Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-29-2020, 12:26 AM   #1
bmacdo
Member#: 514452
2017 WRX
Crystal White Pearl
Default 2017 WRX Exhaust Recommendations?
So recently I have installed my cobb catted resonated downpipe and have been loving it so far.. Only issue is that my muffler delete is now incredibly loud and has terrible drone. I was looking at the r400 and am worried that it won't be loud enough. Is there any thing that is just a little bit quieter than muffler deletes? Preferably a dual exit.
bmacdo is offline   Reply With Quote
Old 07-29-2020, 06:29 AM   #2
rustyshackle42d
Member#: 451058
2017 WRX Base
Nameless catback with 4inch mufflers?
rustyshackle42d is offline   Reply With Quote
Old 07-29-2020, 12:57 PM   #3
hengyu408
Member#: 493782
2020 WRX
Depends on your ears. I have my Cobb resonated j-pipe connected to a r400 and it's pretty droney past 3K rpm.
hengyu408 is offline   Reply With Quote
Old 07-29-2020, 02:17 PM   #4
bmacdo
Member#: 514452
2017 WRX
Crystal White Pearl
Any chance you could hook me up with a sound clip??
Old 07-29-2020, 03:35 PM   #5
WrightWRX
Member#: 494418
Maybe try finding The SPT midpipe. I too run muffler deletes with a catted j pipe and it’s probably my favorite setup I’ve had. The resonator on the spt mid really brings the drone and raspiness down. And it’s not as loud as I was expecting it to be.
WrightWRX is offline   Reply With Quote
Old 07-29-2020, 06:09 PM   #6
Jdmx13b
Member#: 479302
You could just slap your stock axlebacks on to save you money as, pretty much any quiet catback isn’t gonna be any louder. If you’re dead set on it than the invidia q300, awe touring, grimmspeed catback, and perrin dual tubes are revered as the quietest often too quiet catbacks with little to no drone. I’d probably avoid the r400 for sure as everyone knocks it for having drone. I’d suggest at least try getting a resonator installed before pulling the trigger on a catback
Jdmx13b is offline   Reply With Quote
Old 07-29-2020, 08:18 PM   #7
blue sedan
Member#: 311622
2020 WRX
Lapis Blue
He's correct!put the stock axle back exhaust on ..less drone, noise and angry neighbors
blue sedan is offline   Reply With Quote
Old 07-30-2020, 05:57 PM   #8
bmacdo
Member#: 514452
2017 WRX
Crystal White Pearl
Except I don’t want something quiet. I want something just quieter than muffler deletes
Old 07-30-2020, 09:35 PM   #9
su_ba_roooo
Member#: 418242
2017 WRX
This video with decibel readings says the Remark cat back is actually a little more tame than the usual axleback muffler delete. Might be worth a look.
https://youtu.be/ATYcmxG51Mk
su_ba_roooo is offline   Reply With Quote
Old 07-31-2020, 12:35 AM   #10
bmacdo
Member#: 514452
2017 WRX
Crystal White Pearl
I’ll definitely check it out right now
Old 07-31-2020, 03:12 AM   #11
user1029
Member#: 57064
2008 STi IAG built
HTA86 E85 Kel272s Cos IM
Q300 for 3" flow and none of the noise
2.5" STI midpipe with resonator is another option
user1029 is offline   Reply With Quote
Old 07-31-2020, 08:31 AM   #12
alapilusa
Member#: 424692
2015 WRX
i agree. if you want something just slightly less loud than straight muffler deletes, the nameless catback with 4inch mufflers or even stock midpipe and just nameless axleback with 4inch mufflers is probably you're best move
alapilusa is offline   Reply With Quote
Old 07-31-2020, 12:08 PM   #13
Nguyenypoo
Member#: 517196
Cobb resonated downpipe with stock exhaust.. If you want it loud muffler deletes
Nguyenypoo is offline   Reply With Quote
Old 08-02-2020, 09:38 AM   #14
BoostedTeaParty
Member#: 515430
2017 WRX Premium
'19 X3 M40i
If you want loud, there will most likely be an accompanying drone. I have the Cobb catted and resonated J-Pipe and the Invidia Q300 cat-back. It's loud when you're aggressively accelerating (and gives you the satisfying exhaust pops) but there's no drone, and it's civil enough for a residential neighborhood. Sound clips are all over the internet for that one.
BoostedTeaParty is offline   Reply With Quote
Old 08-10-2020, 03:50 AM   #15
bungarra
Member#: 441457
2016 WRX PRemium
Agreed. Q300 TBE is still quite loud, R400 will be plenty loud with plenty of drone.
bungarra is offline   Reply With Quote
Old 08-10-2020, 08:35 AM   #16
veebooster
Member#: 510831
2016 WRX
I find the R400 cat back just right on volume. A bit of drone at 3000rpm but not ridiculous.
I can see volume increase by adding a j pipe but does the drone really bump up that much? Why? Must be sound frequency change i guess.
veebooster is offline   Reply With Quote
Old 08-13-2020, 05:29 AM   #17
bungarra
Member#: 441457
2016 WRX PRemium
J-pipe changes everything massively.
Old 08-23-2020, 01:05 AM   #18
izzi426
Member#: 517976
2017 WRX
Check out a few comparison youtube videos. I really like the nameless and nvidia exhaust.
izzi426 is offline   Reply With Quote
Old 09-18-2020, 02:31 PM   #19
St1nkyPete
Member#: 518688
Just installed this setup (cobb cat res dp to r400) and honestly i think the drone got better. Yes its much louder, yes it drones around 3k, however I find that the note from the droning is much less obnoxious and head hurting than with just an r400. Went cruising for a few hours on it and found myself enjoying it much more even though volume wise it is louder, also strangely enough it seemed easier to talk to my passenger around 3k because the note of the drone doesnt reverb in your head as much. I can try to upload some sound clips this weekend, but i think if ur okay with the level of drone without a downpipe and are okay with a pretty decent volume increase then go for it (I personally think it sounds absolutely incredible)
St1nkyPete is offline   Reply With Quote
Old 09-30-2020, 02:54 PM   #20
w_dyer13
Member#: 516175
2019 WRX base
dark grey
I have the Invidia R400 catback with resonators, and it really purrs more than anything. Doesn't wake the neighbors. Cold start is nice and aggressive and then it actually idles quieter than the stock exhaust. Youtube videos are nice, but everyone's audio is different and it's near impossible to get a really great sound reproduction. What others are saying is right, No resonator and j-pipe make it a lot louder and more aggressive but still tame compared to a few other brands out there. I come from a line of Honda's so I have internal drone in my bones and the R400 doesn't drone to my ears at all. Best way to hear it is go to a meet and listen to people who have the gear. Good luck!
w_dyer13 is offline   Reply With Quote
Old 09-30-2020, 04:30 PM   #21
Straight6
Member#: 419593
I would go with the Q300.
Straight6 is offline   Reply With Quote
