Tire & Wheel Forum sponsored by The Tire Rack |
01-10-2022, 07:15 AM | #5926 | |
Member#: 339923
Vehicle:2006 Impreza WRX STi grey |
go with the 9.5 wide. yes this can or rather will have an effect on handling characteristics but most of the guys running in gridlife street modified class run 9.5s, as well as most in any body of racing that allows a 255-275 wide tire will be running 9.5s. check with what class/league you want to race in to be sure of the rules. but switching to a 9.5 will still allow clearance for brakes, pending which you want to run. if you swapped to sti 6 pot brembos i think it's a small spacer on the front for the 18x9.5+38 rpf1 and i'm about 99% sure the 18x10+38 rpf1 clears the 6 pots. the 4 pots require an 8mm spacer for the 9.5+38 and i think a 3mm spacer for the 10+38.
02-02-2022, 03:38 PM | #5927 | |
Member#: 510701
TXIC
Vehicle:2018 WRX LMTD CWP |
02-06-2022, 12:53 PM | #5928 |
Member#: 346610
SCIC
Vehicle:2021 WRX Limited 6mt White |
Want to run 275/30R18 tires on my 21' WRX without rolling the fenders. Yes, odd but my mind won't be changed if possible. Anyway, can this be accomplished with an 18x9.5 +50et or does the offset need to be a +55? I want to be lowered as well.
The closest setup I've found is a lowered one running 18x9.5 +45 using 265/35R18's without rolling. |
02-10-2022, 10:02 AM | #5929 |
Member#: 528757
2019 WRX Set-ups
Hello - New to the forum and would like to see some details and pics of '19 WRXs with wheel/tire set-ups + offsets as well as lowered suspensions. I am personally planning on buying Yellow Speed Racing Dynamic Pro Sport coils, Michelin Pilot Sport 4s tires, and Motegi MR131 Tracklite (offset +40) wheels. I've never bought coils before, but don't think I want to deal with fine tuning dampering, so the Yellow Speeds are non-adjustable.
Any pics, info, help would be appreciated. |
02-17-2022, 08:15 PM | #5930 |
Member#: 528054
So I need a sanity check.
I've got a '21 WRX, stock brakes/suspension. I've been looking at a set of Enkei TS-V 18x8.5 with a 45mm offset. Just going to swap the stock dunlop summer tires onto them when winter is over. From what I can gather I shouldn't run into any clearance issues at all with a setup like this, but thought it was worth double checking to make sure. |
02-17-2022, 09:19 PM | #5931 |
Member#: 422419
Vehicle:2015 WRX |
I just pre ordered a set of TE37 SAGA SL M-Spec 18x9.5+39 PB with FACE 4; I shouldn’t have any fitment issues right?
02-26-2022, 03:56 PM | #5932 |
Member#: 142417
Vehicle:2011 STi Dgm |
Staying with 19s on my 2020 STi. I already put 245/35/19 performance winters on the stock wheels and now I'm looking at 19x9.5 +38 or +40, probably need a roll since I'm lowered on RCE SS1s, but I can't decide on 255/35/19 or 265/30/19. What's the proper fit?
03-28-2022, 01:42 AM | #5933 |
Member#: 372933
Vehicle:08 spec.B DGM |
year: 2008
model: Legacy spec B wheel model: Enkei T6S wheel size/offset: 18x8.5 / 45mm / 5x100 tire brand/model: MICHELIN PILOT SPORT 4S tire size: 225/40 R18 - or maybe wider suspension: coilovers alignment: fender mods: spacers: no calipers: 2018+ 6-pot brembos The real question I have is will these wheels clear 6-pot brembo calipers? If not, any other wheel suggestions in 5x100? |
03-29-2022, 07:24 AM | #5934 |
Member#: 142417
19x9.5 +38 Titan 7 TS5 with 265/30/19 MPS. Have to slightly adjust ride height, camber and align and see if I need a roll. Also center caps back ordered. Def need those.
04-24-2022, 06:38 PM | #5935 |
Member#: 528757
05-08-2022, 03:30 AM | #5936 |
Member#: 33789
Vehicle:04 WRX Red 20 WRX silver |
Curious about fitment of 235/45 17 tires on my '04 WRX. Wheels are 17x7 Prodrive +53. 215 were stock and most run 225, I know. Seems like a stretch but I have the tires from my '20 WRX and don't have a use for em and seems like a cheap way to put new rubber on the '04.
