01-03-2022, 01:04 AM | #1 |
Member#: 517340
Vehicle:2007 WRX STI |
Best way to clean very dirty STI seats?
I bought an 07 STI from an auction and it was obvious that the previous owner neglected to maintain or keep the car remotely clean in the last several years of his ownership. The drivers seat is heavily soiled, and the seat backing is blackened. What is the best way to clean alcantara that is this dirty? I have done the traditional Sonax alcantara cleaner and soft brush method, it didn't do much. I've seen some people say you can wet vac or steam clean alcantara safely and some people say you absolutely should not. Anyone have any luck with doing either?
https://gyazo.com/e814587c277f4d55e9e1315dfb868946
02-03-2022, 04:27 PM | #2 |
Member#: 528650
Pinnacle Black Label Suede-Soft Alcantara is the best from my experience.
I also read here some very good Midas reviews, the repair and service centre. Once in a while it is a good thing to make a professional cleaning and disinfection. I try to do it once a year minimum or after some long trips. Last edited by alicestevens; 02-19-2022 at 02:23 PM. |
03-05-2022, 01:58 PM | #3 |
Member#: 526919
Vehicle:2018 STI DGM |
I used Sonax Alcantara cleaner with little success in the past.
I just tried Dr. Beasley’s cleaner and protector, and I will never go back. Amazing product. |
03-20-2022, 01:17 PM | #4 |
Member#: 529321
Sonax Alcantra cleaner and a good steamer, works wonders!
04-04-2022, 05:48 PM | #5 |
Member#: 505448
Alcantara is very soft and cleaners may break down the material if they're too aggressive. It would be best to try warm water with a very gentle mix of cleaning solution and a soft brush or non abrasive steam cleaning attachment.
04-11-2022, 02:49 AM | #6 |
Member#: 529617
I have an 05 sti with oem blue seats that look super dirty! Any recommendations on a good cleaning solution?
04-11-2022, 02:50 AM | #7 |
Member#: 529617
04-21-2022, 09:26 PM | #8 |
Member#: 528896
Vehicle:2002 Impreza WRX STi Blue Black Mica |
I have just gone through this with my 02" STI.
It had seats that had gone black similar to yours. I soaked them with a general purpose cleaner and water, then hit them with a brush attachment on the end of my drill. I then wet vac'd them and repeated. I can't post attachments at the moment, but before and after pictures are on my insta, @nosdodnai |
08-09-2022, 06:50 PM | #9 |
Member#: 530997
Any recommendations on a vacuum?
10-15-2022, 05:07 PM | #10 |
Member#: 531782
Vehicle:1999 2.5RS Coupe WRB |
This probably isn't the recommended approach, but I've used a carpet cleaner type of wet vacuum to clean seats before. If they're heavily soiled, you'll need to "mechanically" clean them before attempting any sort of chemical treatment. The wet vacuum got all the gunk out of my seats, then followed up with standard upholstery cleaning sprays (making sure they're safe for the specific material of your seats).
07-10-2023, 10:10 PM | #11 |
Member#: 427287
Vehicle:2016 WRX WRB |
Ive gone with chemical guys over the years for their leather cleaner and fabric cleaners.
07-11-2023, 12:01 AM | #12 | |
Member#: 90804
SCIC
Vehicle:2021 Ascent 2012 Accord |
07-17-2023, 03:34 PM | #13 |
Member#: 534856
You mentioned that you have already tried Sonax Alcantara cleaner, but it didn't yield satisfactory results. In such cases, you might consider using a stronger Alcantara cleaner specifically designed for deep cleaning. Follow the product instructions carefully and test it on a small, inconspicuous area first to ensure compatibility and prevent any potential damage.
