Welcome to the North American Subaru Impreza Owners Club Thursday October 22, 2020
Old 08-17-2020, 04:56 PM   #1
kgozi
Member#: 489048
Default JDM twinscroll downpipe, restrictive design a dealbreaker?
One of the last bits of my build is the exhaust, is this restriction going to really hinder performance on the dyno when I get a pro-tune?
If so I will have to get it cut and reweld from a shop. Has anyone stayed with this design?
kgozi is offline   Reply With Quote
Old 08-17-2020, 05:20 PM   #2
Psychoreo
Member#: 79643
2021 STI TE
Terminal black pearl
I ran the stock JDM twinscroll downpipe on a Ver8. Stock everything and made ~280whp/272wtq. That might be backwards, it might've been 272whp/280wtq. Either way, that's about what it made with the stock turbo/downpipe and an e-tune on the dyno.
Are you swapping to some big glorious twinscroll turbo, or running the stock one?
What engine?
Old 08-17-2020, 09:46 PM   #3
kgozi
Member#: 489048
What engine?
Version 8 EJ207 stock turbo basically a “stage 2” buIld
Old 08-17-2020, 11:42 PM   #4
Psychoreo
Member#: 79643
2021 STI TE
You'll be fine.
Old 08-18-2020, 09:04 PM   #5
kgozi
Member#: 489048
You'll be fine.
Does your jdm downpipe have the same design where it gets more restrictive like mine? Not sure if this is a common design for all of them
Old 08-18-2020, 09:31 PM   #6
Psychoreo
Member#: 79643
2021 STI TE
I honestly don't remember. I did the swap ~8 years ago. If you're really worried about it, when you bring the car in for exhaust work to have the DP lengthened (I'm assuming that's a JDM length DP), have the shop match the larger size. It's not going to make a noticable difference, but you'll feel better.
Old 08-20-2020, 01:33 AM   #7
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
You may give up 5whp with the factory donut gasket taper.
D-Rodman is offline   Reply With Quote
