07-18-2020, 07:55 PM | #1 |
Member#: 457257
W. Canada
Vehicle:2020 WRX WRB |
Remove Light Scratch 2020 WRX
Hi, I just got my new 2020 WRX and i was cleaning some fingerprints off the window panel with my microfiber cloth and i guess there was a rock. How do i get rid of these scratches?They are light and dont catch a finger nail.
https://ibb.co/vwygLTk
07-18-2020, 08:31 PM | #2 |
Member#: 512654
Vehicle:2019 wrx red |
DA polisher with a black or white foam pad, and a finishing polish.
07-18-2020, 09:23 PM | #3 |
Member#: 457257
W. Canada
07-19-2020, 12:48 AM | #4 |
Member#: 512654
https://www.detailedimage.com/Menzer...P217/32-oz-S1/ this would be my choice, with a black foam pad, but anything similar should do the job. ive used it on scratched up tail lights and have them turn out perfect. plastic door pillars should finish out well with it. bet you can find some youtube vids of people fixing the same issues.
07-19-2020, 01:47 PM | #5 |
Member#: 138957
Vehicle:2016 WRX STI Limited DGM |
If you're trying to remove scratches from the window frame like in the pictures linked, I do not recommend a DA polisher. The black on the window frames are a matte black tape, if you polish you will make it worse by making it shinier, even damage the tape. Also many polishes will leave staining.
A better solution is to use a microfiber towel and lightly spread/work in some polish and wipe off. Choose a polish that is more of a gel so it won't stain. If it still remains you can try some sort of dressing to help hide like CARPRO PERL diluted 3:1. With the matte black tape there's not much you can do if it gets scratched besides replace/try to hide. |
07-19-2020, 10:17 PM | #6 | |
Member#: 457257
W. Canada
07-19-2020, 10:45 PM | #7 |
Member#: 495630
not sure that can be "polished" thats the trim piece over the frame, cant really "polish it" and you will just thin it out and scratches will still be there, its a flat black and they are very thin coating and they fade and chip really really easily. Options would be to remove them and paint them gloss black a couple of coats and then a couple coats of clear....it will last longer and look better and you can wet sand scratches out if need be after. Or remove them and wrap them in 3M gloss black.
07-20-2020, 09:56 AM | #8 |
Member#: 495630
well if its "tape" as some are saying, then its permanently damaged and has to be redone.
07-20-2020, 04:53 PM | #9 |
Member#: 138957
It is a tape/vinyl wrap material, you can see the seems both on the outside easily where there's overlap and on the inside of the frame where it ends and is the same color as your paint. If you pull it off your frame is actually the same as your body color underneath.
I won't recommend a polish for it as I'm not confident it will work at all. A dressing or trim coating may help hide though. |
07-20-2020, 11:37 PM | #10 |
Member#: 512654
if nothing else works, here's your answer. go to about 6:30 sometimes idiotic youtube vids come in handy lol
07-21-2020, 12:26 AM | #11 |
Member#: 459312
Vehicle:2004 WRX Wagon Hybrid 6MT Swapped WRB |
If that's not a vinyl tape its an anthracite black plastic trim piece scratches like that are basically a replacement required.
Only chance you have to fix it is to heat it with a heat gun may blend the scratches in If it is vinyl tape then replacement is all you can do period |
08-18-2020, 02:57 PM | #12 |
Member#: 517629
Vehicle:2012 WRX Blue |
For scratches that light and in a more narrow area I would recommend a finishing polish with a microfiber towel and your finger
08-18-2020, 06:39 PM | #13 |
Member#: 22412
SWIC
Vehicle:2024 Legacy Sport |
it's tape - I would not recommend trying to polish it
https://parts.subaru.com/a/Subaru_20...10-905-01.html |
