09-23-2003, 03:53 PM | #1 |
Member#: 44009
South East
Vehicle:2001 Toyota Tundra red/bird poop |
My Rex, and some questions.
Hello all. Im new to this group. I just purchased a used 02 WRX, blue in color. Manual trans, pretty clean car. I work at a Subaru/Volkswagen dealership in the service dept, so I was kinda on the lookout for a good used one. This car in particular apparently was a repo or lease turn in. I spotted it on the truck from the sale, and put it on the lift pretty quick. It has 4 brand new Potenza RE 732's on it. It has a short shifter with a black plastic 8-ball type knob (which I like a bunch). I also noticed a large, light blue rear sway bar, and poly/aluminum mounts on the front subframe. I checked the trans fluid and diff fluids, and as far as I can tell they are synthetic type. 42,000 miles, and appears to be in good shape. Shifts good, clutch takeup feels good, and the pedal has some oomph to it.
Now, for my newbie questions. And, I know I am going to take some heat, but here goes. First, what exactly does UTEC stand for. I have been reading this site and WRXhackers, and am acratching my head on that one. Second, the front of my car seems to sit a bit higher than the rear. Is this common on WRX's, or is the swaybar on the rear set too low? The dealer I work for is kinda on the small side, so we dont see a ton of WRX's, and you all know Subarus stance on modded cars. Sorry for the length of my post, but I really dig this car, and I dont want to screw it up. -Toddb
09-23-2003, 04:12 PM | #2 |
Member#: 41477
South East
Vehicle:2006 Tahoe that will pull your bumper off |
Congrats on the buy! UTEC=User Tunable Engine Computer. Go to www.turboxs.com and you can find out pretty much everything you need to know about them. As far as the suspension, the rear is a little higher than the front. If it looks like it's high though, it probably is. I really don't know if it would be your sway bar though. Hopefully some other guys will chime in here and help you out. Anyway, have fun with your car. You'll be tuning it in no time!
FYI: the blue color on your car is World Rally Blue or WRB. |
09-23-2003, 04:13 PM | #3 |
Member#: 2998
VIC
Vehicle:2002 WRX WRB |
UTEC (User Tunable Engine Computer ) is a piggy back computer that sits between your stock ECU and the sensors the car uses to do it's timing / fuelling etc etc and then alters those signals http://www.turboxs.com/ wich allows you to dun different engine maps. Basically a performance enhancement for your car. I allows you to load up different maps for different conditions / driving styles if you wish.
The wheel gap larger at the front is standard. Post some pics or take a measurement and i'll compare to my stock car if you wish. If your car has those mods IMHO it's been driven pretty hard. A good thing!! As long as the car has a full service history. Enjoy your car and drive safe. Gethin. |
09-23-2003, 10:03 PM | #4 |
Vehicle:OK buy Nates beans westcoastroasting.com |
The blue sway bar is made by Whiteline and the "poly/aluminum mounts on the front subframe" sound like an "anti-lift" kit, also by Whiteline.
Try: whiteline.com.au for more info. Whiteline is an Austrailian aftermarket manufacturer. I have many of their suspention parts, including the RSB and ALK on my car. Good luck with your new WRX, and shift smoothly. |
09-23-2003, 10:12 PM | #5 |
Member#: 11482
South East
Vehicle:02 WRX Acute Stickeritis |
Or he could possibly have an upgraded front rollbar with the poly bushings instead of the anti-lift kit. The rear bar can't be adjusted (except perhaps for its stiffness setting, but has nothing to do with ride height.)
Congrats and have fun with the car. |
09-24-2003, 11:53 AM | #6 |
Member#: 11482
South East
Oh, and it is typical for the front to sit a little higher than the rear.
09-24-2003, 12:09 PM | #7 | |
Member#: 44009
South East
Thanks for all the posts, I dont feel so stupid asking about the UTEC now. -Toddb |
09-24-2003, 01:31 PM | #8 |
Member#: 19905
SCIC
you work at a service department at a dealership and your thinking about cutting springs on your wrx?
09-24-2003, 01:32 PM | #9 |
Big Ron
Super Moderator Member#: 18062
Vehicle:on car parts so PM me b4 j00 buy |
DO NOT cut the springs! This will create a very bad ride and throw your alignment and geometry all out of whack. Wait till you can get some proper springs. The apparent uneven ride height is there for a reason, so don't worry too much about it. Springs should be around $250 or so plus installation if someone else is going to do it. Check the used classifieds here for used ones for less.
09-24-2003, 01:34 PM | #10 |
Member#: 19905
SCIC
p.s. i wouldnt reccomend it. seriously, if you just want to buy lowering springs, they are pretty cheap. of course, struts and springs are a better way to go, but its a lot better than cutting your springs
09-24-2003, 02:01 PM | #11 | |
Member#: 44009
South East
Well, it was just a thought, no tools in hand yet. I do have access to spring compressor and alignment rack, but I just wanted to see what the consensus was before I did it. I had a 91 Jetta Coupe with very mildly cut front Eibachs, and after I aligned it, it was fine. I drove it for 3 years like that with no real issues with tire wear, other than burnouts. I'll probably just get the Eibach kit and some konis when money permits. -Toddb |
Similar Threads | ||||
Progress Front Sway bar for 03 Rex and some noltec bushing | z-rex | Suspension/Brakes/Handling | 26 | 11-19-2009 02:11 PM |
List of parts I need to fix my tranny issues and some questions.... | WRXfoME | Transmission (AT/MT) & Driveline | 2 | 03-20-2009 11:48 AM |
Sold My Rex and have some thigns for sale...... | chitownrex74 | MWSOC Private Classifieds | 4 | 06-07-2007 08:24 PM |
Hello all! My introduction and some questions/advice | itskrees | Newbies & FAQs | 6 | 05-25-2007 01:41 AM |
here is my rex with some new rubber | djrocker666 | Member's Car Gallery | 7 | 09-12-2002 07:23 PM |
