022, 01:31 PM | #12 | ||
Member#: 30804
SWIC
Right now I have clamp load data for ARP2000 (new), ARP2000 (used) and ARP625 (new) using three different thread lubes (one of which is the ARP lube). I still need to finish testing clamp loads for the following: ARP625 (used) Special #1 Special #2 IAG 1/2" IAG 14mm RCM 14mm superstud Since I'm doing this in my spare time I'm doing it when.... I have spare time. I'm hoping to get back on it really soon, but I have some heads that are being a PITA, and I have to figure out why the same valve on an FA motor keeps popping the rocker when using anti-lag. |
01-24-2022, 06:23 PM | #13 | |
Member#: 34361
01-24-2022, 06:25 PM | #14 |
Member#: 34361
Mechanical Advantage Racing Blog on Choosing the Right Head Stud (C-2018)
https://www.maracing.net/choosing-the-right-head-stud |
01-24-2022, 09:24 PM | #15 |
Member#: 193940
That was a interesting read. Ty
02-07-2022, 12:02 PM | #16 |
Member#: 30804
SWIC
For those of you following along I can add a small tidbit.
As part of the project Micah and I are playing around with three different thread lubes; ARP, mystery lube A and mystery lube B. ARP lube is just the same stuff you get in the packaging of the head studs. I have a load cell here and made a fixture to measure clamp load. Clamp load is going to be the common factor across all the testing, and the ARP studs with ARP lube clamp load are the control. So in this example we're going to talk about ARP2000. Following the ARP instructions and using the ARP lube we got a clamp load of X (not sharing numbers just yet until we have complete data). Then taking that same stud, completely cleaned we used mystery lube A. To achieve the same clamp load took 30% less torque. Just for fun I took an old ARP2000 stud, and applied the lube mentioned and torqued to full torque according to ARP's instructions which is 90lbs. It was a struggle to reach 90lbs of torque. I could feel the stud stretching as I applied force, and this was confirmed by the readout from the load cell peaking and then falling off rapidly. When I did finally reach 90lbs the clamp load dropped over the course of time to finally at a point that was much higher than the control, BUT this is not a good thing. Feeling how it stretched, and watching the clamp load fluctuate so much tells me that it went well into plastic deformation, and is now a useless stud so it went straight into the trash. When we are all done with data gathering one of the papers we're going to put our there is the effect of lube on clamp load. Yes, anyone with an inkling of understanding of fasteners will say "well duh Clint," but it's not too often you get to see real world relatable numbers. |
02-07-2022, 01:33 PM | #17 | |
Member#: 469585
W. Canada
02-15-2022, 06:51 PM | #18 | |
Member#: 338855
Vehicle:2011 WRX Silver |
looking forward to your findings...meanwhile I will just try not to blow up my engine, which at this point is parts on my bench (because I gone done blow up the last one) |
02-16-2022, 12:53 PM | #19 | |
Member#: 30804
SWIC
Let me see what I can address: 1) For my initial testing I took 3 brand new ARP2000 studs, and using their lube, and their instructions I do not hit a clamp load of 15060 at 90lbs. 2) Wholeheartedly agree with you. 3) OEM bolts are actually on my list to test, but alas time has not favored an opportunity to keep working on the project. I need to get on that. 4) In all of my testing I have been consistent with what studs are what, and measured min cross section of each. So now I have cross section of each stud, I have clamp force for each stud using 3 lubes, and the next step will be to measure stretch at each indicated clamp load. Then with some mathery I SHOULD have every variable filled to answer any and all questions. 5) I'm not even sure what photo loading software nasioc is using these days. If you want to see a pic head on over to the Turn In Concepts facebook page as I posed a pic about a month ago. I CAN describe what I have though. I have a block of aluminum milled as flat as my head surfacer will do. In that is a threaded bore for receiving the stud. On top of that I have a steel hat washer, then I have a 20T load cell, then I have another steel hat washer. The stack-up height of everything matches what you would get out of a case and head combo accurate to within .010". One thing that I did do that is different is I formed the threads in the aluminum block which is 6061. I figured that given the repeated cycling I wanted that bit strong, and it should be non-affective on the outcome since it will be used across all studs I'm testing. 6) I too was a little concerned that I ripped the threads out of the aluminum block, but see note above. I also cross checked it after against a virgin stud, and threading it in did not cause any issues so I don't believe I damaged those threads in any way. I know it's not the best method to test, but that's all I could come up with. I do wish that I had measured before and after, yet sadly I did not. Honestly I just wanted to torque the crap out of something because the process of torque, write a number, torque, write a number was getting pretty boring. Not to worry I'm sure I'll get bored again and feel like breaking something so I'll have more opportunities. 7) We're still limited on length due to where the threads need to fall, and I don't believe (correct me if I'm wrong) that any additional length above the nut would have any benefit. In all of this Micah and I have been approaching this with the philosophy that studs are springs. Sure they can clamp just fine, but what happens in a big knock event? Hence a good part of this exercise. We need it to take the load of a bang, and return to normal clamping. At the same time we can't go TOO big or by the time we've reached proof we'll end up deforming the head (I know from talking with JJ that this is a real concern because if you get carried away with their 14mm you can crack the head). 