05-11-2022, 07:20 PM | #5937 |
Member#: 450571
year: 2006
model: STI wheel model: ZE40 wheel size/offset: 18x8.5 / 45mm / 5x114.3 tire brand/model: Dunno yet tire size: Been reading : 245/40/18 or 245/35 suspension: coilovers but not slammed to the ground alignment: fender mods: i don't want to but maybe a slight roll all around spacers: no Any issues with this set up or have you guys ran into rubbing? I don't want to stance the hell out of the car either. Last edited by halohalomix206; 05-11-2022 at 07:34 PM. |
05-12-2022, 05:19 PM | #5938 | ||
Member#: 510701
TXIC
No issues at all Best for gravel dirt are 15's 205/65/15 tires bc theyre dime a dozen for this size wheel its also universally used. Rocks? I'm assuming when ya mention rocks you mean overlanding driving over rocks is not an ideal situation (I'm gonna rule out rock crawling bc wrxs are not known for this altho you probly could if ya really wanted to and that was your goal) unless you're driving at a snails pace and have the right setup, otherwise pointless. Snow, slush you can slap on a set of 3PMSF or dedicated snow rated tires and you should be fine. Ice is a totally different story e.g. rally cars use a specific ice/snow wheel typically a much thinner width like 5 to 5.5" along with studded tires Sent from my SM-F711U using Tapatalk |
05-31-2022, 05:29 PM | #5939 |
Member#: 450829
Vehicle:2017 Impreza Hatch White |
2017 Impreza Hatch with BRZ rims and tires
https://www.hubcaphaven.com/p/24049/...8111ca090.html
year: 2017 model: Impreza Hatch base wheel model: 2021 Subaru BRZ 10 spoke gray wheel size/offset:48mm tire brand/model:Michelin Primacy HP tire size: 215/45/17 suspension: stock alignment: Stock fender mods:None spacers: yes/no? size? None- Currently All Stock I kept breaking hubcaps on the stock 16" steelies. Handling is a noticeable improvement with minor change in speedometer. One rim has slight curb rash- please advise on touch up as Subaru does not make paint for rims. |
06-08-2022, 05:45 PM | #5940 |
Member#: 450313
Nice to jump back in these forums about a decade later. Been kickin around getting a new set of wheels on my old garage queen. I know the oem wheels are +53, is there a big apperance difference between the 45 offset and 54? Would be nice to run something slightly lower if I can get away with it...but I don't want to bother with something down in the 30's. It appears from research camber plates and rolling would be pretty much required. Thanks for any help! Looking at either a 17x8 setup or an 18x8/8.5 setup.
year: 2007 model: STI wheel model: Advan RGIII wheel size/offset:17x8 45mm. Been emailing with a shop saying that 18x9.5 +40ish will fit just fine but doesn't check out from what I've been reading in here. 18x8 or 8.5 +45 work? tire brand/model: Continental Extreme Contact Force tire size: 245/40/17 or 235/40/18 suspension: Ohlins Fixed Perch Normal setting + Jdm Pink Springs. I believe its a 1" lowering all around alignment: Stock? fender mods: ideally would like to avoid spacers: no Last edited by benbikes4beer; 06-09-2022 at 05:37 PM. |
06-19-2022, 04:04 PM | #5941 |
Member#: 530432
year: 2020
model: wrx wheel model: xxr wheel size/offset:18x8.75+35 tire brand/model: Goodyear ls2 tire size:245/45/18 suspension:BC racing coilovers alignment: stock fender mods: rear rolled spacers: yes/no? size? No Last edited by Johnjballs; 06-19-2022 at 04:21 PM. |
07-16-2022, 01:54 AM | #5942 |
Member#: 450571
can anyone let me know if 18x7.5+48 ZE40s clear the STI Brembo Caliper? 2007 STi
07-16-2022, 01:54 AM | #5943 |
Member#: 450571
posted twice can you delete mods?
07-26-2022, 08:56 PM | #5944 |
Member#: 529755
Year: 2011
Model: 2.5i Sedan Wheel: Kosei K4R Spec: 17x8 +36 Tire: Continental Control Contact Sport SRS+ Spec: 225/45r17 Suspension: Stock Alignment: Stock Fender mod: none Spacers: none They are flush in the rear, slight poke in the front; if I was lowered, that would likely change though. |
08-01-2022, 04:53 PM | #5945 |
Member#: 332641
08-02-2022, 06:09 AM | #5946 |
Member#: 431618
Double Post
08-02-2022, 06:09 AM | #5947 |
Member#: 431618
09-04-2022, 05:59 PM | #5948 |
Member#: 531304
year: 2017
model: WRX wheel model: Anovia Kano wheel size/offset: 18x9.5 +38 tire brand/model: General G-MAX AS-05 tire size: 265/35 suspension: Swift Spec-R Lowering Springs alignment: Nothing crazy fender mods: None spacers: No |
09-21-2022, 05:06 PM | #5949 |
Member#: 531508
Hi all, new to the forum but not new in the Subaru community. Excited to learn from the abundance of knowledge and wisdom on the forum!
year: 2021 model: STI wheel model: TE37SL Black Edition ii wheel size/offset: 18x10 +39 tire brand/model: Michelin PS4S/Toyo Proxes Sport tire size: 275/35/18 OR 255/40/18 suspension: Fortune Auto 500 Coils alignment: not too aggressive Fender mods: roll (ideally don't want to pull) spacers: no Originally settled on 265/35/18 as most would run on VA chassis, however after checking OEM diameter on 245/40/18 of 25.7" and 25.8" on 245/35/19, I'd love to get as close to that as possible. Hence, considering 275/35/18 (25.6***8221 and 255/40/18 (26"). I've seen a few members on here running same wheel specs & tires that have made it work (e.g. @skeeter281) but I've also seen others say it wouldn't. Would love input on this matter to help me settle on the tire size for my new summer setup. Thank you! Even more appreciation if you have photos to show! Last edited by mrteeleung; 09-21-2022 at 08:33 PM. |
09-22-2022, 03:17 AM | #5950 |
Member#: 33789
I have 255/40-18 on my mostly stock '20. I can't remember for the life of me if the wheels are 18x8 or 8.5 They fit fine with no rubbing but do have a bit of poke that kinda bugs me. I should get some photos on here.
Similar Threads | ||||
the motorsport fitment thread: because race car! | nhat | Tire & Wheel | 45 | 11-20-2011 03:21 PM |
the official wheel/tire fitment thread: all fitment questions go here! | nhat | Tire & Wheel | 1086 | 06-15-2011 01:02 AM |
where did the wheel fitment chart go? | PoopRSkupe | Brakes, Steering & Suspension | 0 | 01-26-2004 01:36 PM |
A thread in the STi forum to keep it alive (because STi forum is closing) | Eric SS | Off-Topic | 6 | 09-10-2003 03:54 PM |
