Welcome to the North American Subaru Impreza Owners Club Wednesday August 17, 2022
Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 04-08-2011, 01:54 PM   #1
AMR
Member#: 171509
Default 2011 Subaru Limited STi (sedan) - OBJECTIVE: 500whp Pump Gas (93 octane) Build
Our customer Matt came to us with 1 goal....500whp on our dyno on 93 octane!
STAY TUNED!!!!
- 2011 Subaru STi
Customer:
- Matt
Objective:
- 500whp on 93 octane
Driving Characteristics:
- Daily Driven / Weekend Warrior
Engine:
- AMR Pro-Street (PS25) Short Block:
-- New 2.5-Liter Semi-Closed Turbo Block
-- New Subaru STI Forged Crank
-- AMR Forged I-BEAM Billet Rods
-- AMR Spec Forged Pistons
-- AMR O-Ring
-- AMR 9/16 Head Studs
-- AMR Head Gaskets
-- AMR High-Flow Oil Pump
-- Professionally Balanced, Blueprinted and Assembled
AMR BIG VALVE Race Heads:
- Oversized Stainless Steel Intake & Exhaust Valves
- Dual High Performance Valve Springs & Titanium Retainers
- Port & Polished Intake & Exhaust Chambers
AMR V1 Camshafts:
- 272in / 272exh
Other:
- AMR CXR750 Turbocharger
- AMR Front Mount Intercooler
- AMR 2" Equal Length Header
- AMR Up-Pipe
- AMR CAST Turbo Inlet
- AMR Dual Turbo Back Exhaust
- Upgraded Aluminum Oil Pan
- Upgraded Injectors
- Upgraded Fuel Pump
Engine Management:
- ECUtek RaceROM tuned by AMR
AMR is offline   Reply With Quote
Old 04-08-2011, 01:54 PM   #2
AMR
Member#: 171509
Default OUT WITH THE OLD (factory engine)
Engine Removed
Factory engine on engine stand
Old 04-08-2011, 01:54 PM   #3
AMR
Member#: 171509
Default New Engine
AMR Pro-Street Shortblock w/ AMR 9/16 Studs & AMR O-Ring
AMR Assembled Long Block w/ AMR BIG VALVE Heads & Aluminum Oil Pan
Old 04-08-2011, 01:54 PM   #4
AMR
Member#: 171509
AMR CXR750 Bolt-on Turbocharger
Old 04-08-2011, 01:55 PM   #5
AMR
Member#: 171509
Old 04-08-2011, 01:55 PM   #6
AMR
Member#: 171509
Reserved 5
Old 04-08-2011, 01:55 PM   #7
AMR
Member#: 171509
Reserved 6
Old 04-08-2011, 01:55 PM   #8
AMR
Member#: 171509
Reserved 7
Old 04-08-2011, 01:56 PM   #9
AMR
Member#: 171509
Reserved 8
Old 04-08-2011, 01:56 PM   #10
AMR
Member#: 171509
Reserved 9
Old 04-08-2011, 01:56 PM   #11
AMR
Member#: 171509
Reserved 10
Old 04-08-2011, 03:16 PM   #12
Homemade WRX
Member#: 33782
96 3MI Racing
search FIRST, then PM!!!
build the hype!!
Old 04-09-2011, 05:44 AM   #13
ITS11STI
Member#: 264648
2011 STI Sedan GT35R
Good Luck with the build! Should be a happy customer when all is said and done!
ITS11STI is offline   Reply With Quote
Old 04-10-2011, 08:05 AM   #14
fourmicah
Member#: 128760
2017 STI
Can you actually put something of value up next time?
fourmicah is offline   Reply With Quote
Old 04-11-2011, 10:36 AM   #15
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
AMR is really weird company, it seem that they make good products that perform well. But they don't provide any testing, data or answer any question.
Old 06-15-2011, 03:31 AM   #16
fourmicah
Member#: 128760
2017 STI
I know Juan, I've heard very good things about them and their products. I just get frustrated when people/companies put up these threads about something great and nothing is in thread. The worst ones are those that they want you to follow through the build which they are doing over a decade. Just once I want someone to put up a post were they have actually completed the build first. No motor break in, boost leaks to find, waiting for parts or something broke. Actually have the final tune, everything has been tested checked and working for a weeks and working great.
AMR - Looks like a good start. Why did you choose to go with a stock location turbo instead of a rotated set up given the amount of power the customer wants on pump gas?
Old 04-11-2011, 03:58 PM   #17
AMR
Member#: 171509
uploading has started...post 2
Old 04-11-2011, 08:08 PM   #18
Rapier46
Member#: 277987
wow that shop looks great!
Rapier46 is offline   Reply With Quote
Old 04-12-2011, 08:12 AM   #19
fourmicah
Member#: 128760
2017 STI
That's awesome, you talk about the way the shop looks.....
Old 04-11-2011, 10:47 PM   #20
betterthansx
Member#: 259103
16' Focus ST
Kona Blue
subscribed!
betterthansx is offline   Reply With Quote
Old 04-12-2011, 12:37 AM   #21
Layvon
Member#: 195711
PART OUT. PM ME
02-07 Goodies
Did they change up the factory manifolds or does Matt have aftermarket headers on there?! I see a lot less heat shield.
Eager to watch this progress.. Any time-frame in mind?
Old 04-12-2011, 10:41 AM   #22
AMR
Member#: 171509
Thank you
Pictures uploaded to post #3.
Old 04-12-2011, 10:02 PM   #23
juanmedina
Member#: 133146
can you post more info? what parts are you using? injectors? turbo? pistons? etc? special stuff that you guys do or plan to do? what is the plan for the car? will it see the 1/4th of mile? track? etc etc
Old 04-13-2011, 09:43 AM   #24
AMR
Member#: 171509
Post 1 was updated
Old 04-12-2011, 03:05 AM   #25
tweaek
Member#: 279638
Wow! Will be exciting to see the final results.
tweaek is offline   Reply With Quote
788 WHP on PUMP gas 93 octane on the Project Evo Dyno Flash Proven Power Bragging 76 03-08-2017 09:22 AM
2011 Subaru WRX STi Limited Sedan 1080p and stills, near Mt. Hood. HannahSubaru North West Impreza Club Forum -- NWIC 118 12-24-2011 01:51 AM
UPDATED 720p 2011 Subaru WRX STi Limited Sedan at Rowena Loops near Portland Oregon SubaruShawnPDX North West Impreza Club Forum -- NWIC 19 02-18-2011 11:47 AM
Daily driven FP Green STi... 11.9 on pump gas at full weight x99percent Proven Power Bragging 56 05-04-2006 06:36 AM
How much power is the stock STI turbo worth on Pump gas?? 93oct WRBLUEWAGON Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 10-20-2003 10:07 AM