8) You absolutely nailed it with how I'm going to measure the stretch. I have a gauge that does .0001" that I'm going to use for getting that, and that process is my next big push in data gathering. I'll also throw this in there - people will bring up temperature affecting things. All the studs and my test rig have been living on our engine build room (sometimes in Ethan's way). That room is kept at a constant 68F and is closed off from the rest of the shop. 9) For years I have wondered about the relationship of clamp on fasteners that are reused. Now, here we have two cases. Case 1 is where we're just using them for something like measuring during assembly or even fastening torque plates. Case 2 is truly used hardware where someone had a stud in an engine, blew it up, and then reused the studs for the next engine. Over the years I have adopted the philosophy that heat cycling is the key to this. Bolt things down and measure means no heat so good to go. Reused studs from a broken engine means heat so reconsider their use. NOW I finally have the ability to refine what honestly has been a wild ass guess. As of right now I have clamp data for all new studs. I need to get clamp data for used studs.... and I have PLENTY of those here to test with. That exercise will truly be eye opening. 10) Just popped open that pdf in another tab. I believe I have read this one years ago, but I'll give it a quick read today to see if anything stands out. 11) Thank you for the link on the book. Just ordered a copy. No worries on blown up engine. Mine is in pieces, and has been for a couple of years. I have a real problem working on my own stuff because if I'm at the shop I always feel I should be working on customer stuff. Even when I come in on the weekend. As my wife will tell you I have a VERY poor work/life balance. |
02-17-2022, 01:29 AM | #20 | |
Member#: 338855
That is disappointing about the M11 ARP 2000 stud and not seeing the clamp load that they say they achieve. That said, I will be interested to see what you did achieve. I think there is a lot of variation with this stuff...and part of me when on the phone with them wanted to ask "and what was the sample size and standard deviation?" I saw the test setup on your FB page and I think that looks good. I have done similar for some testing in my real life. I think you are doing a good job with covering the bases for a meaningful set of data once you are all done. This stuff takes time and it is cool you are fitting this in. In regard to my comment about a larger diameter bolt being stiffer if the same length as the smaller diameter, I was talking the length from nut bottom surface to top of threaded hole. I think my comment about trying to keep stiffness the same may be a bit silly. The stiffness of a fastener in the axial direction can be approximated as k=AE/L, where k is stiffness, A is cross sectional area of root (or smallest) diameter, E is Young's modulus, and L is the grip length. If you want the same stiffness and say an M11 is fastener 1 and M14 fastener 2 you can say k1=k2 or L1/A1 = L2/A2. The M14 fastener that would be the same stiffness as an M11 can be found by L2=L1*A2/A1. Using a M11 stud on my bench I measure L1 = 170 mm. The M11 root diameter is ~9.25 mm and the M14 root diameter is ~11.9 mm. This works out that for an M14 stud to have about the same stiffness as a M11 stud it would need to have a grip length of 281 mm, which obviously can't happen. I do wonder what the implications are for a fastener that is 66% stiffer. while clamping force is for sure higher, it is also more sensitive to changes across the joint. Interesting to think about in off/normal situations of knock. (I just cracked a liner and this caused me to call ARP and was also looking at journal papers for normal and knock cylinder pressures and was shocked at how high they can get) from the temperature standpoint I don't think there isn't an issue for testing purposes. Your tests are relatively short and the temperature change small. Even if you have a 5 degree C change that results in I think a small change in clamping load. Aluminum has a coefficient of thermal expansion of ~22 um/m/C and steel is ~13 um/m/C. The difference is 9, so with the 5 degree C change you have an ~8 micron effective change in stud length. This works out using the AE/L for stiffness and the 8 micron length change to be 1047 N (234 lb) change in load. That is at the 1.5% level for one of those ARP 2000 M11 fasteners and quite a bit less for a M14. This is basically in the noise. You are also likely not having a 5 degree C swing during the test. it might be interesting to check the increase in clamping load that happens in operation and maybe over heating conditions. I will try to dig up where I have seen stuff about clamp load and torque as a function of number of times tightened. That fastenal ref is my go to place for quick clamp load estimates for various fasteners...not too onerous to find. Bickford on the other hand...that is massive and will make for a good door stop even if you don't read. I am always amazed at how complex threaded fasteners are if you start to look closely. anyhow...enough blathering...this is interesting stuff. I am going to assemble my new engine with ARP/IAG 1/2 studs and will be interested to see what you found with those. |
02-17-2022, 10:57 AM | #21 | |
Member#: 30804
SWIC
02-17-2022, 10:59 AM | #22 | |
Member#: 338855
02-17-2022, 01:38 PM | #23 |
Member#: 34361
Kendall Samuel, where are you? LoL
02-17-2022, 03:25 PM | #24 |
Member#: 193940
I too went with 1/2 studs. I thought when they machine the heads and block for 1/2 studs, they cut out the old threads and tap new ones.
Your telling me that they just cut the thread "tips" and thread in the 1/2 studs? |
02-17-2022, 04:49 PM | #25 |
Member#: 198281
Don't get me started on this!!!
It's such a bad idea; lets put a stress riser on a stress riser If Carroll Smith knew he be turning in his grave! The reality of it is there aren't known issues because of this poor practice. At least not that I am aware of. |
